Question about Brand Remote Start/keyless/car Alarm Very Sleek
How do i fix remote start that start but not continue running run only for less than one minute . and shot off
    Top Expert:
  • Spy Master
  • 7,678 Answers
Hello
u will find a lot of wiring diagrams, codes etc and circuit diagrams help books and stuff like this at online places.. like reliable-store
for free
the girl in the chat box can help u instantly... im a frequent buyer there since Im a mechanic so take help from there
Posted on Jan 24, 2019
SOURCE:
My craftsman gasoline lawnmower will start when primed run less than a minute then cut out . how do I determine the problem...then fix it
Have you checked the fuel supply first. Its possible your jet valve may be plugged or dirt in the fuel bowl. One quick way of checking this is take the spark plug out and put a little shot of gas in the spark plug hole then reinstall the spark plug and put wire back in place and try to start engine. If it start and revs up for a few seconds till the gas is burnt up then stalls it is pretty certain its a dirty fuel jet or dirt in the fuel bowl. This quite often a real cheap fix .
Jul 20, 2015 | Craftsman Garden
Enigine cranks and turns off after a min and trys to crank again
You did not mention the year/make /model of the vehicle but, your issue may be related to the tachometer setting or the immobilizer. One way to test is to remote start the vehicle with the key in or near the ignition and see if it still turns off after a minute. If the vehicles remains running with the key in or near the ignition, your issue is with the immobilizer bypass. If the vehicle continues to turn off after one minute, the issue may be with the tachometer setting. Here is a possible solution: remote start the vehicle with the remote. When the parking lights come on, turn the vehicle off WITH the remote. This is the virtual tach setting. Test this setting and see if the issue continues. If not, you may need to adjust the tachometer threshold jumper at the module. There are two jumpers at the module, side by side. The other is for parking lights. The jumpers are labeled on the bottom of the module. If the jumper is at the off position, move it to the on position. This setting helps with vehicles that use less than 12 volts in their ignition systems. This unit may have difficulty learning the tach in vehicles with these ignition systems.
Jan 23, 2011 | 5303L Security/Remote Start System
I have a Yard Machine 5.5hp 2-stage snow blower. I bought it used but I think it is a lightly used 2004+-. I use the primer bulb and it will start within 2 pulls, runs beautifully. I slowly open the...
The running time seems to indicate a plugged fuel tank vent. Try opening the cap to see if that will allow continued running. Many engines have the vent within the cap itself, while others vent from the air cleaner through a line. Ignore the fuel drip on the adjustment screw. Hope this helps!
Dec 27, 2010 | Garden
Car shots down within 18 minutes of it running, fan does not seem to be running. It's a Saturn L-series 2001, drove it all the way to S. Carolina from Ohio with no problem. Yesterday I was driving to the...
It may be the CRANK SENSOR ,i had a car one time,it started fine,and drove fine one day i drove it about15 miles,stopped ,got back in it, started it, drove about 5 miles ,and cuts of with a little hesitation,it cranks but does not run, i sit there for about 20 minutes,crank it, it starts back ,i drive it back another 15 miles ,and runs great ** the crank sensor gives the signal to the ECM if the ECM ,never get that signal ,it does n't know to crank the car,or what cylinder to start with,check with your saturn ealer ,and get a second opinon
May 03, 2010 | 2001 Saturn L-Series
My 1999 chevy silverado is cutting out and dying. i've changed the fuel filter, it ran fine about four miles then stalled and won't start.it will start and idle then seems to run out of gas.
Wouldn't happen to be a diesel, would it? If so, do a search on ebay for a remote fsd/pmd module. Fixed my 95 'rado (in less than 20 minutes) with a 6.5 turbo diesel -it would stall wherever and whenever it wanted, without warning.
Mar 14, 2010 | 1999 Chevrolet Silverado 1500
My python remote starter when starting in the morning only wil will runl. On my 2008 dicota truck will run less than a min. And shot itself off only in thr morn.
You need to reprogramme the tach input, the engine is running colder in a morning and will run higher for a few minutes, during the day the engine will be warm and idle quickly.
Nov 21, 2009 | DEI Python 1400XP Remote Start/Keyless...
My unit is cycling on and off every 2 minutes or so.
This can be due to a faulty thermo sensor or if the unit is fitted with a pressure safety switch, it could be short of refrigerant.
Mar 09, 2009 | Carrier 38BRC036 Air Conditioner
My GE washer Model WPSR3100 will run for 2 or 3 minutes when first started and then stop. After 5 or more minutes it will start up again and run for less than 1 minute and stop again for another 5 or more...
It appears that you may have controller issues since operation is haywire. Try to reset the electronics to factory defaults. If this remedy does not do it then.........
Search Over 2 1 Million Appliance Parts
Sep 20, 2017 | GE Washing Machines
Rinnai water heater continually running
the rinnai comes on when water starts flowing through the unit.
Apr 08, 2008 | Heating & Cooling
Brand Remote Start/keyless/car Alarm Very Sleek Logo
43 people viewed this question
Top Spy Vehicle Parts & Accessories Experts
Colin Stickland
Colin Stickland
Rob Sinbad
Rob Sinbad
Norman Al-Anbar
Are you a Spy Vehicle Part and Accessory Expert? Answer questions, earn points and help others
