I have an akai flatscreen that will not power up
    President:
  • 1,077 Answers
It's the #1 plaguing issue with flat panel TV in all brands. Most likely the TV has a power supply related problem. It's possible that it maybe a bad capacitor or transformer on the power supply board. Or, it maybe something simple like a blown fuse inside the TV. The most common thing to go out on flat panel TVs is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board. But, I can't say it's 100% the problem because I can't actually look at the tv over the internet. I can only make guesses with the symptoms.
You have a few choices:
1. You can try leaving the TV unplugged for 30 minutes so the TV can reset itself.
2. If by chance the TV is still under warranty, go that route.
3. If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists.Usually, cost under $20. And most cases the new part cost less than $15.
4. Pay a TV shop to do the repairs. It maybe costly, but get an estimate of how much they will charge. That way you can decide if it worth repairing or replacing the whole TV.
I hope I shed some light on the subject for you.
Posted on Jul 14, 2009
Akai Flatscreen T V will shut off write After U TURN IT ON
sounds to me like capacitor faults on power supply,,,check for swollen capacitors that are leaking a black substance from the top of capacitor when swollen,,,(easy enough to see),,try replacing the capacitors with the exact same value in uf or mf but use a slightly higher volatage capacitor,,ie,,if it says 16v on the side of capacitor use the same or a higher voltage (if you use a higher voltage capacitor make sure theres enough space to refit as the higher the voltage the larger the capacitor,,make sure you replace it with the same amount of uf or mf which is also written on the side of the capacitor,,,,,hope this helps,,,
regards
kenny
Jul 04, 2014 | Televison & Video
Akai troubleshooting
Your Akai probably has audio outputs to connect to an external amplifier. This is explained in the instructions for your TV.
Dec 16, 2013 | Televison & Video
If my akai flatscreen 32in tv is moved or if the power goes out sometimes I plug it back in and the red light doesn't come on. Other times is when I'm watching it and I turn it off it goes from...
bad joint remove back panel with tv off check for any bad joints on power board also caused by thermal fault with tv on use a heat source over boards till tv shuts down then check suspect board
Dec 23, 2012 | Televison & Video
I pushed the wrong button on my remote and now my Akai flatscreen says no signal. But I don't know what button I pushed! Please help!
Unplug TV from power outlet ,wait 5 min and pluged back.Should go back to manufacture setup
Cheers
Aug 23, 2011 | Televison & Video
Akai 42' flatscreen i turn the power on the green indicator lights up and in i hear a click but i dont get a picture no other functions work such as volume,input,or channel buttons. is it my main board or...
On the power supply board there is a VA & VS voltage that you need to check to see if they are reading right. On the inside of the panel there is a lable that will tell you what the Voltages should be for VA & VS. If they are ok, they you probabaly have a bad Y board, if the votages are wrong then you need to replace the power supply. And check for bulged caps on power supply too.
Oct 14, 2010 | Akai PDP42Z5TA 42 in. Plasma Television
Takes up to 10 mins to cut on when pressing power
Ur power supply board is dead.Replaced the power supply board will solved this problems.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Mar 02, 2010 | Akai LCT2715 27 in. LCD Television
Where do i get a manual for an 32" AKAI LCT3285TA flatscreen? I'm looking on how to program for an external HD antenna.
Hi
Click HERE and download required instruction manual. You may need to enter 5 digits for confirmation on website to start downloading.
Jul 09, 2009 | Akai LCT3285TA 32 in. LCD Television
Televison & Video Logo
62 people viewed this question
Top Televison & Video Experts
