Question about Hotpoint WMA54 Front Load Washer
My machine keeps triping electric , every time i switch it on within 5 mins it trips rcd, is ok if i put it onto rinse and spin
  • 25 Answers
Sounds very much like a faulty element iff not check brushs on motor depending on age of machine
Posted on Jul 13, 2009
Hi, i go into the test mode and it starts on 18 and when it gets to 14 the house electricity power trips off.Any idea what part do i need to replace?
How can I figure out why my washing machine is tripping the ...
diy.stackexchange.com/.../how-can-i-figure-out-why-my-washing-machi...
Aug 17, 2012 - 110.24872300) washing machine which up to this point has been ...Note what is happening when it trips (is it starting to spin, starting to drain, filling, etc.).... If the outlet trips when the washing machine isn't running and isn't ...
Washing machine tripping RCD « Singletrack Forum
singletrackworld.com/forum/topic/washing-machine-tripping-rcd
Switching on the plug socket that the washing machine's plugged into caused no problems, but switching the machine itself on trips the RCD. ... then its possibly the water fill solenoid as most cycles start with a water fill. ... I've always guessed it is theelectricity/water combo somewhere in the machine so err on the side of ...
Nov 29, 2015 | Washing Machines
Power trips in spin cycle
Pump is leaking water and causing problems. Replace the fault part and clean thoroughly.
Feb 27, 2014 | Samsung Washing Machines
Zanussi washing machine trips rcd on spin
Hi Ian.
I am assuming your RCD is fitted in your consumer unit (fuse-box)?
If so, then the chances of this being the cause is minimal. The RCD trips wen electricity is not balanced between live and neutral wires - which means some is leaking out to elsewhere - which it shouldn't because it is dangerous.
It would have helped if you had indicated how old your machine is, and how much use it has had but I am currently leaning towards the motor have several winding options that kick in (or not) depending on the spin speed. It would therefore be a motor fault, or something as simple as the brushes are disintegrating (which is often accompanied by hesitant and intermittent behaviour from the motor). These types of faults mean that some of the electricity may be leaking to the motor casing and then to earth.
I would recommend you call an engineer or if you have decent DIY skills, locate a replacement motor (ebay or the likes) and swap it out.
Good luck
David
Dec 15, 2013 | Zanussi Washing Machines
I have had a new consumer unit fitted and the washing machine tripps the RCD during operation, not sure when because there is no indication where the machine is within its cycle.
Hi again,
You are more up-to-date with 17th and 2 RCD's than we are here in France- also knowledgeable!
It does appear to be a machine problem. What I would do is, going backwards from the final spin, try each cycle to give some indication where the problem lies. For instance there would be no water heating on spin of course BUT both of the motors, main and drain, would be working - the former at its hardest/fastest. If OK through spin, step back to rinse- again no water heating (normally). If that is OK then its pointing more towards the heater element than anything else as both of the motors would have been isolated by the earlier tests. I would not suspect the control board at this point. Obviously if the spin trips it could be either of the motors OR some dodgy wiring showing itself during lots of movement.
I would have the back off WITHOUT POWER(!) and check as much visually as possible.
Here's hoping!
John C
Feb 02, 2011 | Bosch Washing Machines
Zanussi jet stream iz16s tripping ouy rcd once filled up with
It would seem to me that the heating element needs replacing from the information you have supplied especially as it performs most of the other functions like filling and spin and drain.
Good luck
Mar 17, 2010 | Washing Machines
It keeps tripping the rcd at any stage through the wash cycle
hi there....possibility that you heater has gone short circuit and needs replacing......try selecting spin only if still triping out you have a faulty motor
regards Sir Galahad
Aug 18, 2009 | Washing Machines
My hotpoint ultima keeps triping the trip switch. it had f08 on the screen but now that has gone, but still trips electrics every time i press start.
Hi
f08 means heater relay cannot be actived so try unplugging heater element and see if it stops tripping the electrics.
regards
Mar 14, 2009 | Hotpoint Ultima WF860 Front Load Washer
AEG Lavamat W1450 2 years old,
possibly wire come loose or try disconnecting heater element and repeat spin cycle.if runs well then, replace heater.
Oct 24, 2007 | AEG Lavamat W1450 Front Load Washer
Hotpoint WMA54 Front Load Washer Logo
227 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
