Question about Philips 26MF231D 26 in. LCD Television
I have a 50inch plasma tv green light go on for a few seconds then blings red . i replaced two blown capacitors still same promblem.... need help
    President:
  • 1,077 Answers
You must have some electronic experience when you replaced the bad capacitors.
Best thing to do is find a Service Manual for your TV on the internet. It will really help you in a big way to diagnose the source of the problem. The Service Manual will give you red light blinking codes, circuit diagrams, test points, and part# lists.Usually, cost under $20.
Another thing you might want to look at is the power supply for the screen. Most manufactures call it a Backlight Inverter Board. The TV maybe trying to power up the screen and failed. Then, when into protection mode. The Service Manual should define the red light blinking code for you.
I hope I shed some light on the subject for you.
Posted on Jul 14, 2009
Model:Philips 42PF9965 Plasma At switch on the green light comes on for a few seconds,then it goes off and the red light starts flshing.After several attempts the tv may come on live and stay on until you...
You might have some swollen capacitors on your power supply board. They will be easy to spot out, because they will not have flat tops like the rest of the capacitors. Replace them with the same rating capacitor. You will need a soldering iron, solder and solder wick for this repair. If you are not comfortable with electronics I would recommend taking it to a authorized service provider.
Apr 14, 2011 | Philips 42FD9954 42 in. Plasma HDTV
Ours is a 50inch . It just turned it self off and the red light on the front is flashing rather than contant red or green when on
Film capacitor Is bad. So the power relay and capacitor need to be replaced. One pretty much wears out the other. Parts are a pain to get a hold of. But very cheap. 1/2 dozen of each cost around 50 cents delivered from overseas.
Relay is a small rectangular box. It's what makes the clicking sound. Film capacitor is usually yellow or blue colored. Rectangular with two leads to the board. Almost directly next to relay.
Apr 11, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
LG 32" Plasma TV power-on problem
Your power supply board is dead, u know basic electronics’ and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
hope this helps...
Jul 02, 2010 | Panasonic TH-42PWD6UY 42 in. HD-Ready...
Philips flat screen 42" flashing red light 7 times it stops for 5 seconds and 7 more flashes if i unplug and plug it a few time it will come on
my 42 inch phillips, i turn it on green light comes on for 10 sec then red light comes on and flashes 4 times then stops for 5 sec then repeats.
Apr 20, 2010 | Philips 42PF9631D 42 in. Plasma Television
LG plasma have an amber light when turning on then green then red
After all the research I found out that the IC on the Z board is bad and new board was ordered and replaced. The plasma work fine after that and picture is excellent with the new board. This forum is great, without this I couldn't fix it myself. Thank you.
Sep 30, 2009 | Zenith P42W46X 42 in. Plasma EDTV
TV will not turn on, the light goes from green to red.
I own the same model. You have 1-2 Blown Capacitors. Take off the back cover, And look towards the center of the main power board. Look towards the center of this, and there are 2 capacitors side by side. You should see them swollen at the tops, even maybe a little black residue that has come out. I soldered on 2 new ones, and bingo! I would suggest replacing them both.
Dec 13, 2008 | Philips 42PF9631D 42 in. Plasma Television
Philips 42PF7220A/37 42" Plasma TV
After you remove the back cover inspect the power supply board for swollen or bulging capacitors. Pull and check any capacitors that you suspect to be swollen. Next, look for a sticker in the upper right hand side of the TV set. Use the values you find on the sticker to calibrate the voltages on the power supply board.
Feb 09, 2008 | Philips 42PF7220A 42 in. Plasma Television
Toshiba Plasma TV Green and Pink (Diffusion?) Problem
I could be wrong but sounds like your plasma display is going bad. What is your model number?
Dec 28, 2007 | Toshiba 42HP66 42 in. LCD Television
Philips 26MF231D 26 in. LCD Television Logo
191 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
