Question about Maytag Neptune FAV6800AW Top Load Washer
Fuse keeps blowing out in my maytag washing machine
The fuse keeps blowing in my maytag top load washing machine model LAT8435AAE. It blew the first time from a power surge. I replaced the fuse and when I went to turn it on it blew right away. So I put another fuse in and it did the same thing. Can you tell me what keeps blowing out the fuse.
  • 164 Answers
Re: fuse keeps blowing out in my maytag washing machine
The power surge probably shorted out something in the main wire harness or fried your motor. remove the screws from the control panel and look for any wires that are discolored, charred or disconnected. in the event you do't find it there trace the wiring thru the cabinet looking for the same thing. if you don't find that, replace the motor
Posted on Nov 17, 2007
  • 77 Answers
Replace the complete lid switch ***'y. be sure to adjust properly.
Posted on Dec 03, 2008
0 characters
3 Points
Washing machine keeps tripping electric when the door locks
Washing machine tripping or fusing electrics > ... > DIY Washing Machine Repair Help
Jun 26, 2013 - A Washing machine tripping or fusing electrics is a fault you can't really deal with unless ... If washer has tripped the RCD or fused the plug but now won't work properly. ... Here's an article on Washing Machine Door Will Not Open ... If youkeep resetting it without fixing the cause of the tripping it can blow ...
6 common washing machine problems and how to solve them
Feb 10, 2014 - As mentioned earlier, front loader doors lock during the cycle to prevent the water from ... The washing machine keeps tripping the power!
Maytag ,Whirlpool Washer Diagnostic - Breaker tripped and ...
? 7:00
Jun 13, 2013 - Uploaded by
Yeah, keep it ... Maytag ,Whirlpool Washer Diagnostic - Breaker tripped and will not always run - .... TROUBLESHOOTING Top Loading Washing Machines in ... Maytag Neptune Door Locked but No Spin - R11 is not burnt ...
Washing Machine keeps tripping the electrics -
Dec 29, 2015 | Washing Machines
its in the lid switch safety assembly,there is a glass cartridge fuse on this board and if the lid switch sticks it will blow this fuse to power down the machine to protect the uses from it spinning with the lid open this board is available from most maytag dealers or appliance parts dealers
Dec 11, 2012 | Maytag LAT2600A Top Load Washer
I own a maytag atlantis top load washer model LAT4914AAE and the fuse located behind the knob controls blows when ever i go to wash a load
The reason the fuse keeps blowing is because one of the two switches their where the fuse is is bad and drawing to much amperage so the fuse blows. THe lid switch/fuse asm comes together and it should be replaced.
The part number for that switch assambly is 22001682 it could be purchased at your local appliance parts store or online at;
Sep 23, 2011 | Washing Machines
Maytag dependable care LAT8435AAE fills with water then quit. Has power but will not start in any cycle
You need a new timer. It's an easy repair ...
Jul 19, 2011 | Maytag Dependable Clean Top MAV5920EWW Top...
For the past few years the small fuse in the washing machine blew about once a year. A few months ago it seemed to blow every week. Then it was fine again. Now I replace the fuse and as soon as I turn on...
One says the lid switchs are not working in tandem with each other. Another says the circuit board is bad. I say it is because it is a Maytag and built with an obsolete ethical plan for generating profit.
Dec 29, 2009 | Maytag LSE7806A Top Load Stacked...
My washer continually blows a fuse
If your machine is the Maytag stacked washer/dryer combo, there are a couple of areas I would look at. The first is the lid switch assembly. The fuse is a safety device designed to blow if the lid switch malfunctions. The two lid switches interact and if they don't both switch at the same time it can blow the fuse.
The second thing to try is to wash a load on cold water only and see if the fuse blows. See if there is a water supply issue. Check the water inlet valve. Remove the water supply hoses and check the small screens in the water inlet valve. Make sure they are clean and clear of rust or debris. Use a mulitmeter or ohmmeter to check the solenoids for continuity. A lack of continuity would indicate a faulty solenoid and the water inlet valve assembly will need replaced. These are a couple of things to consider. Hope this helped and best wishes.
Aug 15, 2009 | Maytag LSE7806A Top Load Stacked...
Maytag washer blows 1.5A fuse in back of the top compartment where the dial etc is
There is a micro switch next to the fuse. It is shorted out. Replace the micro switch and solve your problem.
May 20, 2009 | Maytag SAV571EEWW Washer
Fuse blew on my Maytag washing machine. 1 amp only and others blow. Time to buy new or service? can buy the switch assembly unit. it gets short and the fuse blows out.
May 04, 2009 | Washing Machines
Fuse blowing on model #lat8440oaa w
a short in a wire somewhere grounding causing fuse to blow
Feb 26, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Washer was in fill cycle and stopped
You've got a short circuit somewhere in that electrical circuit.
First, unplug the washing machine.
Replace the fuse. If it doesn't blow immediately, then there is likely a short in the washing machine, and from what you describe, it's in the motor.
If it blows, then there is something wrong in that circuit, and you can likely rule out the washing machine. Check all devices on that particular circuit, of which there can be a number of plugs.
Jan 23, 2009 | Maytag LAT3600A Top Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
1,177 people viewed this question
Top Maytag Washing Machines Experts
Richard Roth
Richard Roth
Al Clark
Todd Marr
Todd Marr
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
