Question about Fuji FinePix S3000 Digital Camera
When I connect the cable to the USB port the computer no longer recognizes the camera connection.
You may have to reload software that came with camera. Or go on line and search for it. It is also possible that your USB port is bad. Try a different USB port on your computer.
Posted on Jul 27, 2009
Set-up won't recognize that the USB cable is connected to both printer and computer and therefore printer won't work. What's up with that??
1. Confirm the USB port on the computer you are connecting your printer to is being recognized by your computer. The easiest way to do this would be to plug a known good USB Memory stick into the USB port you want to use. If you can read the contents of the USB Memory stick then the port should work. Remove the Memory stick, start the printer installation program (Make sure you don't the printer connected), want until the setup program tells you to connect the printer before you attach the Printer's USB cable.
If the printer isn't recognized try a different USB port, when picking a new USB port to try select a higher priority port, for example in increasing priority from, an external USB hub, a powered external hub, a monitor based hub, USB ports on the front of the computer, up to the USB ports at the computer rear. For USB ports on the same circuit select an USB 2.0 before an USB 3.0 port
Aug 04, 2015 | HP OFFICEJET PRO 6830 E-ALL-IN-ONE PRINTER
When I Connect My Aiptek 8100 camera to the PC, they show a message "USB device not recognized." Is this because I did not install it's driver? If so please tell me where I can find the driver?
Usually usb device not recognized is due to damaged usb cable or usb port..use a different usb cable and connect it to your pc, if your usb cable is ok then connect it to a different usb port. if the problem in not with the usb cable or port install driver from the cd you got with camera. if you dont have that cd download driver from the device manufacturer site.
Oct 03, 2012 | PC Mall 8100 (MODEL 8100) PC Notebook
Usb device not recognized
Assuming a healthy camera battery, capable of holding a charge - try another cable / USB port / Computer first.
When it's same on all USB ports and a different computer, wiggle the USB connector on the camera carefully. If the connection is ok at some point, it's the camera USB port making bad connection.
Jul 04, 2011 | Sanyo VPC-X1250 Digital Camera
My computer does not detect my power shot A400
If you camera is not detected when connected to your computers USB port what you can try here first is to connect the camera on a different USB port and make sure the connections and usb cable is fine, and if your computer is a desktop you can try connecting the the camera on the back USB port of your computer and see if that will be fine.
But if still not working I will suggest you try connecting the camera on different computer and also if possible use a different USB cable and reinstall the camera software if you have the setup disc for it.
Mar 07, 2011 | Canon PowerShot A400 Digital Camera
Camera is no longer recognized by the computer when connected through the USB port; I have already replaced the cable and checked it on different computers.
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Nikon Transfer or any other photo cataloging program.
Nov 08, 2010 | Nikon Coolpix 4300 Digital Camera
Trouble loading photos from camera into computer
Try the cable in another usb port and see if that works
Apr 01, 2009 | Canon PowerShot A590 IS Digital Camera
Canon EOS Digital Rebel XT will not connect to computer.
Please discard that the USB port or the USB cable are defective. You can do it if you try to hook your camera in other personal computer using the same USB cable. If it works, then follow the next instructions.
Connect your camera to the PC thru the USB cable and turn it on.
If you are using Windows, go to the Control panel - System - Hardware - Devices - and check if there is any device that was not recognized by Windows. Such devices are marked with a yellow question mark.
If so, get into the device item and with right mouse click, select to update the device driver.
If there was not unrecognized device, then you can unistall your USB port driver and then run a change hardware status to recognize the USB port again, then run the update driver routine.
Regards,
Feb 07, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Samsung s630
First, I need to ask the dumb questions:
1. Are both computers running XP?
2. When you connect the camera, do you turn the camera on?
3. Do other USB devices work when connected to the same
USB PORTS you are using to connect the camera?
Ok, since the camera is not recognized at all on both computers, we can pretty much disregard USB PORT failure, but just in case, try different USB PORTS on both, please.
Most if not all cameras should be recognized as mass storage devices just by connecting them to USB PORT on computer, and should be visible as a new drive in MY COMPUTER icon.
Maybe your bundled USB CABLE is not working, or this is one camera that insists on using the bunbled software package that came with the camera.
Last thing to try is to buy a multi-card reader/writer and put the memory card in there. That has to work!
Hope that helps.
Dec 30, 2008 | Samsung Digimax S630 Digital Camera
"little tikes- my real camera" can't upload pics
The USB connection seams to be very sensitive try pushing the USB cable into the camera firmly and wiggling it. Once the mass storage device is recognized be careful not to move the plug. The connection can be very flaky.
Good luck,
Mike
Dec 10, 2008 | Little Tikes My Real Digital Camera Pink
Camera No Longer Being Recognized
Does it connect to the PC via a USB cable? Then try connecting to a different USB port or if you have try a new USB cable. I had the same problem with my IXUS 400 and changing to a new USB port, directly to the PC - not a USB hub, it worked. However now I have several issues with my camera - no sound or image on the LCD screen, but I think these are unrelated.
Jan 27, 2008 | Canon PowerShot S400 / IXUS 400 Digital...
Fuji FinePix S3000 Digital Camera Logo
79 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
