Question about Lexmark Z2420 Printer
Paper feed button keeps blinking; documents won't print
    Problem Solver:
  • 12 Answers
Which buttons keeps blinking? have you checked your cartridges. you could be out of ink
Posted on Jul 13, 2009
I can't get anything to print from tray 1, the manual feed. I'm trying to print envelopes and they keep printing on 8.5x11 paper from tray 2. If I put envelopes in tray 2 it won't print
Have you already tried this? After you click print and select your printer, click properites and select your paper from 8.5x11 to Envelope.
Jun 25, 2012 | Xerox Phaser 8560MFP Laser Printer
Epson Printer Problem
HI,
Press the fonts.gif load/ejectbutton. The printer ejects the jammed paper and then resumes printing.If the error is not cleared, open the printer cover and remove thejammed paper. Then reload paper in the sheet feeder and press the fonts.gif load/eject button. The printer resumes printing.
Jul 24, 2008 | Epson Office Equipment & Supplies
Paper light keeps blinking, paper full, won't print
Paper light blinking could mean a few things on this machine.
There could be a paper jam in the machine. Open the front cover remove the drum and toner and look in the machine. You can also check in between the drum and toner by removing the toner from the drum. Open the back cover and look for a Jam as well.
Try putting a piece of paper in the manual feed tray which is right above the paper tray, sometimes on certain documents the margins are too big and asks to go into the manual feed slot.
Apr 12, 2010 | Brother HL-2040 Laser Printer
Printer won't print documents. Green light on
Hmmm, try feeding a sheet of paper into the manual feed slot... you might have inadvertantly sent a Manual feed job, and the printer is waiting for a sheet to be fed by you.
Feb 10, 2010 | Dell 1710n Laser Printer
Paper feeding halfway through then stops
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 03, 2009 | Samsung CLP 300 Laser Printer
The Paper light keeps flashing when theres paper in the printer
A few things could be happening here.
1. Clear the print queue, and if there are jobs that won't delete, reboot the computer.
2. Now clear the jobs on the printer (cancel job button) until the status light turns green.
3. Put a piece of paper in the manual feed tray on the front.
4. Print a test page.
If the test page prints to the paper in the manual feed tray, then it is set as the default tray. Go into the printer settings and change it to "auto" or tray 1. If the test page prints to tray 1, but the original document you tried to print (when it got stuck) still won't print, cancel the job. Now, again, put paper in the manual feed tray. Try to print the document again and if it pulls from there, go into page setup of your document and change the setting from "manual" to "auto" or tray 1. Clear the job again (if it's stuck) and you should be able to print again. Hope this helps. This is one of the most common solutions - it happens a lot, especially with documents that are emailed from other people and once they get stuck in the queue, nothing will print (except the test pages directly from the printer, like you describe).
Jun 25, 2008 | Brother HL 5250DN Laser Printer
Paper LED Blinking
Did you see http://www.fixya.com/support/r310860-lights_indicate
The Paper LED is flashing.
papereroor2.gif Meaning of LED Indication
Front cover is open:
Close the front cover of the printer.
Back cover is open:
Close the back cover of the printer.
Paper jam:
Clear the paper jam. To see paper jams and how to clear them, click here. If the printer does not start printing, press the Go button.
No paper fed manual feed slot:
Put the paper back in the manual feed slot.
Memory full:
The printer memory is full and the printer cannot print full pages of a document. To solve this problem, click here.
Print overrun:
A print overrun occurred and the printer cannot print full pages of a document. To solve this problem, click here.
Clean drum unit:
The corona wire needs to be cleaned. To see how to clean the corona wire, click here.
Jan 04, 2008 | Brother HL-2040 Laser Printer
Red "Paper" light blinking Brother HL-2040
I agree with another su=olution. The paper light was blinking on and off sugesting a paper jam. Paper had jammed in the back roller and displaced the small lever out of its slot.
Open rear cover, open paper guide by pulling it downwards so you can see the rollers, In the middle of the guide you will see a black lever about 25mm long to the right of this you will see a small slot. The guide will have been pushed to the left of this slot and the Plastic cam will be bowing toward the front of the printer (about 3mm). You need to pull the 25mm lever towards the rear of the printer and then slide the plastic cam to the right so the blade part of the cam slides into its correct slot. The blade is about half a mm thick and the slot is the same and is about 60mm to the right of the lever Use a torch to see it easier. This is a 2 minute job once you see what is wrong.
Hope we have helped someone out there fix a printer
Nov 01, 2007 | Brother HL-2040 Laser Printer
Lexmark Z2420 Printer Logo
124 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
