Question about Dryers
Dryer works but will not heat up, can I replace the element myself? kenmore mod: 110 63032101 type: DDOT ELE 2406028-CV54
  • 5,911 Answers
To answer your question, "yes", replacing a heating element is a simple repair that you should be able to perform yourself. However, the problem may/may not be the heating element. There are several things that can cause a dryer no heat problem.
If the dryer runs, but does not heat, the first thing you need to check is the wall receptacle for the proper input voltage. A reading across the two hot leads (left and right slots) should read 220-240 VAC. If this reading is incorrect, check your breaker panel. Some homes have the dryer circuit on two breakers, vice one single 220 breaker. If the voltage at the receptacle is good, unplug the dryer and remove the cover on the terminal block in the back of the dryer. Plug the dryer back in and take the same voltage check at terminal block across the RED and BLACK wires. You should see 220-240 VAC if good. If the voltage is bad at the terminal block, but good at the wall receptacle, you have a bad power cord. If the voltage is good at the terminal block, then the problem is internal to the dryer.
NOTE: The reason a dryer will still run if the input voltage is incorrect is because the dryer drive motor only uses 110-120 VAC, while the heating circuits require the full 220 service. So, if you are missing a portion of your input voltage, the dryer may exhibit the symptoms you have.
If your problem is with the dryer heating circuits, the following link explains what to look for and how to troubleshoot:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
Pay particular attention to the paragraph that discusses proper ventilation. The number one cause of dryer heat related problems are caused by poorly installed, kinked, or clogged dryer ventilation. Your heating circuits are located on the lower right side of the dryer cabinet under the drum. You will need to remove the lower kick panel under the door to access. The elment is inside the heater box while the Thermal Cut-Out (TCO) and Hi-Limit Thermstat is located on the outside of the heater box to the left of the element. The TCO is located in the rear, while the Hi-Limit Thermostat is located near the heating element terminals. NOTE: Make sure the dryer is unplugged while taking any resistance checks. Make sure you disconnect any terminal wires before measuring to ensure accurate readings. If you have any questions, please let me know. I hope you find this information helpful.
Posted on Jul 13, 2009
Does any one know what the resistance reading should be for the start button on a Kenmore elite dryer.
look for the safety switch at the Door. Dryer wont run if it thinks the door is open
May 25, 2015 | Kenmore Dryers
Have a Kenmore Elite Dryer that won't start. Mod 110.65962401 Ser MS0303258 Type DDOT-ELE-2406028-CV54
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 22, 2011 | Kenmore Elite HE4 Electric Dryer
Whirlpool Ultimate Care II dryer trips breakers.
No way to know unless you do some checking. This video shows how to get into the machine: HERE
I have a repair manual that features the same basic style of dryer you may want to take a look through: HERE
Feb 14, 2010 | Dryers
It appears the heating element went out on our older Kenmore dryer - Type DWJR ELE 2406028 FM54. mod 110.62622101. Is this an easy fix?
Yes it is fairly easy to replace from the back. First verify it is the element and not the thermal fuse or a loss of one leg of the 240VAC circuit.
Eric
Jul 06, 2009 | Dryers
Dryer runs no heat
Sounds to me you either blew the fuse or tripped the circuit for the heating element. Try replacing the fuse or resetting the breaker before trying any repairs.
Jan 09, 2009 | Kenmore 64602 Electric Dryer
Dryer wont start just clicks.
could be start switch bad,main fuse bad,door switch bad,or a weak motor,you need to call an honest appliance repair shop(not sears$$$$$$$$$) I DON'T WANT YOU TO HURT YOURSELF,THE DRYER IS HIGH VOLTAGE(220)MIKE
Sep 13, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
355 people viewed this question
Top Dryers Experts
