Question about Kenmore 24032\24036 Top Load Washer
Kenmore 80 leaks in
Top load washer: Leaks water at the start of the rinse cycle. If I tilt the washer back you said there is a plastic pump. Can this be replaced?
  • 25 Answers
Yip no worries pump is the same as phillips/whirlpool 5min job only 2 clips
Posted on Jul 13, 2009
Water leaks under washing machine
SOUNDS LIKE YOU MIGHT HAVE A WORN OUT DRAIN PUMP, YOU WILL HAVE TO OPEN IT TO DO A VISUAL CHECK ON IT,
Feb 02, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore washer leaking water out bottom in rinse or spin cycle.
During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details. All the time If the washer leaks all the time, check these: Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate. Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician. Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it. Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Jan 24, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore top load washer 110-24642300 is leaking when it fills
tip the unit back and lean against the wall so you can look under it you will see the pump it is plastic. more than likley this is your problem. let me know if you need more assistance
Feb 24, 2009 | Kenmore 22642 Top Load Washer
Leaks water
Probably a bad water pump. That is were the Kenmore usually leaks.
2 screws on the top panel right and left sides.
Remove these screws, tilt the control head backwards.
Remove the wiring harhess connector.
Remove 2 clips holding the cabinet to the back panel.
Remove the cabinet by pulling forward.
Pump is attached to front of motor.
Feb 21, 2009 | Kenmore 24642 Top Load Washer
Washing Machine stops and leaks
A Clothes Washer with the complaint "Leaks in Front" (on floor) can be;
Defective Water-Pump (Very common of non-belt models) - Many water-pumps become defective due to the constant wear and misc. items becoming lodged (coins, necklaces, shoe laces, screws, etc.) or breaking the plastic housing or connections. The water pump is fairly simply to replace and is located on the inside front of the machine.
The water pump is typically a white or off white plastic and will have (2) black drain hoses connected; one coming from the tub and the other going to the drain out the back/rear of the machine. Electric pumps with typically of 2 wires going to and connected to the pump. ** Note: When disconnecting and removing the water-pump, becareful of water remaining in tub that may come shooting/flowing out.
-C
Fremont, CA
Jan 28, 2009 | Kenmore 24032\24036 Top Load Washer
My Kenmore 80 top loader washer is full of water and will not drain. Yesterday I tried to speed the cycle along and stop it during rinse cycle and moved it forward but now I have tried everything and it...
Sounds like the drive belt that operates the pump has failed.
You will have to pull the washer out and remove the back panel to peer inside. The pumps are normally a piece of **** plastic and about the diameter of a 'personal pizza' and are driven by a V-belt when working. You should also be able to see that one of its hoses goes to the rear of the machine and exits to the drain pipe.
If you find you do need a belt, you can get the proper part number from the online Sears/Parts section by entering your complete model number when asked.
The pumps don't normally quit instantly but start to leak on the floor if the seals fail so it is likely only the belt.
Dec 14, 2008 | Kenmore 24032\24036 Top Load Washer
Kenore 80 top loading washer leaks
If is leaking at the front of your washer its gonna be the pump
May 04, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore Washing Machine
Open up behind, after taking off the wall power plug. Check to see it the hose from underneath the tub is loose, tighten. Or replace hose if damaged.
Oct 07, 2007 | Washing Machines
Kenmore 24032\24036 Top Load Washer Logo
Sal De
fordexpert
Robert Rankin
