Question about Garden
MTD mower won't engage traction belts
The blades operate fine, it will go into gear, forward,reverse and nuetral, but won't go anywhere. I recently fixed the linkage that some how fell off. It worked great for one mowing, gears and speed control worked. I raised the back tires off the ground, gears still engage. All belts seem in good shape.
Check to see if rear axle is broke. Jack up the rear of the tractor, put it in gear and spin one of the rear wheels, the one on the other side should spin the opposite way. hope this helps
Posted on Jul 14, 2009
Why won't the blades engage on my riding mower 54" mtd 13ap625k730?
You have probably thrown the belt for the blades. If it continues to throw the bet check the tensioner.
Aug 10, 2014 | Mtd Garden
Mower for Yardman 760 will only move in forward gear or reverse for a few minutes, then will not move in either direction whether the blades are engaged or not.
The drive belt going to the rear transaxle is either worn or the incorrect length. If drive belt has not been replaced in awhile, I would recommend getting it replaced. Hope this helps.
Sep 26, 2013 | Mtd Garden
Hi i just bought a second hand MTD C4510 ride on mower yesterday, and the drive belt came off , where can i view a diagram to fit it so it can drive forward etc
u should have two drive belts .go to nearest seller of mtd ,get owners manual .u can'not push foot speed lever to quicky up & down .start to learn how to use your mower slowly .there is no gear box for forward & reverse speed. but u have forward & reverse gearbox .talk to your dealer he will explain
Dec 10, 2010 | Mtd 46" Dozer Blade, Fits All & Yard -...
MTD riding mower does not move forward or reverse.
this is a belt driven transmission. from the engine driven pulley going aft towards the xmission differential there is another smaller variable speed pulley, there is a long belt between these two, from the variable speed pulley there is a larger xmission pulley that sits kitty-corner to it with a belt between these two. This larger "xmission pulley" is what drives the differential and depending upon which gear you have selected, makes it go forward or reverse. Check that both belts between pulleys are on, check that pulley's hardware is completely secured (nuts tightened down) The heads of these pulley's are splined to align to the shaft(s) and if they aren't tight, they will just spin and not engage the transmission. If your battery is under the seat, remove it and you should be able to see and access the aft pulleys. If both belts are on and engaging the pulley's and the shaft is turning on the transmission pulley than you have transmission differential failure. Bet it's the belt off or pulley head loose. Good luck, hope this helps
Apr 14, 2010 | Garden
Mtd model series 790 mower wont move, belts are fine and transmission wont go in nuetral
mtd 1993 riding mower model 828 I was mowing then tractor stopped and wont go forward or backward It runs fine, and blades
seem fine. Drive belt looks fine.
Sep 17, 2009 | Mtd Garden
Stalls when engage blades in forward, but cuts fine in reverse
Did you try to disengage the safety feature that should shut the tractor off when the blades are engaged and the tractor is placed in reverse? I believe that it is located under the shift leaver
May 14, 2009 | Mtd Garden
Garden Logo
232 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
