Question about Initial IDM-1731 Portable DVD Player with Screen
Does not power on
I've tried to turn on the portable dvd and it will not power you have any ideas what could be the problem
    Problem Solver:
  • 6 Answers
You have a couple things to check first off.
1. Using a VOM, measure the output voltage of the Wall Charger power cord. You should measure 9VDC +/-10%.
2. If voltage is present, then ensure that the pin located in the center of the female jack on the DVD Player is not loose by using the end of a Click-able ball point pen.
3. If the pin is secure, attempt to plug the jack in and move it slowly and slightly in a circular motion and see if the LED on the front of the unit comes on at any point.
4. If you have a battery pack that plugs into the side power jack of the unit, measure that voltage as well and make sure that it matches what's listed on the battery pack. If you have the battery pack that latches onto the back side and connects via the plate connectors, then you will need to use something very thin and metallic to measure the output and ensure that the voltage is accurate for that battery.
5. If all the voltages are accurate and present, then you most possibly have a broken solder connection within the unit or a defective DC input jack.
Posted on Dec 30, 2007
Wiggle the power cord near the power jack, and see if the unit will power on, power jack on my unit was loose.
Posted on Nov 30, 2007
I have a sony DVP-FX74 portable dvd player that won't turn on. I have charged the battery. Any ideas?
the power system has been interfered with,i won't use a complicated language but i need you to try and use an adapter,if it doesn't work it means the transformer has a problem or it has failed completely and it needs replacement
Oct 25, 2012 | Sony Dvp-Fx740dtb Portable Dvd Player Sony
Danby portable air conditioner won't turn on - brand new!
Obviously it is problematic machine from the factory so it will suggest a replacement.
Apr 12, 2012 | Danby DPAC12010H Portable Air Conditioner
Im using a behringer ucg102 guitar/usb interface, im getting a very bad hum/hiss.. i've tried 3 different guitars and multiple jacks. im not running any guitar effects yet, i've removed the...
Try this using a differeent computer. Some computers generate a lot of digital noise. Also use a lot of gain from the guitar to improve the signal to noise ratio.
Jul 23, 2011 | Behringer energyXT2.5 Plus Portable...
GPX portable DVD model PD808B - wrong region message
Turn on power. Open lid. Enter 9735 with the remote and press 'enter', you can now choose between regions on the screen. Select the desired region unlock and press 'enter'. This works well!
Benony Jonsson
Feb 20, 2009 | GPX PD808B Portable DVD Player with Screen
Dvd player
Go to radio shack maybe they got the cable you need to connect it,its a 3.5 mm to standard rca´s.Good luck
Aug 19, 2008 | Sharper Image SI655SIL Portable DVD Player
Did I get you right, 200 pcs of brand new Protron PDV700 DVD Portable Player?
In any case, chances are the problem is the switching 5V regulator which supplies the logic circuitry or any part of the circuitry of the power supply.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 11, 2008 | Protron PDV-700
Dvd problem
I had this once you should get dvd cleaner dvd lens cleaner
Dec 04, 2007 | Durabrand DUR7 Portable DVD Player
Initial IDM-1731 Portable DVD Player with Screen Logo
151 people viewed this question
Top Initial Televison & Video Experts
Are you an Initial Televison and Video Expert? Answer questions, earn points and help others
