Question about ASUS A8V-VM Motherboard
Wd1600aasd doesn't get recognized on my a8v motherboard.. i know it's an sata I but ppl tell me SATA II works.. plus the guy at the tech store knew it was a SATA I Board.. can this work or i have to return it
  • jeromeleblan Jul 13, 2009
    eum yes i tried that.. still no luck.. saying that it cannot detect it.. if i load it as a secondary drive yes it apears in my device manager.. but my hdd is shot.. takes 10 mins to load.. and if i unplug it the post usualy took time now it doesn't but it still does not detect it .. saying the bios is not installed
  • 202 Answers
Some via chipsets require the drives be jumpered to 150mbps, sata 2 is 300mbps. should work otherwise sata 2 is backwards compatible. read the paper on the drives they should have a jumper.
Posted on Jul 13, 2009
A8VE-SE won't recognize SATA HDD
If you are trying to install Windows XP then -
The problem is that XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
Jan 08, 2013 | VIA Asus A8v-e Se Socket 939 Pci-e K8t890...
Will not recognize sata drive need to know necessary connections
There are only two connectors on a SATA drive, namely POWER and DATA.
Check that both cables are securely connected.
Try the disk-drive in some other computer.
Nov 02, 2010 | Maxtor MaxLine Plus II 7Y250MO 250 GB SATA...
SATA HDD is not detceted properly
As far as I can remember, the VIA VT8237R southbridge used on this board has a bug, causing it not to recognize SATA II drives.
You may be able to configure your hard drive to use the slower SATA 150 mode (1.5 GBit/s or 150MB/s) by setting a jumper on the drive. Unfortunately, this is not supported by all models - check the jumper description on the drive.
If the drive doesn't offer this feature, you might consider adding a SATA controller like this one (you may be able to find better and cheaper controller cards at your local computer store).
Mar 22, 2010 | ASUS K8V-MX Motherboard
Gigabyte 945 gzm s2 doesn`t recognize HDD Western Digital 320 GB
You might need to change your bios settings from ide to sata. Have you already checked the bios settings? If everything is in order you might have a bad board. What have you tried so far?
Nov 20, 2009 | Gigabyte GA-945GZM-S2 Motherboard
Asrock Motherboard problems with SATA HDD
It is possible that you are trying to use a SATA II HDD in a system that supports SATA. SATA II devices are not backwards compatible usually,
Dec 20, 2008 | Asrock P4V88 (P4V88 RAID) Motherboard
My PC don't recognize HD Samsung Sata II 250gb
If you mean the drivers for your SATA harddisk, you should have gotten a CD with your motherboard that contains drivers they might be labeled as RAID, sata, or EIDE controller. when you click that it should prompt you for a floppy disk to put the drivers on, you need to put a floppy disk in drive A and then extract the RAID drivers to your floppy, when installing windows press F6 at the begining of the installation and it will act like it didn't work for a minute and then it will pop up asking you something, you press S and then you will be asked to insert your floppy disk. It might ask you if you want to install the x86 or x64 drivers, x86 is 32bit and x64 is 64 bit, if you don't know which you are using it should tell you somewhere on your windows disk. another option is to get a sata controller that isn't part of your motherboard, it would be a pci-e card and it would come with drivers. I don't know where you could download your drivers from because I think the driver you need is specific to the type of SATA controller your motherboard has in it, but I do know that seagate and western digital have sata drivers available as well for their harddrives so I don't know what to tell you. best shot is your motherboard driver CD.
Dec 18, 2008 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
PCI Card for SATA I VS SATA II
There are many PCI SATA controller cards out there. Just know that the SATA will not run at the SATA II standard. This is because you're motherboard may not support the bus speed for the SATA II or SATA I. If you current motherboard does not have a SATA port built on it, than your not going to see the speed the drive is able to run. Click this link (a Google search for PCI SATA II controller cards). http://www.google.com/search?hl=en&q=PCI+SATA+II+controller+cards&btnG=Search
Watch out for PCI-X. This is not the same as a PCI slot.
PCI-X slots are only found on motherboards that have SATA I & SATA II slots on them. These PCI-X slots are the smaller SATA slots found inbetween PCI-Express sloted boards.
Promise controller cards make some of the best controller cards on the market.
Mike
Jul 26, 2008 | Computers & Internet
Wd800jd sata hard drive not recognized in bios on boot up
Hi, A couple of ideas: 1. There are 3 versions of this motherboard: Dragon Plus, V1.0 & V2.0, perhaps your BIOS needs an update to be able to recognize the new HD. This of course would require flashing; 2. There are two variations of a WD SATA hard drive: Serial ATA amd Serial ATA II; 3. Re Jumper settings: the eight-pin jumper block is only used to enable power management on the drive. There are no master/slave settings since there is only one drive per cable; 4. If you are fresh installing Windows on it, you need to press F6 when asked by the Windows Installer and follow on-screen instructions. Hope this be of some help/idea. Post back how things turn up or should you need further information.
Sep 17, 2007 | Western Digital Caviar SE WD800JD SATA...
ASUS A8V-VM Motherboard Logo
100 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
