Question about IBM Computers & Internet
LCD Display problem
My Lenovo 3000 N100 lcd screen works fine when plug into an external monitor and seems to work fine when the screen is set at a certain angle when opened. The problem occurs when I push the screen back too far beyond a certain angle. What I see on the screen is that it starts to just become a stable completely white color screen. AND when I adjust the screen back towards the keyboard, the display comes back to normal.
I search the internet and got an idea that it may be that the lcd flex cable might have been loosened from the motherboard. Is this right or is it something else.
Thank you in advance for your help.
  • cavalier197 Jul 14, 2009
    Thank you Geekman.
    I reseated the connector and it seems to have resolved the issue.
  • IBM Master
  • 32,281 Answers
From your description it sound like you have a faulty video cable or the video connector on the motherboard is loose.
Reseat the connector and it may solve your problem.
Posted on Jul 14, 2009
No display on booting but from sound it is evident that win xp is booting & running. No display in external monitor also
If only problem is the lcd screen, if you are sure, just buy a new inverter for lcd and install it, forums like these and some sites on net explain how it is to be done
Mar 28, 2014 | Lenovo 3000 N100 0768 - Pentium Dual Core...
External Acer AL1917 stopped to work with Lenovo 3000 n100 as an external monitor.
No signal means you have a different input enabled somewhere...like TV/HDMI/VGA ...you are set on some input other than the one you need for your cable. Check the menu settings, if you have a remote, try the input button and try a different setting
Jul 09, 2017 | Acer AL1917 19 inch LCD Monitor
When i turn on my computer its screen works fine, after some time it fades away shows lining pattern on my screen and when i touch the screen it comes to its original form,,, anybody having any information...
If you touch the screen and it comes back to normal this proves the LCD panel display is defective, only option replacement. Go to www.ebay.com Type: make and model of laptop and refine search to screen. Plus! hook a spare monitor to the video output to make sure there is no problem with the video graphics card.
May 01, 2012 | Lenovo 3000 N100 0689 Notebook
Lenovo 3000 n200 0769AMU press power on switch green light on after about 1 sec screen still black no HD light fan running
Welcome to Fixya
Try to drain the electrostatic charge of the motherboard that usually cause this issue. I wrote a tip on how to do the power drain. Try to plug in external monitor on the VGA port and see if you are getting display using external monitor. If you are getting display using external monitor then the problem would be the laptop LCD. If you are getting the same black screen using external monitor then the problem is already the motherboard.
Thank you for using Fixya!
Mar 19, 2011 | Lenovo 3000 N200 0769 Intel Celeron 530...
Lenovo 3000 n100 lcd display works but only less than a minute before display goes black. Connect an external monitor and it works fine.
possible problem is your led light on your LCD or its Flex. you might need to have it replaced. Try to check your LCD when it turns black under the light if you can see a dark image of your desktop. If you can see your desktop then the backlight has a problem. If there is no display, your LCD needs to be replaced.
Aug 13, 2010 | Lenovo 3000 N100 0768 - Pentium Dual Core...
I got black screen a few seconds after reboot my LENOVO 3000 N100, type 0689 - 2BS, Laptop run normally without screen light, I need to flash screen in order to read it. I tried unplugging the battery and...
Hi. I think the LCD screen of your laptop needs a replacement because I think the backlight on that LCD is already busted thats why you need to point a flashlight or some sort of light just to see the display. Powerdraining your computer wont work because this already a hardware issue with the LCD, that's why when you switch display with your monitor it works fine. I would suggest replacing the LCD of that laptop or try calling Lenovo tech support if your laptop still under warranty so that they would replace it for free. This is no. to contact for your Lenovo laptop US/Canada 1-800-426-7378, Australia 1-300-880-917. Hope this Helps
Feb 28, 2010 | Lenovo 3000 N100 Notebook
My notebook screen 3000 n100 goes dark after few second
This could be a faulty CCFL lamp.
To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Jul 15, 2009 | Lenovo 3000 N100 0689 Notebook
Lenovo 3000 n100 notebook display problem
Appears the backlight for the LCD display has stopped working. This usually needs to be replaced by a professional unless you are electronically and mechanically savy.
Jul 10, 2009 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Screen goes dark after a few seconds
try fn+f7 that Toggle external monitor,and disconect external monitor before starting
Jun 13, 2009 | Lenovo 3000 N100 0689 Notebook
Lenovo 3000 N100 Screen Problem
First, plug a external monitor and toggle the screen to discard configuration or software problems. If the image displays correctly you have a problem either in the LCD screen or its connection cable.
Open the bezel and check for loose or damaged connection cable. Look specially next to the hinge, ON THE LEFT.
In case the problem is not the cable you might have to get a new LCD. You can have replacement parts and instructions here:
http://www.piezas.biz/epages/wwwpiezasbiz.sf/en_GB/?ViewObjectID=56222
Jun 29, 2008 | Lenovo 3000 N100 0689 Notebook
Computers & Internet Logo
180 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
