Question about HP Compaq d530 PC Desktop
HP Compaq D530 sff Will not power up
When I press the power switch the CPU fan starts, case fan starts, the speaker makes a couple of light popping sounds and power LED lights up. Then after about 3 seconds it shuts down.
  • Kellyt93 Apr 03, 2008
    Hi, I have the same issue. I took the ethernet cable out, still happens. Both the power light and hard drive light blink red. Could it be a bad power switch or battery? Thank you, Sam: missagd93@hotmail.com
  • so2r Dec 27, 2008
    I have the same problem in 2 separate D530s.  I updated the BIOS in both and ONE of the D530s now works fine, but one still won't fire up with the ethernet cable plugged in.  I have matched both BIOS' so I have no idea why one still does not fire up with the ethernet cable plugged in.  If I wait for about 5 minutes AFTER WinXP fires up, I can plug in the ethernet cable and all is well.  Any time before 5 minutes and it dies.
    I doubt it is a motherboard or power supply issue.
    k5wa at arrl.net
I have the same problem but it seems to be related to the NIC. When I start without the ethernet cable plugged in it's fine, plug in the ethernet cable and the machine stops dead. I can't even start the PC with the cable plugged in.
Posted on Mar 05, 2008
I get the same problem but it is a BRAND NEW power supply. do u think there may be a short somewhere? could the motherboard be causing this? jorgie_maxima98@yahoo.com thanks
    Genius:
  • 1,601 Answers
Sounds like your power supply went out.
Posted on Nov 16, 2007
How do i repair green blinking light in motherboard and not powering up?
Is the CPU fan running ? Check power plug to cpu fan could be a spot on motherboard that has to be plugged into with power.
Feb 12, 2015 | HP Compaq d530 SFF PC Desktop
Dear sir, my desktop is hp compaq dc7600 sff. everytime when it starting to boot the following info is appears: "512- chassis fan is not found. press f1". after pressing f1 it's starting to...
The sytem checks for the Chasis fan during the bootup (startup) process. The fan is connected to the motherboard via cable. Turn off the system. Open it and make sure the the cable is connected properly. While the PC is open, press the power button and check if the fan turns on. If not the chasis fan may have gone faulty, which needs replacement. If you find it faulty, you may find and replace the fan by removing the old/ faulty fan by removing the 4 screws and installing the new one.
Hope it helps! Good Luck!
CreativeTECH
May 02, 2011 | HP Compaq d530 SFF PC Desktop
Hp disktop erreur 920-fan command 2 pin connector
The CPU Fan is not working. Contact Compaq or go on Ebay and see if you can find a replacement fan. If you continue using your PC without the CPU fan operating, you will burn out the CPU. I hope this helps. Good luck and have a pleasent day.
Apr 30, 2011 | HP Compaq d530 SFF PC Desktop
512. chassis fan not detected the meaning
means that you need to go into the bios setting and go to hardware manager i thing on hp and dissable the fan monitor or open case and make sure system and cpu fan are pluged in and running
Aug 15, 2010 | HP Compaq d530 SFF PC Desktop
Compaq d530 SFF PC Desktop: what is the most amount of ram that can be place i...
hi! I have the same PC but not flat , and I work on it with 768mb RAM
it work fine with XP
I think 1Gb and more can cause problems and shirt your CPU life
don't use vista it over heat and exhaust the CPU
If you know how to control FAN SPEED , because even he heat up she don't accelerate , if you have an idea please let me know :
try.39@hotmail.com
thanks
May 18, 2010 | HP Compaq d530 SFF PC Desktop
Hyper Threading - How to?
right when the computer starts to boot up when you turn it on press F2 for the BIOS menu. a menu should pop up go to the correct category for what your looking for. there should be an option in the BIOS somewhere to disable/enable hyper threading.
Mar 05, 2010 | HP Compaq d530 SFF PC Desktop
CPU fan
there are metal clips install on heat sink. so press them down and turn them to up. fan will be unlocked.
regards,
Sep 28, 2009 | HP Compaq d530 SFF PC Desktop
All computer fans starts ok but trips with notice,
You may hear the case fans running. Remove PC cover and check CPU fan and replace, it may not be running at full speed.
Sep 23, 2009 | HP Compaq d530 SFF PC Desktop
HP D530 SFF CHASIS FAN NOT DETECTED
tell me the wright way to remove 512 chassis fan error i am very depressed on this
Mar 17, 2009 | HP Compaq d530 SFF PC Desktop
CPU FAN SPEED IN HP Compaq d530 Small Form Factor Desktop PC
The fan/heat sink on these models get plugged with dust very easily, use an air compressor or can of air to blow the dust out of the heat sink and fan. In extreme cases the thermal paste gets dried out and needs to be re-applied to properly cool the processor.
Dec 01, 2008 | HP Compaq d530 SFF PC Desktop
HP Compaq d530 PC Desktop Logo
247 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
