Question about Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System
Control panel in home does not respond. All lights on panel lit at all times.
    Champion:
  • 246 Answers
Change spa side switch
Posted on Aug 31, 2009
CONTROL LOCK GE GAS DRYER
  1. Press and hold for 3 seconds the "Control Lock/Unlock" button on the control panel to lock the control panel.
  2. Listen for a double beep and observe the "Control Lock" status light is lit when the control lock is in effect.
  3. Press and hold for 3 seconds the "Control Lock/Unlock" button on the control panel to unlock the control panel. The "Control Lock" status light is goes out when the control panel is unlocked.
Jan 31, 2015 | GE Dryers
Tip
The front light lit on my Whirlpool dryer is showing control locked
Hi.
If the front light lit is control locked, that means that your Whirlpool electric dryer had been set in control lock mode.
Control lock is a special mode that will prevent user from changing settings or using control until the dryer gets unlocked again.
The machine is set to control lock mode by holding down the CONTROL LOCK/UNLOCK button for several seconds. In the same way you can stop the control lock mode when the machine is already set to Control Lock.
When the dryer is running and Control Locked is on, the dryer can still be stopped by pressing the Pause/Cancel button, but cannot be restarted until the control is unlocked.
If the front light lit is control locked but the dryer door opens and it does not turn off, then you are probably in this situation. In that case, the door will be opening , but the machine still stays locked.
Disconnecting the machine from power, either unplugging power cord or tripping circuit breaker, won't help. The control lock system is designed to stay on in case of power failure.
If the machine is control locked, try unlocking it with the following procedure.
To unlock: Press and hold the CONTROL LOCK/UNLOCK button for 3 to 5 seconds to turn the control lock feature off.
If that does not work, try disconnecting power for five minutes to reset the machine, and eventually do unlock again. As said, cutting power alone will not cause the machine to unlock.
If the machine is still not responding, the lights stay on all the time, the dryer panel does not respond to control unlock procedure, and the door does not lock anymore, then it may be a defective control board.
If you are in this situation, before replacing the control board more parts, including the door lock must be tested. In that case the best option may be contacting the Whirlpool support number listed on the Dryer use and care manual, usually in the last pages.
In this case try resetting control lock as explained above, as told the dryer is more likely control locked and then stopped.
Regards.
Ginko.
on Feb 01, 2010 | Whirlpool GEW9250 Electric Dryer
Haier HLH406BB 40 in. LCD HDTV - tv will not turn on. is not responding to either panel or remote power buttons. red off input light is still lit.
hi sounds like a power supply fault could be capacitors, look for tech in your area good luck
regards
shaun
Jan 15, 2014 | Televison & Video
Display not showing
have you pressed the home button? on many systems the display times out after several minutes and you have to press the home button. If that is not the solution try power cycling your system. Dis-connect the battery inside the panel and the power and then reconnect the batter and then the power. You will have to wait a minute or two for the panel to power cycle up. Always call your monitoring station before opening the control panel and advise them you are doing so.
May 11, 2013 | 2gig Z-wave Wireless Control Panel Cntrl2
Wolf dual fuel range keeps beeping after a power surge. Can not get anything on the control panel to respond.
Remove power for a few minutes...plug back in to see if it responds.
If control panel still doesn't respond...it may be time for home visit by repair guy.
That control panel is the "brains" of the unit...power surge may have fried it.
Jul 23, 2011 | Ovens
Control panel in house is all lit red doesnt respond lights wont go off all systems are froze bad storm transformer blew on pole
Time for a repairman to check your system. The storm may have burnt out your main boarde if you don't have a surge supressor onn the system.
Jun 25, 2010 | Jandy Aqualink Rs4 One Touch Control...
My Bose 321 series II is not responding to the control remote commands!
You need to test the remote, in a low lit room try using your remote real close in front of a digital camera or video camera, hold the remote button down and look at the LCD screen of the camera, you will see blinking LED's if its working, (Dogs can see this light all the time I think) if you see the infrared beam in the digital camera image its working or transmitting.
Oct 27, 2009 | Audio Players & Recorders
Control Lock Light Is Lit And Won't Turn Off On Washing Machine It Will Not Respond
locate button with lock emblem beside it hold button down 3-5 secs ..still not going off suspect front control panel
Oct 24, 2008 | KitchenAid Washing Machines
The upper oven door is locked shut and will not release. All lights are off on the display panel and the oven does not respond when any setting are pushed. I have reset the circuit breaker several times...
im to assume that this happened while self cleaning, sonds as if you have had a high limit thermostat go bad adn has shut down oven function( depending on model there is also a fuse inline with the main control panel to protect it from the heat/ power surge, unit will need to be pulled out to acess fuse behind the unit
Jul 09, 2008 | Whirlpool RBD245PDS Electric Double Oven
DACOR DOWNDRAFT RV36B PROBLEM
when just the high and low lights are lit, the unit is in childproof mode. try holding down the high and low buttons at the same time until they go out. then if they do, check the response of the other buttons. If this dosen't help, there are really only 2 other options. Most often we see the control board go bad on these (located behind an access panel in the lower right hand corner of the unit below the counter) or the button pad contacts wear out. If the only button that doesn't respond is the up down button, and all the other buttons work fairly easily once its up..then you probably have a bad button pad. If the thing does all sorts of weird things and seem to have a mind of its own, probably a bad control board. the control boards on these fail so often, they re-designed the board to prevent further failures. The button pad is easier to replace and cheaper, so if you have to guess go with that first. good luck!
Jan 01, 2007 | Dacor Prefrence PRV36 Stainless Steel...
Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System Logo
190 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
