Question about RaidMax SIRIUS (ATX-701WS) ATX Mid-Tower Case
Problems with Raidmax RMX-SRS/WS
I have just bougth a Raidmax RMX-SRS/WS and my fan indicator is not working(nor the led for the indicator) . My power on led isn't working neither.
I checked the links with the motherboard and seeamd fine to me but I could be wrong.
Can you help me?
I forgot to mention that at startup all the indicator go to the end of the scale.......
    Problem Solver:
  • 6 Answers
Posted on Feb 21, 2008
Mitsubishi ws 65313 power led comes on then shuts back off. led error code 2-2
Error code 22 indicates "short-circuit protect" fault is PWB power board part# 930B900001
Please understand that with a short in the power supply, you may also have problems in other areas. (i.e. Multiple problems)
The part is no longer available, but this web site may be able to rebuild it for you:
May 05, 2015 | Mitsubishi Televison & Video
Fan not working
I would simply unscrew it unplug the fan and replace it with a equal if not better one, be sure to open it before you buy the new fan to make sure of the connector hope i could help =]!
Feb 25, 2012 | RaidMax (RX-530SS) 530-Watt Power Supply
My amps stays in the clip mode where as the light on the two channel stays red
Page 7...
CLIP: red, to the left of each Gain control.
Normal indication: illuminates whenever the amplifier is driven beyond full power. The LED's brightness indicates the amount of distortion. Distortion that causes only brief flashing may not be audible.
During muting, the indicator fully illuminates. This occurs during normal "On-Off" muting.
Abnormal indication:
•Bright red illumination while the amp is being used indicates either thermal muting or a shorted output.
•If the amplifier overheats, the fan will run at full speed, and operation should resume within one minute. Allow the fan to run, and make sure the amplifier ventilation is adequate.
•A shorted or overloaded output circuit will cause excessive Clip flashing and possible overheating.
•If distortion is audible without a Clip indication, the problem is either before or after the amplifier. Check for damaged speakers or overloaded signal source. The amplifier Gain control should be in the upper half of its range to prevent input overload.
Jan 29, 2011 | QSC RMX 4050HD 2Channel Amplifier
Raidmax 500w power slowly died, then wont turn back on.
1.-Your CPU fan is working?
2.-Your Power supply fan is working?
If not and following your description I think that you have to replace your power supply.
If you have the light on in the motherboard doesn't mean that your power supply is good.
Check the first to points above and if 1 and 2 are not working
Replace your power supply.
Let me know how it is going!
Thank you for using FIXYA!
Don't forget to rate my help
Pablo :-)
Oct 13, 2008 | RaidMax (ATX-612WBP) ATX Mid-Tower Case
I broke my temp probe on my raidmax
if by the probe you understand front fan controller,yes,there are controlers to replace yours..just pay attention to fit in the bay..
Jan 21, 2008 | RaidMax SIRIUS (ATX-701WS) ATX Mid-Tower...
Power LED
Remove the hdd connector from the Mb. Borrow or buy a hand help AC. DC OHMS meater.
Run a OHMS test across the two pins. If OHMS reads zero the bulb is bad.
Nov 26, 2007 | RaidMax Scorpio Mid-Tower (Blue) (16116)
Fan not lightning up
there should be 3/4 small led (light emitting diodes) on the inner of the fan check the integrity of the solder on the wire to this led strip if there are any breaks in this then it can be re soldered.
if the fan is part of the PSU (power supply uinit then consult your local pc repair shop do not open the PSU.
If its just a case fan it would prob be easyer just to replace the fan.
hope this helps
Nov 03, 2007 | RaidMax NINJA 918 ATX Case
RaidMax SIRIUS (ATX-701WS) ATX Mid-Tower Case Logo
201 people viewed this question
Top RaidMax Computers & Internet Experts
Mohammad Abumuailek
Mohammad Abumuailek
Are you a RaidMax Computer and Internet Expert? Answer questions, earn points and help others
