Question about Kenmore 62622 Electric Dryer
I have a Kenmore 66722 Dryer that will not start. I am thinking that it is a switch.
  • 3,230 Answers
Yes, first you can check Power from the house -
Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
Second thing to check is Door switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
Good Luck!!
Please do rate this solution.
Thanks
Posted on Jul 13, 2009
Kenmore 70 Series Dryer won't turn on. I don't think it is a door switch problem because when I hold down the door switch to make the dryer light turn off, the dryer still won't start. I...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 19, 2011 | Kenmore Dryers
Kenmore 600 series dryer.model # 110.67622600. wont start. light goes on & off when i push and release the door switch. when i push the starter switch it make a clicking buzzing sound. more noise when...
heatman101
Jun 27, 2011 | Kenmore 67632 Electric Dryer
After 500 kenmore dryer is done drying the dryer won't shut off
The push-start switch in the dryer is probably bad. The contacts inside the switch get warped over time, causing the dryer to think you pressed Start again after it finishes a cycle. Replacing that switch should solve your problem. You can find the switch online at PartSelect.com if you know take the rear panel off the dryer and see what the switch looks like.
http://www.partselect.com/PartSearchWizard.aspx?Appliance=Dryer&Brand=Kenmore&PartType=Switch
Nov 06, 2010 | Kenmore 500 6952 Dryer
Kenmore 66722 electric dryer - barely started one day then stopped working. When start button is pressed, ticking noise is coming from cycle selector. Opened the control panel and noticed that the plastic...
heatman101
Sep 18, 2010 | Dryers
My dryer Kenmore 66722 when replaced the heat element new one.It does get heat,but take longer to have a good dry for 1 load (90min).
check the vent ...clean and clear... also check how much air is blowing out...run with vent unhooked to check if it is vent problem
Sep 21, 2009 | Dryers
I think my dryer finally stoped
Inspect the start switch and the door pressure switch as well. if both switches check out OK, replace the timer/control device.
Jun 03, 2009 | Kenmore 700 6972 Dryer
Kenmore electronic sensor gas dryer thinks door is open
Hello linda, it sounds like the door switch is not working in the closed position, when you close the dryer door the door switch shut's the light off, it also allow's the dryer to run when the door is closed, if it's defective the dryer will not run, check the connections at the door switch, if the connecetor and wire's look ok your door switch will have to be replaced. Hope this help's.
Apr 02, 2009 | Kenmore Dryers
Kenmore 62622 Electric Dryer Logo
69 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
