How to fix a Beko Washing Machine Door Interlock
  • 25 Answers
With a small screwdriver remove outer clampind band on door boot.gasket pull back gasket from front panel remove the 2 screws fom lock and reverse procedure
Posted on Jul 13, 2009
3 Suggested Answers
Coldcut
  • 1554 Answers
SOURCE: Door interlock flashing
Same issue with loose solder joint on the relays inside CCU (computer control unit)
the same bad CCU is used by several manufactures.
you have to open the CCU and re-solder the the relays to the board. they have microcracks around the legs.
you will get the door lock issue randomly.
to prove the issue open the top access panel .and pull up on the center black plastic connector and the issue will go away.
Posted on Feb 28, 2008
  • 289 Answers
SOURCE: how do i fix my washing machine interlock hotpoint hvf 344
The door should have a pin on it that pushes and closes the interlock switch. Check to see that the switch is inadjust ment to trip by turning off the water door open and with a plastic rod or a pencil push thru' the hole in the chasis where the door pin goes through and start the machine. If it starts quickly pull out the pencil, unplug the machine and adjust the switch. Plug it back in. It may continue on with the cycle you just started if not better! If not close the door aand start a short cold wash cycle. If it sounds like it wants to start, turn on the water and let it run thru' the complete cycle.
Posted on Jun 29, 2010
Washing machine had a door closing and opening problem, i thought i fixed it with a squirt of good old wd40 door now operates fine, but washing machine just hums and clicks now. o gosh what have idon
The WD40 should not have done any harm, unfortunately the faults with the door lock cannon be fixed with CRC, You will need to replace the door lock assembly and hopefully the machine will resume normal operation.
Apr 03, 2017 | Beko Washing Machines
BEKO 6108 XE door does not lock and machine won't do anything
might be a knackerd interlock on the door...
cheers
Mar 04, 2015 | Beko Washing Machines
How do I replace the rubber door seal on my beko wmb71642w?
This video will show you in detail how to replace the door seal gasket and fit the new one properly to beko wmb71642w washing machine How to Replace Beko washing Machine Door Seal
Oct 17, 2013 | Beko Genuine Washing Machine Door Gasket...
How do I replace the metal retainer ring arond the rubber door seal of beko washing machine
This video will show you in detail how to replace the door seal gasket and fit the new one properly to Beko washing machine How to Replace Beko washing Machine Door Seal
Jan 25, 2013 | Beko Genuine Washing Machine Door Gasket...
Beko door seal
This video will show you in detail how to replace the door seal gasket and fit the new one properly to Beko WM5140W washing machine How to Replace Beko washing Machine Door Seal
Jun 27, 2012 | Beko WM5140W
My beko washing machine will not spin. the door does not stick shut which when turned on its ment too. not sure whether it has something to do with door or atual system
hello there it sounds like a door interlock problem
where the catch goes into the body of washing machine is the door interlock held by 2 screws turn electric of and plug out of socket and take lid of washer at the front of machine between drum and casing where catch goes in you will see interlock release cable socket and undo screws keep one hand on interlock so it does not drop down and take this with serial and model number to your washing machine spare outlet or currys parts master online
yours ross
Nov 21, 2008 | Washing Machines
Washing Machines Logo
129 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
