I have an ariston AVXXL105 and when I turn the machine on, all the leds are on and they won't turn off and, no matter what button I push, nothing happens
  • 25 Answers
Replace carbon brushes on motor
Posted on Jul 13, 2009
My Fisher & Paykel 708 smart drive washing machine won't starts and beeps.
That is Error code 9
9.
(00001001) Phase 1 to 5 - Size Error
Phase 4 to 5
The Display size switch setting does not match that stored in memory.
Action - Reselect the size of Smartdrive by using the SIZE SETTING MODE. Push and hold
the water temp up button, then press the power button to enter SIZE SETTING MODE. Three
LEDs are used to identify size. The cold water temperature LED identifies 5kg. The low water
level LED identifies 6kg. The hold spin speed LED identifies 7kg. If the product has not been
setup before all 3 LEDs will be on. To set the size for 5kg push the wash temp up button then
the power button. To set the size for 6kg push the water level up button then the power button.
To set the size for 7kg push the spin speed up button then the power button. This locks the size
into memory. To check the size is set, start a cycle.
Dec 20, 2012 | Fisher and Paykel Washing Machines
I can't stop the dryer from coming on Ariston AL128D, I just want to wash
Hi there, the F button on your washing machine (see manual http://www.gebruikershandleiding.com/Hotpoint-Ariston-al-128-d-margherita/preview-handleiding-431405.html?page=0004) is the clue. if pushed in it won't dry. don't know why, but by trial and error this seems to work
Sep 12, 2012 | Ariston Technologies AL128D Margherita...
F & P MW511 Washing Machine ... Driving me Mad ... Please Help!
Size setting
The low water level LED identifies 6kg.
If the product has not been setup before all 3 LEDs will be on.
the power button.
This locks the size
Aug 16, 2012 | Fisher and Paykel Fisher & Paykel Washer
My fisher and paykel top loading q washing machine won't start. It beeps and lights 5 and 8 come on. Any ideas what the issue might be?
That is fault code 9 machine not sized
9. (00001000) Size Switch Error
The Display size switch setting does not match that which is stored in memory.
Action GW Machines: Reselect the size of the machine by using the SIZE SETTING
MODE.
To set the size switch, turn the power on at the power point and off at
the console. Press and hold Wash Temperature Setting Up then
press Power. SmartDrive will give 4 short beeps and the pattern of
LEDs will change.
One of the following buttons needs to be pushed to lock the size into
memory.
• Press Wash Temperature Setting Up, the Cold LED is on for 5.5kg
(560mm wide).
• Press Water Level Up, the Low Water LED is on for 6.5kg / 7.0kg
(600mm wide).
517790C
35
• Press Spin Speed Up, the Spin Hold LED is on for 7.5 / 8.0kg
(650mm wide).
• Press Power to confirm the setting and also exit this mode.
Action IW Machines: To access Size Setting Mode, push and hold the Fabric Care button
and then press the Power button to enter Size Setting mode. Select
the correct size on the display by pushing the Adjust button to
highlight the correct size. Size setting is then achieved by pressing
the Power button. Powering off will set the size into the memory.
Note: Fault code 9 will only be logged into the memory of IW machines. GW and MW
machines can display this fault but it will not be recorded.
Aug 13, 2012 | Fisher and Paykel Washing Machines
Ariston a1600wd wont turn on
Before you change fuses, do you have an internal fuse board or RCD system in your home? Sometimes, an individual RCD can trip out, locking off sockets. Some sockets are individually set up for up and downstairs in a house, or different rooms. If you have a board or RCDs, check them out :)
Nov 18, 2017 | Ariston Technologies Washing Machines
We pulled our stacked washer out from the wall to service the cold water hose filter on the back of the unit. when we pushed it back into it's location the washer won't start, won't fill...
I know you don't want to hear this, but either you did something to the hose filter or you didn't get it plugged back in correctly.
If you banged the water inlet valve in moving it back, it might be damaged.
Suggest you unplug everything and start over.
Sep 04, 2011 | Frigidaire FEX831F Top Load Stacked Washer...
Ariston AWD 121 wont work
make sure the water supply is turned on , a small red and blue tap usually under the sink
Nov 11, 2009 | Ariston Technologies AWD 121
Ariston AML125 won´t spin or empty water.
Dislodge the white covering infront (just located at the bottom). Once opened, unscrew the black button at the right hand side. Once open, check for blockages like coins, loose items, even lint. This worked for me and saved me $$$!!!! Now my Ariston is back to its superb performance. Do read the manula once in a while, it does help!
Dec 02, 2008 | Ariston Technologies AW125NA 13 lbs. Load...
Washing Machines Logo
296 people viewed this question
Top Washing Machines Experts
