Question about Canon LaserClass 2050 Plain Paper Fax
Ordered a Contact sensor unit HH7-2424-000 but it has a different connector than the one that came out of the machine.
    President:
  • 1,126 Answers
Is it possible that you have an LC 2050P instead of an LC 2050?? HH7-2424-000 contact sensor belongs to both 2050 / 2060 LC fax machines, however, HH7-2520-000 belongs to an LC 2050P fax machine. Perhaps that is the difference, or am I missing an update? Let me know which model you have please.
Posted on Aug 09, 2009
Dish washer is broke, your agent came to repair. Ordered parts. Never saw the sears guy again. Now your agents say the washer is not under repair. I have paid for warrenty
Contact sears customer service with your warranty info to resolve this issue. If unit is no longer under warranty then that is a different story. Check youir manual for warranty details.
Sep 01, 2017 | Sears Washing Machines
New Door Lock - Machine does nothing
make sure the wireings in right order
Apr 30, 2015 | Hotpoint Washing Machines
2005 range rover
DTC P2A00: Oxygen Sensor Circuit Range/ Performance (Bank 1, Sensor 1)
Probable cause:
  1. Sensor or solenoid faulty
  2. Connector terminal contact damaged/corroded
  3. Wire harness fault. Check for correct voltage, open, short to ground or short to voltage
  4. Control unit software needs to be updated
  5. PCM or ECM faulty
  6. HO2S sensor contaminated/damaged
May 18, 2017 | 2005 Land Rover Range Rover
You can change the connectors on the wiring loom there are only two wires per valve
this video might help
Jul 22, 2013 | Whirlpool duet Washing Machines
Westinghouse LF708C fault code SE. not spinning. what needs to be fixed?
SE refers to a sensor error, remedies include checking all connections plugs: § The connector (5pin, male, white) in the Wire Harness is not connected to the connector (5 pin, female) of Hall Sensor in the MOTOR. ?_? reconnect or repair the contact in the connector The electric contact between the connectors (5 pin, male in the Wire Harness and 5 pin female in the Hall Sensor) is bad or unstable. ?_ Reconnect or repair the contact in the connector ? The connector (6 pin, male, natural) in the Wire Harness is not connected to the connector (6 pin, female, natural) of PWB ASSY(Main) or the electric contact of connectors is bad/unstable. ?_ Reconnect or repair the contact in the connector ? The electric contact between the connectors ¡a6 pin, male in the Wire Harness and 6 pin female in the controller(Main)¡bis bad or unstable. ?_ Reconnect or repair the contact in the connector ? The Wire Harness between Hall Sensor in the MOTOR and PWB ASSY(Main) is cut(open circuited). ?_ Repair/replace the damaged WIRE HARNESS ? The Hall Sensor is out of order/defective. ?_ Replace the Motor ? The controller(Main) is out of order/defective. ?_ Replace the PWB ASSY(Main)
Jan 22, 2010 | Westinghouse Washing Machines
Codigo C7760 de una Kyocera kilometros 1635
C7410 C7800 C7810 C8010 C8030 Drum unit connector insertion problem • Absence of the drum unit is detected continuously for 1500 ms while there is no error on the copier. Broken external temperature thermistor wire • The input voltage is above 4.5 V. Short-circuited external temperature thermistor • The input voltage is below 0.5 V. Finisher* paper conveying motor problem • The paper conveying motor lockup signal is detected for 0.5 s or longer. Finisher* paper conveying belt problem • An on-to-off or off-to-on state change of the paper conveying belt home position sensor is not detected within 2 s of the paper conveying belt clutch turning on. Drum unit connector inserted incorrectly. Defective drum unit connector. Poor contact in the humidity sensor PCB connector terminals. Defective external temperature thermistor. Poor contact in the humidity sensor PCB connector terminals. Defective external temperature thermistor. Poor contact in the paper conveying motor connector terminals. The paper conveying motor malfunctions. Defective finisher main PCB. The paper conveying belt is out of phase. The paper conveying belt clutch malfunctions. The paper conveying belt home position sensor malfunctions. The paper conveying belt home position sensor connector makes poor contact. The internal tray is incorrectly inserted. Reinsert the drum unit connector if necessary. Replace the drum unit. Reinsert the connector. Also check for continuity within the connector cable. If none, remedy or replace the cable. Replace the humidity sensor PCB. Reinsert the connector. Also check for continuity within the connector cable. If none, remedy or replace the cable. Replace the humidity sensor PCB. Reinsert the connector. Also check for continuity within the connector cable. If none, remedy or replace the cable. Replace the paper conveying motor and check for correct operation. Replace the finisher main PCB and check for correct operation. Adjust the paper conveying belt so that it is in phase and check for correct operation. Replace the paper conveying belt clutch and check for correct operation. Replace the paper conveying belt home position sensor and check for correct operation. Reinsert the connector. Also check for continuity within the connector cable. If none, remedy or replace the cable. Check whether
Jan 19, 2010 | Office Equipment & Supplies
Hi Hat pedal not fuctioning
Obviously the hi hat trigger does not function properly, it either does not generate enough signal, or the signal doesn't come thru well, or the signal comes thru well but it doesn't trigger the sound unit properly.
This could be caused by:
- too low input sensitivity setting on the sound unit for the hi hat input
- a displaced or loosely fixed sensor (trigger) on the hi hat
- a partially damaged sensor
- a bad wire connection at the sensor
- a bad wire connection at the sensor connector
- a dirty contact on the sensor connector
- a dirty contact on the cable connector at either side of the cable
- a bad cable, a broken wire or poorly soldered wire in the cable connector at either side of the cable
- a dirty contact on the input connector of the sound unit
- a bad solder connection on the input connector of the sound unit (inside the unit)
- a bad solder contact on a component or a faulty component associated to that particular input in the sound unit (capacitors, resistors, diodes, transistors, ICs, etc.)
To rule out a damaged cable, just change it and see if the hi hat works ok with another cable, if it does, the cable was damaged.
If the sensors are interchangeable , try to swap the sensor with a sensor from another cymbal, see if the other sensor works well, if it doesn't, then the sensors are not the problem.
To see if there is a problem with the input on the sound unit, connect another cymbal to that input, if it works well, the input is not the problem, if it still doesn't work, check sensitivity/trigger level setting, check connector contacts for any dirt, check connector and component solder contacts inside the unit.
Also, try to connect the hi hat to another input on the sound unit, if it doesn't work well after that, there's a problem with your hi hat (sensor, wires, dirty connector on the sensor), if it works well instead, then there's a problem with the hi hat input on the sound unit (sensitivity/trigger level, dirty connector contacts, bad solder contacts, damaged components)
Another thing: try your hi hat connected as is, but have someone move the cable connectors while you play it.
If moving the cable connector at the sensor side results in a change of operation (it might start working well for an instant or so), you definitely have a problem with that connection (check for bad wires in sensor connector, cable connector and for dirt on both connectors' pins).
If moving the cable connector at the sound unit input side results in a change of operation, then there's a problem with that connection (check for bad solder points on the input connector inside the sound unit, check for bad wires in cable connector, check for dirt on both connectors' pins).
I hope you can fix it, otherwise just post me some feedback if anything seems unclear, i'll be glad to assist you.
regards
3rq8 (Triarcuate)
Aug 04, 2009 | Yamaha Dtxpress Iv Special Electronic Drum...
Washer will not spin LG Washer WM1832CW
1. Open back of the washing machine and control panel. Locate two wire harness coming out of main motor and main board. Check the wires for any cuts and harnesses for any corrosion. Fix the cuts and sand the corrosion to fix the issue.
2. Check the windings on the motor by pulling 3-wire connector from main board. Check resistance between each of 3 pairs using multi meter. The resistance should be 8-15 ohms. If one or more pair has no resistance reading then the winding is burned. Replace the rotor winding.
Rotor windings can be ordered from here: http://www.repairclinic.com/SSPartDetail.aspx?s=t-wm1832cw-%3d%3di1266809&PartID=1266809
3. If windings are fine then the hall sensor or speed sensor or motor sensor or sensor assembly needs to be replaced. The hall sensor sits on the inside of the rotor winding. Hall sensor has 4 wire connector attached. To remove the hall sensor: Open the outrunner or magnetic rotor from the motor first. Remove a big bolt at the center of the motor by holding the magnetic rotor. Once bolt is removed, the magnetic rotor can be removed by simply pulling it straight out. You may have to wiggle it a bit. Now remove a screw holding a wire going to hall sensor towrds bottom left of the winding. Now remove six inside bolts holding rotor windings to the drum body. The rotor windings are heavy so be careful while removing the bolts. Remove two wire connectors from the rotor windings and pull out the windings. Lay the rotor windings flat facing connector side up. Remove the hall sensor by praying out tabs.
Hall sensor can be ordered from here: http://www.repairclinic.com/SSPartDetail.aspx?s=t-wm1832cw-%3d%3di1268238&PartID=1268238
Jul 14, 2009 | Washing Machines
Kenmore HE5 error code F28 on spin cycle
F28 is a serial bus error from the CCU (Central Control Unit) to the MCU (Motor Control Unit).
All you need is some Electronics contact cleaner spray and a 1/4 inch socket to remove the top of the machine and the back of the machine.
The CCU is the computer looking box at the top front right hand corner.
Find connector M13, (has red marking on it and only 3 wires) disconnect it by pushing the retainer tab back and pulling gently on the connector.
Spray the contacts of the connector and computer with connector cleaner.
Then re-assemble connector.
The MCU is in the back lower left corner.
Find the connector with 3 wires and red mark, and remove this connector in the same way you did the other, spray it and re-install.
Put the back and top back on.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 25, 2009 | Kenmore Elite 45986 Front Load Washer
Samsung HLM507W Blink Lights
beings the connectors were different on the new bulb the spark gap maybe different also if it is the lamp wont work in that unit
Apr 12, 2008 | Televison & Video
Canon LaserClass 2050 Plain Paper Fax Logo
90 people viewed this question
old marine
old marine
