Your settings sound pretty good.
FREEZER temp should ideally be set at zero... or just immediately below... and the REFRIGERATOR at 33°F or immediately above freezing.
Before you actually rip your refrigerator apart and start trouble shooting... IF possible... It is best to unload everything and completely defrost your unit... open , dry and powered off
Plug it all back in and start over completely anew.
If then... it is still failing... Powered off
There are really only three parts...
For actual trouble shooting... once you have determined if it is the freezer defrost circuit... find the appropriate temperature sensor on your wiring diagram... that is the cheapest part to experiment with... "DEFROST THERMOSTAT" ... BUY IT.
Install it... powered on...!!
I ordered the "heater" at the same time... as I am getting old & don't fit inside freezer areas for extended periods and it was in the immediate area (my parts were from appliancepartszone)
Try using the specific part number on an online search... get at least three prices... and look at SEARS Parts prices... for ABSOLUTE worst case pricing... (same part... terrible price!).
Got it? Sears Parts... No!
Your primary logic board... will be the worst/high cost item
that could be causing your DEFROST PROBLEMS.
Use extreme care and wire tie your connections AWAY from the fan blades. Any OBSTRUCTION there will cause more troubles than you are fixing
Good luck and happy hunting
Normally when frost build up occurs it's because warmer outside air is getting into the freezer and the moisture from that warm air cools and condensates then freezes into frost or ice. You either have a bad seal like the other listing states try leveling the front a little higher than the back. Or you may have an issue with the defrost heater, thermostat or timer. Do you have a light that comes on from time to time? If so you have an auto defrost unit. If there is no light you may not have a frost free freezer which means you will have to remove the frost manually.
Please check the bellow links for your knowledge:-
http://www.wikihow.com/Stop-Your-Fridge-from-Ice-Build-up
http://www.ehow.com/how_4781069_prevent-frost-build-up-freezer.html
Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
