Question about Kenmore 62622 Electric Dryer
Dryer will not start. Used it yesterday, no
Dryer will not start. Used it yesterday, no problems. Checked fuses, nothing wrong there.
  • Ned Halaweh
    Ned Halaweh May 11, 2010
    did you check to make sure 240V is coming into the unit?
    Problem Solver:
  • 8 Answers
The 220v is for the heater in the dryer only. All other features are 110v.
If you hear noise of motor, but the dryer drum is not moving, then you popped the belt.
For a no start, check door switch with VOM / continuity tester. A battery powered tester works well to confirm switch works.
This would require popping top lid at front from it's corner clips, and tilting the top back to the wall as it hinges at the back.
Removing 2 screws (first) holding lint chute to under side of access door of the lint filter screen. Pull out lint screen as well.
Even if the is not the fault, it's a good time to clean this area of lint 100%. Remove front panel complete to access with vacuum. Inspect belt at the same time. Clean off the slip rings that the drum rotates on at the front cover. These are high temp nylon glide rings.
The next area of test will be on the heated tunnel in the back of machine. Two snap switches control temp cutoff.
One could bypass the switch as a test only to see if dryer fires up. 2 screws hold these switches in place on tunnel with 2 wires. Connecting these 2 wires together bypasses the temp switch.
If this confirms bad switch, replace it by ordering from appliance parts. There are 2 switches, and might as well replace both at the same time.
Confirm power at the main circuit breaker box. If this is also a ground fault circuit, these are know to fail as well.
Test with it's test button on the panel switch, and by circuit tester at the outlet for the dryer.
Good Luck..
Posted on Sep 05, 2009
  • 547 Answers
Hi welcome to Fixya
You must pop off the top of the dryer then remove the front after the front is off you can remove drum .
The belt goes around the drum and the motor pully and under the tentioner wheel after you get belt on replace front and top.
PLEASE MAKE SURE TO UNPLUG FROM POWER THIS IS 220volts AND CAN HURT YOU BAD
Thank You For Useing Fixya
PLEASE RATE ME
Posted on Jul 18, 2009
What is wrong with my dryer?
Check the vent line (when it is working) for for good air flow...residual heat may be tripping the overheat safety.
May 10, 2014 | Whirlpool GEW9868K Electric Dryer
My roper dryer worked fine yesterday. It won't work today
remove back cover then locate the blower housing in the back,its round on this is a thermal fuse appx. 1" X 1/4" with 2 wires from it,this is the thermal fuse test it,if its open on continuity its bad and the dryer wont operate the pat number is FSR# 3392519
May 21, 2012 | Roper REX3614KW Electric Dryer
GE gas dryer won't start
you need a new motor
Apr 11, 2012 | Dryers
My maytag performa purchased at lowes model no PYET244AYW won't start. It ended a load yesterday and when my wife went to start a load today it does nothing. Reset breaker. Checked switch in door it...
The part called the thermal fuse is very likely going to blown due to the lint build up around the blower. To check that thermal fuse remove the wires from it and use a meter and check for continuty with zero ohms resistiance. That thermal fuse is going to be in the housing where the blower is and i have included 2 pictures it is going to be either one of the 2 shown in the pictures depending when the dryer was built which one the manufacture used at that time.
I hope i have been able to help you fix your dryer,
Aug 15, 2011 | Dryers
I have an older Maytag D8512 with an electric igniter. When I push the start button, nothing happens. I checked the pilot light and it is off. I used a long matchstick to see if I could start the pilo
there is no pilot light. electric igniter will glow and pull amps allowing gas valve to open. if you do not see igniter glow it is bad or thermal fuse has blown. look for 120 volts at the igniter when running. if voltage found bad igniter, if no voltage trace back to fuse/stats.this assumes dryer is actually running. if drum not turning could be a number of things. door switch, fuse, etc
May 24, 2009 | Maytag Dryers
Electric kenmore dryer 11066732500
Its possible that sometime when you were touching the wires that something came unplugged, or moved and short circuited
Mar 13, 2009 | Kenmore 74602 Gas Dryer
Kenmore 90 Series Electric Dryer will not run
chech to see if your belt is broken. It may have a belt switch
Oct 28, 2008 | Kenmore 62602 Electric Dryer
Dryer not working
Assuming the problem is associated with you changing the cord, it sounds like you have a wire crossed on the power cord. Double check how you have the cord installed first. If that is correct check your power to the dryer. Since you changed the type of cord, I assume you have had outlet replaced or have just moved to new house. If you have a fuse box instead of a breaker box, check your fuses. It takes two fuses for the dryer. If one of them blows, the motor will run but you wont get heat. The motor runs on 120 but it needs 240 for the element. I can't count how many people have bought a new dryer just to find out they only had a house fuse blown and nothing was wrong with their old dryer. If you have had wall outlet changed there could be a wire crossed in it.
Oct 05, 2007 | Roper REX3614KW Electric Dryer
Kenmore 62622 Electric Dryer Logo
141 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
