Question about Dyson DC07 Animal Bagless Upright Cyclonic Vacuum
I lost the manual to my vacuum
I can't get the hose to work, there is no suction
  • Anonymous May 12, 2008
    no suction from my dyson wand
  • 372 Answers
If no suction from hose check the following.
The (U) shaped inspection port at the back of machine where flexi hose enters has not come off or has a blockage.
Remove flexi hose from rear of machine once off slide it fully up the wand handle hold handle end up to a light & look up the pipe for blockages.
Check side premotor filter.
Does it pick up ok when using to vacuum carpets or is that got bad suction to ?
Posted on Nov 25, 2007
This was it, It was a marker and a block of styrofoam together created a blockage in the u-bend underneath the flexi-pipe. After disassemblying the flexipipe from the back of the Dyson (its a clip, press the clip towards you and pull the flexi-pipe out). Once I cleaned it out the suction to the wand returned. Thanks for solution, Chris.
Posted on May 24, 2008
How to fix lost suction
Check for a blocked suction intake hose.
Jul 07, 2017 | Vacuums
It has lost suction
Have you got suction just before the motor? How about air coming out the exhaust?
Mar 14, 2015 | Vacuums
Riccar 8995 no suction
I think you mean it's an 8955, Riccar has not had a 8995 model. If there is no suction in the hose it has to have something clogging it. Open the little round opening on the back of the vacuum where the hose attaches to see if you have suction there.
May 18, 2014 | Riccar Vacuums
Poor wand suction
your cyclone assembly may need to be striped down and cleaned also remove the exhurst filter located under the bin.
Oct 15, 2013 | Dyson DC17 Animal Bagless Upright Cyclonic...
I have a model DC3 rainbow thar has lost suction. what can i do to fix it
Check suction at intake without any hose connected. If that is good, then connect hose and check suction again. If that is poor, then you have a clog. If still good, then check power nozzle by getting into the belt area.
Apr 01, 2013 | Rainbow E series Canister Wet/Dry Vacuum
Why has the hose on my dyson has lost suction?
It's most likey got a split in the hose, seperate the wand from the hose and depress the lever to remove from the rear and exend the hose inspecting in between the reinforcement rings. Splits can occur anywhere but are particularly prevelant at the plastic attachment ends
Nov 21, 2012 | Dyson DC07 Animal Bagless Upright Cyclonic...
Eureka pet expert vacuum lost suction
I had the same problem with exact same vacuum, was working great and the one day just lost almost all suction in the hose and in very very poor suction on base when vacuuming carpet, also when vacuuming the carpet everything I vacuum shoots out the bottom and hits my feet, never happened b4, checked all hoses and tor apart every thing to see if their war dust in motor, clogging anywere but nothing everthing looked great, NEED HELP CANT AFFORD TO BUY ANOTHER VACUUM OR TO TAKE TO REPAIR MAN TO B CHRGED AN ARM AND LEG, SOMEONE PLEASE HELPPPP!!!!!!!!!!
Jun 05, 2012 | Eureka 3276AZ Pet Lover Bagless Upright...
I have a dyson 07. Vacuum works fine, great suction using the hose. How do I switch to using the carpet vacuum. (I lost my instruction book) Thanks
If this unit has a suction hose built in to the handle, the carpet vacuum should start working after you return the handle hose to the proper position.
Dec 01, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
My VAX Vacuum has lost ALL suction power. I've
vax power pet 1 filter keeps getting clogged up so dirt not going into cylinder
Jul 05, 2009 | VAX Appliances Vax X5 Bagless Upright...
Dyson DC 14 lost suction to beater bar/ suction to hose/stick
My Dyson DC14 had no suction...see if this works...turn the Dyson upside down...there is a length of hose that connects the bottom of the vacuum to the top, careful remove one end of the hose and check for debris...mine was clogged. Removed the clog and works. Thanks for the above info on checking the hose for cracks.
Apr 11, 2009 | Dyson DC14 All floors Bagless Upright...
Dyson DC07 Animal Bagless Upright Cyclonic Vacuum Logo
284 people viewed this question
Top Dyson Vacuums Experts
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
