Question about Whirlpool Calypso GVW9959K Top Load Washer
I have a calypso top load washer. It comes on but turns of soon after coming on. I tried the rinse spin cycle and it does nothing.
  • 25 Answers
Faulty soleonoid
Posted on Jul 13, 2009
Whirlpool Calypso Washer Mdl#30942 gets stuck during rinse cycle. Machine runs, then stops, but does not rinse completely. Last 35-38 min cycle is problematic. What is wrong and how to fix it?
It's hard to tell by your description of the problem, but it sounds like it could be the timer If it's not running while in spin mode, or as simple as a belt if it's running and not spinning fast enough.
Nov 28, 2014 | Whirlpool Calypso GVW9959K Top Load Washer
The washer off and on on the rinse and spin
there prob coins blocking drain pipe and cant 100% empty.
i had it with mine
Apr 15, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Residue on clothes
For low water volume - or "Trickling" effect...
1. Turn off the water supply to both hoses.
2. Remove hoses (one at a time so you don't get them confused)
3. On the washer side - look for a removeable screen inside wher you just removed the hose.
4. Using a small screwdriver - pop out the screen and reverse-flush it/clean it. It will likely be full of sediment and calcium deposits from your pipes.
5. Replace the inlet screens.
6. Re-fit the hose to the machine.
7. Turn on water supply valves.
8. re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 11, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
I have a Kenmore top loading washer model #110 and won't agitate
First, see the Sears parts site for your washer.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.23912100
Also see the Whirlpool (Kenmore) Service Manual for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
The first thing I'd try is using a different cycle. If the washer works as it should, the problem points to the timer.
I'd also check to make sure that when replacing the switch, the connections to the timer haven't come loose.
Since you've replaced the Lid Switch, the motor has power for the drain and spin cycles.
These washers use a reversing motor. The motor turns one way for agitating and reverses for the drain and spin.
Since you cannot hear anything when it is supposed to be agitating, the problem does point to the timer or motor.
Nov 14, 2009 | Kenmore 22422 Top Load Washer
Kenmore 80 Series - machine won't rinse or spin
Manually move the timer to the SPIN mode and turn it on.
If nothing happens, replace the lid switch.
With a model number I could be more specific.
Feb 27, 2009 | Kenmore 24032\24036 Top Load Washer
Whirlpool calypso model GVW9959K-0 leaking during rinse cycle
hi my name is joyce
Sounds like your pump is leaking. if it is leaking when you are on a spin cycle.
now if it is stuck on f1 cycle and wont drain unplug and let stay unpluged for 60 seconds and replug and see if you can restart on drain and spin cycle. let me know if I can help with any other problems.
thanks
joyce
Feb 06, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
While the washer drains and spins, new water comes in
Drain hose must be at least 30 inchs above the floor.
Jan 06, 2009 | Kenmore 24032\24036 Top Load Washer
Washer does nothing during rinse then leaks during spin cycle
hi thanks for the question i would check the drain hose your problem is the washer is not draining check the drain hose thanks the appliance doc
Sep 27, 2008 | Maytag Atlantis MAV6000 Top Load Washer
at this point i hate to do this but if yo want a free replacement you have to contact whirlpool. this was involved in a class action lawsuit and they are making the repairs for free. otherwise replacing the pump is simple and you can get them off ebay for really cheep. :)
Jun 29, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
90 people viewed this question
Dan Webster
Dan Webster
Sal De
