Question about RIM BlackBerry? Curve 8330 Cellular Phone
All the buttons stopped working...
For no apparent reason all the buttons stopped working (can't dial numbers, etc.); the trackball will roll around but will not select an app?!?!
  • 541 Answers
This is because Keypad is not functioning,the solution is to go to your nearest service centre and repair your Keypad.The Service centre contact number and address will be provided by your service provider.
Posted on Jul 17, 2009
How do I change the speed dial keys that are already programmed?
  1. In the phone, press the Menu key.
  2. Click View Speed Dial List.
  3. Click a contact or phone number.
  4. Perform one of the following actions:
    • To change the contact that is assigned to a speed dial key, click Edit. Click a new contact.
    • To assign the contact to a different speed dial key, click Move. Roll the trackball to move the contact to the new speed dial key. Click the trackball.
    • To delete the contact from the speed dial list, click Delete.
Jul 07, 2014 | Mitel Superset 4015 Corded Phone
Of recent...my BlackBerry 8900 trackball randomly scrolls to the top of the screen. And once this starts it does it continually. Then a next time it stops and doesn't respond to any movements of the track...
Sounds like you might have something stuck in the trackball. I would roll a piece of tape so the sticky side is up and roll the ball around on the tape to try and get some of the dust and other things off of it.
Mar 08, 2011 | Computers & Internet
My trackball cannot sroll down . its stuckk ..
Hi
To unstick your trackball,you need some rubbing alcohol
Pour a few drops of rubbing alcohol directly on your trackball,you can use a dropper to do this.
Roll the trackball around continuously until it starts to work again
Jul 30, 2010 | Computers & Internet
The ball wont roll on my blackberry. Help!
The trackball is easily removed for cleaning by just pulling the trim ring around the trackball off with your fingernail. Remove the trackball and clean with alcohol. Reverse the process to clean.
Feb 06, 2010 | Blackberry Curve 8350i
Turn off the timer on an old imperial st george
I have this exact same oven and this "feature" annoys me no end. To turn it off ... turn the clock dial to PAST the time that the timer dial shows. EG: If your timer dial is showing 6, turn the clock dial so that it rolls past 6 o'clock. This will pop out the timer dial and thus turn off the timer, allowing you to use the oven normally.
To stop accidentally pushing/turning that timer dial, I removed the knobs. Good luck.
Jan 23, 2010 | Ovens
Cell phone blackberry trackball stopped working!
Use a alcohol swab and gently rub it over the trackball. Rub it and roll the ball.. Eventually this cleaned the ball and it worked perfectly!!!!
Dec 17, 2009 | AT&T BlackBerry Curve 8310 Cell Phone -...
Blackberry 8830 wont track down - trackball stuck
This is usually caused by the trackball getting dirty.
Use a q-tip dipped in IPA and clean it. Roll the trackball around and swab the q-tip around to clean.
If cleaning fails then you will need to replace the Blackberry trackball.
Check the following link on instructions on how to do that.
Blackberry 8800 Trackball Replacement Guide
Apr 16, 2009 | RIM BlackBerry ® 8830 Cellular Phone
My blackberry world rollerball moves but none of my buttons click
i would send it back to the manufacturer. apparently the trackball has a problem and it needs to get fixed. or u can go to a blackberry specialist and tweak the trackball so itll work better
Feb 08, 2009 | AT&T BlackBerry Curve 8310 Cell Phone -...
Fan coming on for no apparent reason
The pushbutton panel is most likely failing, part cost around $60.00 if you want to replace yourself. (It's not that difficult). I'm not sure why, but this type of pushbutton panel (referred to as membrane switches) have been experiencing a high failure rate over the past couple of years. Symptoms include buttons not working at all, intermittent beeping sounds, turning on by themselves etc.
If you need further assistance, let me know
Regards,
reg501
Jul 07, 2008 | Kenmore 63792 Microwave Oven
RIM BlackBerry? Curve 8330 Cellular Phone Logo
533 people viewed this question
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Longtime User
ismael castillo
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
