Question about ASUS P5QC Motherboard - Intel P45, Socket 775, ATX, DDR3/DDR2, Audio, PCI Express 2.0, Gigabit LAN,
ASUS P5QC does not detect any devices... I have a HD and a DVD hooked up. The jumpers are set to normal but they are connected to the MB with one cable. Does it need to be a master slave setup?
  • ASUS Master
  • 5,660 Answers
Yes, since you are using two IDE drives on One flat ribbon cable, you need to set the harddrive as a Master drive, and the optical, (DVD), drive as a Slave drive.
When two IDE drives are installed on one cable, BIOS needs a way to find the drive that has the O/S, (Operating System), then the optical drive.
Would recommend you buy a SATA optical drive, as soon as you can afford it. SATA DVD burners aren't that expensive.
Your motherboard is set up for SATA, and SATA is WAY faster than IDE. (IDE is also referred to as EIDE, ATA, and PATA)
Then of course a SATA harddrive, and a fresh genuine copy of Windows in the future.
SATA doesn't care where you plug in a drive, and doesn't care which drive connects to what SATA header. It will find that drive. You can connect any SATA drive, to ANY SATA header on the motherboard.
Having two IDE drives such as an IDE harddrive, and an IDE optical drive on the same cable, S-L-O-W-S your computer down! BIOS has to look to see which drive has the O/S first, then it will look for the optical drive.
Thought I would include two links that tell you, and show you how to set jumpers on the jumper pins, on an IDE harddrive, and IDE optical drive,
1.Harddrive:
http://www.youtube.com/watch?v=WwbboeMO7b8&feature=related
2.Optical drive:
http://www.youtube.com/watch?v=lldXwgPabhE&feature=channel
Should my solution have helped you, feel free to rate it.
Posted on Jul 13, 2009
  • 202 Answers
If you have both on a single ide cable the hd should be the master and the dvd drive the slave. otherwise the ide controller will not know what to do. you cannot have two master drives on the same cable.
    Problem Solver:
  • 11 Answers
You have to enable Marvel IDE controler
Posted on Aug 29, 2009
  • dambaru Aug 29, 2009
    I have the same MB. IDE Dvd rom is not in the list on first page of bios, but it is on the list of Boot priority devices, so i can boot from dvd rom.
My mb Asus K8N cant start using HDD WesternDigital WD3200AAJS
Unplug your computer.
On the end of the disk-drive, there is three-by-two grid of gold pins, labelled MA(ster), SL(ave), and C(able)S(elect). Move the jumper to the 'CS' position.
Start your computer.
Press DEL to enter BIOS SETUP.
Use "auto detect IDE drives", and the 160GB drive should be recognized.
Apr 24, 2010 | Western Digital Caviar WD1600 (1600YD) 160...
MY COMPUTER KEEP SHOW NEW HARDWARE NOT FOUND
you may have not properly set the jumpers on your new installed hard drive.
usually a computer will have 2 eide drive controllers where you would connect a ribbon cable. a ribbon cable has a middle connector and end connector and obviously another end connector that connects to the motherboard)
now you can connect upto to devices to that ribbon cable. most computers will have one device connected to the end connector (the hard drive) and no devices connected to the middle connector or sometimes they may have 2 device on the same cable: the hard drive on the end and a cd/dvd drive on the middle. others computers may have one ribbon cable for each device as computers usually come with 2 drive controllers (so you can connect 2 cables which means a total of upto 4 eide devices)
now, when you connect devices on 1 ribbon cable, the end device is the master device, the one the middle is the slave. to make a device a master or a slave you need to set a jumper. the jumper is usually located in between the ribbon cable connector and the power connector, the legend to know where the jumper goes to make it a slave or a master is usually on the label of the hard drive. you may need to check that label and with some pliers make the proper setting for that jumper.
on a new hd usually the jumper setting will be in master. so if you connected the hard drive on a ribbon cable that already has a master at the end it may not be detected. try to connect that master device on another ribbon cable that has no other devices connected and connect it on the end connector (not the middle one). if you have no other option but to connect it in the middle already having a master device at the end, set the jumper to on the slave position.
while you are at it. make sure you have your power connector and data (ribbon) cable properly seated.
if the caviar hd your are trying to install is an old hd and you know that you have the proper hd configuration and the cables properly seated, it is possible that no detection means hd failure.
Apr 04, 2010 | Western Digital Caviar WD1600 (1600YD) 160...
Trying to install Windows XP SP1 onto HD with this Motherboard. System will not boot from HD to start install.
Make sure your IDE hard disk drive is connected to IDE1 port and that the data cable is fully connected. Also check the jumper on the IDE drive. If you are using only one IDE hard disk drive set the jumper on the drive as a Master without a slave. If you are running two IDE hard disk drives set the primary drive's jumper as a Master with a slave. Set your second IDE disk drive's jumper as a slave. The master drive should be connected at the end of the data cable and the slave drive should be connected to the next data connector. Than check your bios settings. Power on the system and press the Delete key every 2 seconds until the bios menu loads. See page 3-1 in your manual. If you need the manual for the NF8-V MB click on the link provided below and download it;
http://www.abit.com.tw/page/en/motherboard/motherboard_detail.php?pMODEL_NAME=NF8-V&fMTYPE=Socket+754
You'll also need the program Adobe reader to view the manual. Adobe reader is a free download; http://www.adobe.com/products/reader/
Once you’re in the bios go to page 3-4, Standard CMOS Features.
Follow the instruction listed for IDE HDD Auto-Detection. Your HDD should be listed here. Than see page 3-7 in the manual. Open Advanced BIOS Features. A normal boot menu for the Abit would read;
First boot device Floppy disk drive (If one is connected). 2nd boot device should be (CD-ROM/DVD-ROM). Third boot device should list your primary hard disk drive's (Model number). Load your windows CD into your CD-ROM drive.
Once the settings above are set, press the F10 key to save your changes and exit the bios. Your system will auto restart. Windows should begin to load.
Cheers!
Mike
Nov 18, 2009 | Abit NF8-V Motherboard
Reboot and select proper boot device or insert boot media in...
Ok..try this. Disable the flash screen and quick boot options in bios. What might be happening is the prompt to boot from CD isn't being displayed due to one of those two options.
Apr 30, 2009 | ASUS P5QC Motherboard - Intel P45, Socket...
Asus P5Q Upgrade disk error
take the cabel from the dvd out...and try to start igen.
Or try to fixboot with your windows cd...
Apr 11, 2009 | ASUS P5QC Motherboard - Intel P45, Socket...
ASUS P5QC refuses to boot
This is a known issue with Asus motherboards. I got 2 in my shop with the same problem. While I didn't have your model I'll assume the issue is on that board as well.
Clear cmos with the jumper on the motherboard. This resolves the issue with no video.
There should be a 2 pin jumper, your motherboard manual will show you where its located.
Good Luck
Mar 27, 2009 | ASUS P5QC Motherboard - Intel P45, Socket...
When two drives are connecting cd or dvd it detects only one.
If they are IDE drives, then you need to set the jumpers on the rear of the drives. You should set one to master and the other to slave.
Mar 24, 2009 | ASUS Computers & Internet
Asus p5qc not working
The motherboard is dead most likely, if the cpu fan is running ? the hdd can be heard running ? the cd/dvd device is active ? then the motherboard is toasted. what is the system ?
compdoctor2005@btinternet.com
Nov 16, 2008 | ASUS P5QC Motherboard - Intel P45, Socket...
My MB does not accept 2 devices on IDE at the same time
ok
first i assume that your hdd is in master.then take your dvd then see in bbback side u find three pin .put jumper in second pin.
also read instuction on hdd and dvd some times there are defference in manufactureres policy.
Nov 14, 2008 | Intel DG31PR Motherboard
SATA drive not detected in BIOS and windows does not boot up
i have same problem with WD 250GB sata HDD. with same bord K8V-MX,  i all reday update BIOS with 0502 version.
plz plz plz help me.
CC me chepu_456@yahoo.co.in
Feb 21, 2008 | ASUS K8V-MX Motherboard
ASUS P5QC Motherboard - Intel P45, Socket 775, ATX, DDR3/DDR2, Audio, PCI Express 2.0, Gigabit LAN, Logo
1,065 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
