Question about Philips Magnavox 9P6034C 60" Rear Projection Television
I had cabinet damage with the 60in. tv . I found one that looked the same,I changed everything.It works but the front panel buttons are different, they go horizontal across the front as mine were like the one pictured up/dn rt/lft . the connector is different, if i had the pinout for the controls, i could wire it up,I hope, as it controls the power,channel,and ir remote. any help would be greatly appreciated. thanks! tvman66..
    Filmmaker:
    Uploaded 5 video answers.
  • 162 Answers
May not be the same ...just wire up the old one and leave it in the back of the Tv. Then use the remote for everything else.
Posted on Aug 09, 2009
Element 60in. backlight not working... Changed power inverter. What is next fix
Landy, Check the attached vids. instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Aug 03, 2016 | Element ELEFT405 40" LED TV 1920x1080, 60...
How do i fix my sharp tv picture frozen screen?
look for the freeze button on the remote and press it.
Aug 15, 2014 | Sharp 60in Aquos 1080p widescreen...
Can't turn down the volume on my tv
Hello
The fault is due to the microswitches on the front panel. Just replace all of them at the same time. These switches can be located just behind the front pane push buttons. To access it you have to open the TV, and take out the printed circuit board out.3_1_2012_2_49_48_pm.jpgPictures of two type of microswitches are given here. The shape may differ to tV to tv, but look this. may vary ins size and shape too.3_1_2012_2_50_23_pm.jpg
Feb 29, 2012 | Sylvania 6513DF 13" TV/DVD
I have a Maytag Electric Dryer when I press the start button its starts up with a rumbing noise then about 10 secs. later some kicks in or ignites. Could you please telll me what the problem could be. And...
the rumbling noise you hear is the drum starting to turn,, if you have a loose or damaged belt the noise could be higher in volume than normal,, the igniting is also a normal thing you can look here to see a little bit on how a belt is checked and changed with diagrams http://repair2000.com/wpoolbelt.htm to open a Maytag do this There are two spring catches located just below the cabinet top that secure it to the rest of the unit. These catches are located towards each side edge. Use a putty knife (or some other thin and flat object) to slide in under the cabinet top to disengage each of the clips. You can now lift up the cabinet top.
With the cabinet top lifted, you will see two screws located inside the top of the cabinet front. Remove each of these screws and lift the front panel to disengage the two clips found at the bottom. As you remove the front panel, disconnect the door switch and any other wiring, taking careful note of which wires are to be reconnected where.
Jun 14, 2011 | Dryers
How do I change the projection lamp for my sony kds 60A3000 60in tv?
remove the front panel below the tv screen. Look for a small door with a single screw. Remove the door and slide out the old bulb. Install the new bulb and reverse the steps!
Thank you and best of luck!~
May 27, 2011 | Televison & Video
Inisgnia LCD connect to dell laptop
Depending on what kind of laptop you have, your button may look different. Look at the Function keys (all those keys up at the top that have F's in front of them) and see if there is another colored symbol on any of them. You should find a colored symbol that looks like a rectangular monitor.
Press another key toward the bottom of your keyboard that probably says "Fn" or some other kind of "Function" key - not Alt, Ctrl, or Shift. Hold that Fn key down while you press the first key you found that looks like a monitor. That will change your laptop video output mode between several different modes like: laptop LCD panel only; LCD panel and external monitor; and external monitor only.
Apr 16, 2009 | Insignia 19 in. Widescreen Flat-Panel LCD...
Device stuck on bottom right icon. cannot change.
Good Day, hcolern2b;
Sound like your TV's front panel button assembly is bad, replace or disconnect and use remote only.
Good Luck, big IRISH.............PS disconnect from front by removing speaker grill and small black panel, follow wire harness.real close by.
Sep 07, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Green power light will not stop flashing and tv will not turn on or off
You need to replace the 1000uf capacitors on the DM board thats the classic symptom of the DM caps being bad the light continues to blink repeatedly. If you need more info on the repair let me know.
May 15, 2008 | Mitsubishi WS-55909 55" Rear Projection...
Television
How do you bring up the menu without the remote
Feb 24, 2008 | Televison & Video
Buttons won't work with different cabinet need pinout
What was the model number of the set that has the 7 pin keypad that you are needing the info on? Can you change out the front screen panels so you can use the origional controls for your chassis. If they are both 60 inch you may be able to switch out the front screen and control trims.
Jan 23, 2008 | Philips Magnavox 9P6034C 60" Rear...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
