Question about Dell UltraSharp 1907FP 19" LCD Monitor
Resolution wont resize properly
I have a 5:4 (19") dell monitor from a dell dimension 5500 and hooked it up to my dell dimension 4600 and it works but when I cange the resolution to 1280 by 1024 (only by the graphics program cause I can't change it through properties then settings) It looks good but my Icons wont fully go to the bootom where the taskbar is. And when I restart, the resolution changes back to 1024 by 768. Please help
    Problem Solver:
  • 5 Answers
Try resetting your monitor to the factory settings. If that doesnt work I suggest you unistall your monitor in device manager Only if you have the monitor cd. If you do not have a cd to your monitor you can always download on the internet. These two options should help you but if they dont go ahead and come back and repost your question.
Posted on Jul 15, 2009
Acer flat panel monitor with dell dimension 4600 desktop, i am having a resolution problem. Icons are blurry, or fuzzy. the computer does not have a DVI port to connect to the monitor. I have used only VGA...
the issue is most likely the resolution you set the panel to. also make sure you select a generic flat panel driver under the Display properties EXP: if your panel is a 17" Panel chosse 1a driver with a max resolution of 1024X768 @ 60hz to start and go on from there you will solve it.. let me know if you need more help.. Marcelo
Aug 06, 2011 | Dell Dimension 4600 PC Desktop
My monitor has gone to Power Save Mode
If your monitor is going in Power save mode it can be cause by following reasons.
>Check the data cable going from monitor to your Dell Dimension 4600 Tower is connected properly.The connector will be blue or white in colour.
>If the Dell Dimension 4600 Tower is powering on.
If still in power save mode then try to shutdown Tower and monitor,disconnect power cable from tower and monitor.Hold the power button on tower for 15 seconds.Then again try to connect monitor and check,if still nogo,and if tower has no lights then issue with motherboard or video card or power supply.If possible try connect spare known good monitor.
Thankyou
Sep 09, 2010 | Dell Dimension 4600 PC Desktop
Will an Acer AL1716 monitor work with a Dell 4600? Do I need a monitor card?
http://reviews.cnet.com/desktops/dell-dimension-4600-for/1707-3118_7-30529709.html
It has video card already, just make sure the video card driver is correct. Mkae sure to set the PC video resolution to the native resolution of this Acer, which is 1280 x 1024 @60Hz.
http://s807.photobucket.com/home/budm/allalbums
May 10, 2010 | Acer AL1716 17" LCD Monitor
Axle Nvidia GeForce FX 5500-8x Pci No Red Color
don't panic just check for the rgb color files if they are in your monitor's cd
or in driver's cd or in ur graphics card driver cd or you may download it from the websites of your brand.
Mar 21, 2010 | Computers & Internet
Extended Desktop on Dell Dimensions 4600
yes your right..leave it set to AUTO BUT ONLY USE THE ATI CHIP SET VIDEO CARDS.
Dell Dimension 4600 We saw great image quality from the 17-inch E171FP analog LCD monitor that accompanied our review system. Text looked sharp and evenly focused at all sizes, while colors appeared lifelike, with evenly saturated tones in our photo test screen, in a DVD movie, and during a session of Return to Castle Wolfenstein. As part of a new case design for Dell's midrange Dimension line, the 4600 has eight USB 2.0 ports, more than on most value (and some power) systems: six on the back and two up front. An audio port for connecting headphones sits next to the front USB ports.
The compact 4600 does not have the tool-less accessibility of its predecessor, the Dimension 4500, although opening the case is easy: Just depress a thick L-shaped lever and lift off the side panel. You'll need a screwdriver to add a PCI card or a hard drive; unlike the 4500 series, which secured expansion cards and drives with innovative quick-release mechanisms, the 4600 series uses screws. Our test configuration had only one available drive bay (a vertically mounted internal bay), and it's a struggle to use it. You must remove four screws (two on the bottom of the case and two inside) and take out the bay holding the existing hard drive along with the empty bay that's crammed up against the front of the case. The two open PCI slots are reasonably easy to access, but to reach the two open memory sockets, you must push aside a snarl of data and power cables.
The Dimension 4600 we tested came with a 2.8-GHz Pentium 4 processor and 512MB of DDR400 memory. It earned a PC WorldBench 4 score of 122, about average for similarly configured systems. The ATI Radeon 9000 Pro graphics card is not a top-of-the-line board, but it yielded solid frame rates in our gaming tests. And it's perfectly fine for playing games at moderate resolution, especially considering that the bundled LCD monitor won't display anything higher than 1280-by-1024 resolution. It has a combination DVI/analog-out port (you use an adapter to hook up an analog monitor), plus S-Video-out and composite-out ports to output video to a TV.
Please leave comment and feeb back.
Thanks
Feb 24, 2010 | Dell Dimension 4600 PC Desktop
Geforce 6200 / dell dimension 4600 resolution problem
if this is a relacement for an old card 1st make sure the old drivers are ubisnatlled and the goto www.nvidia.co.uk and install the latest wqhl drivers and that should remidy it you may also need to reset you monitor settings
Feb 02, 2010 | XFX GeForce 6200 Graphic Card
Cannot install 17 inch monitor on dell dimension 4600
You have not installed your graphics card drivers! ----------
The drivers are here ---> Since I dont know which graphics card you have you will have to try each one... dont worry if the driver dosent find your card it wont install.
Do you know the full model number of your system , it is printed next to the serial number if you give me this number I can link you directly to the driver -----------
Jan 24, 2010 | Dell Dimension 4600 PC Desktop
My Dell Dimension 4600 monitor has gone completely black though it shows it booting.
Start your computer in "Safe Mode".
Change the screen-resolution to 800 by 600 at 60 Hertz.
Shutdown, and restart.
If you eventually see your "wallpaper", try setting your screen-resolution to 1024 by 768, and "test" it. If OK, try setting your screen-resolution to 1280 by 1024, and 'test" it.
Jan 07, 2010 | Dell Dimension 4600 PC Desktop
No sound with new Vizio 22" LCD TV being used as monitor
you have to hook up the 1/4 headphone jack plug to the TV, from the computer. an Y audio cable with RCA plug (male) with headphone 1/4 male plug. hook the headphone jack to the green hole of the computer(sound out) to the audio input of the TV better yet to a stereo AUX port. also make sure the mute button hasnt been pressed.
Jun 03, 2008 | Dell Dimension 4600 PC Desktop
Dell Dimension 4600
when the screen goes away try to wigle the cable from the computer to the monitor see if it could be that
Dec 27, 2007 | Dell Dimension 4600 PC Desktop
Dell UltraSharp 1907FP 19" LCD Monitor Logo
144 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
