Question about Refrigerators
Defrost water leaking into lower section through cold air vent
  • 50 Answers
It sounds like, that the water drain hole or drain line is clogged. It could be clogged with food particles or ice. You'll have to thaw it out and clear the hole or line. Good luck.
Posted on Jul 13, 2009
After having defrosted our fridge and started it up, the freezer section gets cool but not cold enough for freezing and the lower fridge section remains lukewarm. This is whether operated on electrical or...
You need to check the temperature settings and see if there is enough air flow in the refrigerator and freezer. You need to check for air flow restrictions in the vents and clean the compressor coils. The door seals, door switch, defrost heater and timer has to be checked. Also clean the clogged drain tube and refrigerant leak.
Good luck in solving the problem.....
Jun 23, 2011 | Dometic RM2852 Refrigerator
GLRT216TAW2 Model Number. Water under vegetable drawers, No other water leaking. Back is dry, Do i need a repair man or new refrig which is only 10 yrs old.
Its the defrost problem.In your unit the defrost cycle is not running on time.This is the procedure of the unit.--- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold. The air from freezer to fridge passes from the section, in that section the damper is located.In your case the freezer gets cold, after that defrost cycle has to start, but in your case the defrost cycle is not starting on time so over ice gets internally build and when defrost cycle starts, this ice melts and this gets leaks in the vegetable and under vegetable drawer.-------- Get the defrost timer, and defrost assembly parts checked and repaired by the technician.Repairing will solve the problem.You can get required parts from from online sites like: --- www.repairclinic.com or from searspartsdirect online site. --------- This should help.Thanks.Helpmech.
May 04, 2011 | Frigidaire GLRT216TA Top Freezer...
My GE Adora side by side refrig. has stopped making ice and I am having a hard time regulating the settings on it. The freezer is too cold and the refrig. section isn't cold enough. I also have noticed...
Defroster circuit/timer has failed.
The water line to the icemaker has probably frozen,so no ice. The cooling coils are in the freezer, and the cold air moves to the fridge via vents and circulation fan.
When it all ices up, no air gets to fridge, fridge gets warm.
Many models have a mechanical defroster timer located under the lower front kick panel. Manually rotate the timer until you hear the compressor stop.
Defroster heater then should come on and you hear scorch/hiss/gurgle of defrost sounds. If the timer is working, the fridge should come back on after about a half hour or so.
Sometimes timer fails, sometimes heater element fails. There is also a defrost thermostat that's part of the heater assembly.
http://www.appliance411.com/faq/howdefrostworks.shtml
Oct 23, 2009 | GE Adora (DSF25KGTBG) Side by Side...
Refrigerated does not cool, freezer works
Most units have the cooling coils in the freezer section, then some vents and a fan circulates cold air into the refrigerator section.
If the vents are blocked by food items or ice, then the fridge will be too warm. Also, if the air circulation fan has failed, then cold air from the freezer will not get to the refrigerator.
On a self-defrosting refrigerator, this can be a sign that the defrost timer, defrost heater, or related part has failed. If the cooling coils are packed with ice, then airflow to the refrigerator does not occur.
Typically there is a electromechanical timer that you can see if you take off the lower front panel...this timer switch can be set so the defrost cycle happens when you want (like late at night).
You can also manually turn the switch to start the defrost cycle. Normally you hear the sound of water running and the scorch-hiss sound of an electric heater element touching water/ice when the defrost is taking place. The refrigerator compressor and cooling fan will typically be off during defrost as well.
Oct 21, 2009 | Refrigerators
Both top sections fridge/freezer of my side by side are not cold
Sounds like a defrost problem. Remove food from freezer section, take the back wall out after removing shelves, and use a hair blower to melt off the ice and frost. Most likely you need to replace the defrost heater.
Oct 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Side windows frost up bad in cold weather.
They sell a spray in auto store or walmart car section that you can spray on the window and it automatically defrosts it.
Aug 12, 2009 | 1994 Mazda MX-3
Freezer will not keep foods frozen fridge will not keeep temp.
Sounds like a main control board problem keeping the freezer fan from working . If no air flow to the top of the freezer , the icemaker will stop working and the ice will begin to melt ( leaking from freezer ) . The coils will start to freeze up due to no air flow across them . If continued for a period of time , the cold air could return thru the return vent located in the bottom of the ref/freezer section and freeze the water tank in the refrig section , causing the no water thru dispensor .
Jul 11, 2009 | Hotpoint HSS25GFP Side by Side...
1986 Mercedes 300e The air conditioner vents blow cold out of the center two and hot out of the two sides and the defroster vent. I tried to press the lower vents button and the high setting on the...
All the blend doors and vents are controlled by vauum. If you look in the rear firewall behind the brake master cylinder you will see a vacuum check valve with lines entering the cabin of the vehicle. The yellow colored ones are for your central locking,the green for a/c system, and red for your heater/water valve,clear for your source. Try isolating your vac. systems by unplugging lines and capping them off. Any leak in either system can adversly affect another system. So isolate your leak and then you will have to test your actuaters in the leaky system. If you unplug the red line and cap it off-the water will stop entering your heater core.
Jun 26, 2009 | 1994 Mercedes-Benz E-Class
Refrigerator condensation
I have a Kenmore Coldspot Model 70262990. When I get wet shelves (water, not just condensation), I was able to trace my source to the cold air vent from the freezer. In my case, the water melts from the evaporator and collects in the rear lower section of the freezer. It is "supposed" to go down the drain tube. However I had the drain hole freeze over. Then additional water from the defrost cycle would accumulate in the freezer floor (under the plastic floor) and eventually find its way down the cold air vent between the freezer and refrigerator section. You'll need to unplug the unit, take the plastic floor out of the freezer, remove the evaporator panel to access the defrost drain, melt the frozen water (hair drier works nice), and remove all the water (towel/sponge & bucket). Make sure the drain is not frozen and not blocked. Then put it back together and plug it in.
Does anyone know how to stop the drain tube from freezing over?
Good luck.
Mar 11, 2008 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
