Question about Frigidaire FRS26H5AS Side by Side Refrigerator
I am not getting water to the dispenser or the icemaker. I know the h2o line leading up to the fridge h2o line is clear. Dont seem to be getting any water to the lines leading up to the filter.
  • 1 more comment
  • fvillarreal7 Jul 13, 2009
    Yes I am getting water from the house. I replaced the inline valve connecting the home line to the fridge line. I know the i have flow to that point.
    i am not getting h2o to the icemaker or h2o dispenser. I know i am getting from the home water line.
  • fvillarreal7 Jul 14, 2009
    I hear it make some noise when i engage the water dispenser. where exactly is the solenoid?
    President:
  • 1,126 Answers
What is your model number...I can most likely find a parts "expolded view" for you to locate the solenoid. On my unit it is on the back side where the water enters the fridge.
Posted on Jul 14, 2009
    Top Expert:
  • Frigidaire Master
  • 78,257 Answers
DO U HERE THE SOLENOID VALVE OPEN WHEN YOU TRY TO DESPENSE WATER? THE MOST COMMON CAUSE OF THIS IS THE VAVE BEING STUCK/INOP
Posted on Jul 13, 2009
  • 3,037 Answers
Are you getting water from the house at all to the hose? You should have water pressure to the fridge itself at the very least.
Benjamin
Kelvinator fridge freezer
  • If your refrigerator leaks water, you have a problem with either a water line or a drain line. If your refrigerator has an automatic icemaker or a water dispenser, the water supply line could be broken. Automatic icemakers have a drain line that runs down to the drain pan beneath the fridge. Mold build-up inside the drain line can lead to a rupture that allows water to escape .A broken drain line can also lead to water leaking from your refrigerator.
Dec 16, 2013 | Freezers
My icemaker is not dumping the ice when it's frozen.
Replacing the icemaker is neither expensive nor hard. Order a replacement on the Internet.
Sounds like a malfunction in the icemaker itself.
May 27, 2017 | Whirlpool 25.6 cu. ft. Side-by-Side...
The water coming out of the water dispenser in our GE Profile PSC25PSWA fridge is hot--hot enough to take a bath in. We don't know why the water is suddenly not being cooled and think this is causing...
Is this a new fridge that was recently installed? Because the only thing I can think of that could be causing hot water coming out of the water dispenser is either the installer/tech hooked up the fridge water inlet line to a hot water line somewhere.
Either that, or there is so much extra plastic water line running around in back and/or bottom of the fridge, that the water in the line is getting heated up by being in contact with the condensor coils or the compressor, etc.
No doubt, this is an interesting situation and some more background will likely be needed to get to the source of the problem, especially since you didn't mention any problems with cooling in the fridge or freezer.
Hope this was Very Helpful and let us know some more info, if my basic hunches aren't the problem. Best regards!
Aug 21, 2009 | GE Refrigerators
Water not going into icemaker. Water dispenser works fine.
Check the water valve at the back of the fridge if present.
Even if you used blowdryer, ensure that linse are not frozen by performing a complete defrost.
Disconnect water lines from icemaker, and blow with compressor if the above did not work.
May 20, 2009 | Kenmore Refrigerators
Icemaker and Water Dispenser won't dispense either....
Do as the guy above suggested? This more than likely is the problem. It is not expensive to replace. The question is, can you do it? If you can check to see if the valves are bad, buy new ones and try to do it yourself. If you are uncomfortable, then get a tech or a friend to help you. At least your frig is still working.
Feb 16, 2009 | Freezers
Whirlpool icemaker
Your unit has infered sensors on the frezzer left and right walls. There is a diagnostic test sheet brown in color in your kick plate.All you have to do is open frezzer door look on the right sensor it should blink twice followed by a 1-2 sec delay,if that is good press in flapper door on right sensor do not block path of infered beam you will not see a beam its invisable.Once you hold in flapper on right sensor the led should be solid.If solid optics are good if not solid led replace optic sensors
Jan 25, 2009 | Whirlpool ED5SHAXM Side by Side...
Whirlpool icemaker
Try using an hairdryer or defrosting the unit completely , this often get rid of blockage caused by frozen lines fixing the problem.
The water lines can also be unblocked from dirt using a thin flexible shaft. This after defrosting.
If all that does not fix the problem, then you may need to replace the water valve, the icemaker solenoid, or the whole icemaker assembly.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Jan 23, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Icemaker does not work
Dec 15, 2008 | GE Profile PCF23NGW Side by Side...
Fridge is leaking
Your plastic line which carries water to the dispenser has a crack in it.  Activate the dispenser and have another person pinpoint the lead and splice two pieces together with plastic connector.
Oct 15, 2007 | Amana ACD2232HR Side by Side Refrigerator
Frigidaire FRS26H5AS Side by Side Refrigerator Logo
87 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
