Question about Amana 19 cu ft Bottom Mount Refrigerator, ABB1921DE
Amana abb1924deq freezer and refrigerator parts are same temp warm
  • 87 Answers
SOURCE: SZD27MW - Freezer Fan not working - temp runs 40 midway in freezer
Voltage is either 240V or 110V either way it is stamped on the fan motor. You have a sensor controlling the fan and heater which could have gone open circuit and on some cabinets they use the neutral through the heater to bring in the fan so you could have a heater gone. You can bypass the sensor but this should not be a long term solution as it is a safety mechanism. Hope this helps.
Posted on Aug 17, 2007
  • 1214 Answers
SOURCE: amana refrigerator warm
Chances are if they are getting cool but not cold-
1) the evaporator fan in the freezer is not running
2) Defrost heater has failed
3) Defrost sensor has failed
4) Defrost timer/refrigerator control has failed.
Check for ice build-up on the back wall of the freezer. If there is ice, unplug or turn the unit off for 6-8 hours with the doors open (put any food in a cooler with ice to maintain). Note water may come out of the refrigerator.
Plug the unit back in or turn it back on, close the doors, and check temperature after a couple of hours of operation. If all OK, you will need to have the above tested, or, if you know how to use a multimeter and can read a schematic/wiring diagram, I can instruct you on how to check the above.
Posted on Jan 20, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: Amana BX20RW Refrigerator slightly warm freezer not freezing
Check the thermostat, to make sure that it is working properly. The theremostat is a long wire in the top of the freezer up near the fan. If that is bad it will not let your freezer cool correctly
Posted on Feb 08, 2009
Maytag317
  • 1136 Answers
SOURCE: Amana refrigerator not running but light and water dispenser work
Hi, Remove the front kick plate at the bottom and locate the defrost timer box. You will see a hole and there will be a round switch you can turn. Turn in clock wise and see if the refrigerator starts.
If it starts, the timer needs changed. If it does not starts. locate the cold control (thermostat)
Check continuity on the switch. If it is the on position and the circuit is open, you need to replace it.
I hope this helps. Please let me know if I can assist you further.
Thanks
Vic
Posted on Jun 14, 2009
heatman101
  • 43501 Answers
SOURCE: Top refrigerator part not cooling, bottom freezer and fan working
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on May 25, 2010
Refridgerator section is warm, freezer is cold, however the freezer has alot of frost build up? is it ready for the land fill?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 21, 2011 | Amana ABB1924DEB / ABB1924DEW / ABB1924DEQ...
No Temperature in Refrig
It indicates that there is problem with your thermostat .
How old is your refrigerator ?
Are you facing this problem frequently ?
SAM ANDERSON
Sep 30, 2008 | Amana ABB1924DEB / ABB1924DEW / ABB1924DEQ...
Amana abb1924dew bottom freezer not freezing but hear "motor"...and fridge not very cold...cleaned underneath already..Help please
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Check cold control (thats where you turn it colder)
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME If this was helpful
Jul 30, 2011 | Amana ABB1924DEB / ABB1924DEW / ABB1924DEQ...
Top portion of frig is warm, bottom area seems cool. Freezer below is cold.
heatman101
Apr 26, 2011 | Amana ABB1924DEB / ABB1924DEW / ABB1924DEQ...
Not cooling with moter running
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 16, 2011 | Amana ABB1924DEB / ABB1924DEW / ABB1924DEQ...
Refrigerator is not cold, but it is definitely getting power. It is an amana model abb1924deq
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
heatman101
Feb 06, 2011 | Amana ABB1924DEB / ABB1924DEW / ABB1924DEQ...
Bottom freezer is working fine. refrigerator is warm(does not get any colder no matter how i set the controls) what is the problem?
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
Water Running in refrigerator from Freezer
heatman101
Sep 19, 2010 | Amana ABB1924DEB / ABB1924DEW / ABB1924DEQ...
Amana BR22 top refrig not cooling
HI, your Air damper control assembly is faulty. you should replace this vital part asap.
May 24, 2009 | Amana ABB1924DEB / ABB1924DEW / ABB1924DEQ...
Food and drinks are frozen in refridgerator
you have a bad thermostat,go to sears .com click on parts put your model number in(inside frig.on wall or freezer wall) click on parts and you can get your part-mike
Oct 31, 2008 | Amana ABB1924DEB / ABB1924DEW / ABB1924DEQ...
Amana 19 cu ft Bottom Mount Refrigerator, ABB1921DE Logo
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
