There is a clicking sound when it is heating and sometimes it doesn't heat
SOURCE: Whirlpool oven won't ignite
The good news for you is that your gas provider, the folks who bill you for the gas offer a free service whereby they will send out a technician to adjust your stove for no cost.
SOURCE: whirlpool gas oven sf315pemb1- oven not heating
Hi, It sounds like the ignitor has gone bad. Remove the floor panel in the oven and locate the ignitor fastened to the burner. There should be 120V going to the ignitor harness.
If you have voltage but no ignition, change the ignitor.
I hope this helps you. Please let me know if I can assist you further.
Vic
SOURCE: The oven won't heat up.
Hi This means a
loose/broken wire on the oven temp sensor or the oven temp. sensor itself is
bad and should be replaced. To solve this issue test the oven temp. sensor, it
should read between 1080-1120 ohms, if the rating is more then that and the
door appears to be closing fine then it is the control board that is bad and
should be replaced. Hope this helps...please post back for further assistance.
Daniel
SOURCE: kenmore gas oven will sometimes
The image below shows information about the ignition system on the oven burners of this range. That document shows some of the common causes of slow ignition. I recommend that you check the ports and the alignment of that burner and igniter. This information may help you determine the cause of your problem.
SOURCE: wfe301lvs oven will not heat. cooktop works, but
oven and broil is not heating at all. but stove works great.
