Question about AlloBaby Torino S12F Jogger Stroller
The tires on my allobaby jogging stroller are always going flat. I'd like to purchase some puncture-proof tubes to put inside but the size is so irregular that I don't know where to buy them?
  • 5 Answers
SOURCE: i need to find replacement back wheels for
i got mine through their website babytrend.com just look up the model number
Posted on Jun 12, 2009
  • 10865 Answers
SOURCE: Bugaboo Frog Flat tires
Any bicycle shop will be able to repair the tires for you.
Posted on Apr 06, 2009
SOURCE: tire blew on putting a little air in.
if you have run a long way your tyres should have been worn out even if you fill the air within preferred psi.so i suggest you to buy new tyres ..but remember everytime you change the tyre be sure the wheels are tightened at preferred torque since uneven torques are also responsible for easy worn outs.
Posted on May 23, 2009
  • 127 Answers
SOURCE: Need replacement tire for Hauck funfor kids jogging stroller 2006
You can buy any size tire at any bike shop and put it on you yourself,do you have inner tubes also,check them to.
Posted on Sep 02, 2009
SOURCE: My daughter bought a allobaby jogging stroller and
Short of calling the manufacture for a replacement i would suggest placing an add on Craigslist or a similar community forum asking for the part you need. Consignment shops might be another good start.
Posted on Sep 14, 2009
Tip
Tube sealants keep bikes from getting flats!
When it comes to fixing and preventing flat tires on bikes there are many options from tire liners to puncture proof tires, but I have found that tube sealants have been the best solution. Tube sealants can be used to fix existing punctures in your tires and can work as a preventative measure against future punctures. Making them a great fix and first line of defense!<br><br>They're also super easy to apply, you just inject the sealant into the tire through the air valve on the tire. The sealant works to coat the inside of the tube protecting you from any future punctures and if there is a hole in your tire it will fill and seal off the hole. A simple solution for a very big problem!
on Aug 26, 2013 | Adhesives, Coatings & Sealants
Tire tube flat
have you tryed a bike shop?? or a car tyer shop??,,they may get one for you,,if that fales try that tyer fix it stops leaks in tubless tyers
Jul 05, 2010 | AlloBaby Marbella 12 Jogger
The back rear tires will not keep air in them. How do I fix them or do I need to replace them? (Baby Trend Jogging Stroller)
More than likely there's a leak, maybe small but enough to cause a flat.
As for tubes your local bike shop may carry the 12" or the 16" depending on the stroller make and model. Check the side of the tire to see if you can identify the size, if not the stroller manufacturer or the site should give you more information.
The tires with these jogging strollers come off fairly easily with any regular bicycle tire levers. Although it's possible to take them off by hand, if it's difficult any bicycle shop would carry standard bicycle tire levers. I personally recommend the life time warranty tire levers by Pedro. They are very strong and designed to take off some of the beefiest mountain bike tires.
It would also be good to have spare tubes. You can find bulk tire tubes on eBay for cheap!
Nov 04, 2009 | Baby Trend Expedition Double Jogger
I have a tire tube that's punctured. how do i get a new one?
If you walk often, best bet is to just replace the tube as you're going to have to take out the flat tube either way. It's also the fastest rather than trying to patch up a small tube and doesn't guarantee that the repair won't leak air. Small the tube, the expansion/contraction with heat/cold would raise that possibility.
Tubes can be bought even at Wal-Mart and other places for $3. You can always purchase a bicycle tire lever as these 12"/16" tires come off fairly easily. Of course if you absolutely cannot get them off for any reason a bicycle shop will be able to do so.
This is a great video showing how you can replace the tube.
Nov 04, 2009 | Zooper GoAnywhere Walkair Stroller
One of the back tires on my baby trend columbia stroller is flat. I cant find a hole anywhere. It seems like it may be a problem around the thing that you put air in....any suggestions??
If you pump the tire again with enough air and put your ear against the tire you may be able to hear the air escaping.
If it's a slow leak you may not be able to hear it but any bicycle tire levers will allow you to take off the tire. More than likely you pinched the tube or punctured with a sharp object in use.
I usually recommend replacing the tube completely, the cost & ease of replacing the tube is better than using the patches which I find it a headache to deal with smaller wheels especially for any jogging strollers.
Nov 03, 2009 | Baby Gear
My jeep jogging stroller has a flat. Do I need to
Replacement tube may be more beneficial even though the fix/patch may be cheaper. If you live in an area that have varying climate, the patch along with the repaired tube can expand and contract and may cause small leak if not repaired properly.
Otherwise I would get the right size tube, most jogging strollers are either 12" or 16" tube inside and can be bought from your local bicycle store. With that, you'll need bicycle tire levers which can also be bought at the bike shop. Just about any type of tire levers will do. Of course I'm sure your bike shop can do this for you to possibly for free with a purchase of replacement tube!
Oct 27, 2009 | Jeep Liberty Limited XT Urban Earth Jogger
My daughter bought a allobaby jogging stroller and it doesnt have the child tray on the front and we would like to get one, wondering if you have any idea where we can purchase one
Sep 13, 2009 | AlloBaby Marbella 12 Jogger
Aug 25, 2009 | Hauck Sport - Smoke Umbrella Stroller
Front wheel of stroller has a hole in it.
Go to your nearest bicycle shop and buy a puncture repair kit. It's real easy to use or you can ask the staff in teh shop to do it for you.
Jul 07, 2009 | Schwinn Runner ST Jogging Jogger Stroller
AlloBaby Torino S12F Jogger Stroller Logo
104 people viewed this question
Top AlloBaby Baby Gear Experts
Dorel UK
Dorel UK
Are you an AlloBaby Baby Gear Expert? Answer questions, earn points and help others
