Question about Refrigerators
Model FRS26ZRF, the freezer side is cooling down
Fridgidare model FRS26ZRF 25.7 side by side, the freezer side is cooling down to 9-10 degrees, while the refrigerator side is up to as much as 65 degrees, doesn't sound like a compressor problem, but somethig else? The control switches on each side do not seem to have any effect on changing the temps up or down. I un plugged and found the vents on inside of freezer were froze up, allowed to thaw out, and the refrig side then cooled down to 47-48 degrees, while the freezer still is getting down to 10-14 last checked.
  • 50 Answers
It could be the defrost system? When you allowed to thaw, did you check the evaporator? It could be frozen? It will take longer to thaw. Is the evaporator fan working? It and the compressor will not, when the box is in defrost. Is your defrost working? Are your door gaskets sealing properly? Are your doors aligned properly? Some things to check. Good luck.
Posted on Jul 13, 2009
Model ZFSB26DNA SS Side by side / refrigerator and freezoe not able to get cool enough. Refrigerator side temp 49 freezer temp 7
refrigerators run from 5 to 10 degrees C so your machine is on the upper limit of 9 degrees c
the freezer is at minus 13 degrees c and most work down to minus 20 degrees c so that is in limits
Get a technician in to check the thermostats and in the mean time check the condition of the door seals as they will loose the cold very easily is cracked or not sealing properly
Nov 04, 2015 | GE Refrigerators
How do I access the defrost thermostat for a frigidaire model FRS26ZRF
It's in the freezer section behind the access panel. towards the top of the evaporator. usually at the top of the evaporator clipped to the line.
Mar 21, 2011 | Frigidaire FRS26R4A Side by Side...
I have a GE mdl PSI23SGRCSV side by side. initially the digital temp displays for both freezer and fridge sides went to 16 on freezer side and 43 on fridge side. This happened almost overnight it seemed....
it may be that your fridge is now low on freon the techs now do not know what to do the best thing to do is to call the tech and ask them to test the compressor pressures and see if it is low on charge. unless you know how to take the lower back panel off (the one that is probably cardboard) and feel the lines on the compressor and see if it is really cold and really hot that means that it is cooling properly but if it feels a little warm cominv out of the cooling side and hot on the return side then you need more freon.
Mar 04, 2011 | Refrigerators
Freezer cools to 10 degrees, refrigerator cools to 50 degrees
check if the fan is working and you are circulating air efficiently. You may check on the coils at the freezer if there are ice formation. I would suggest to have the ice melted by unplugging it and ensuring that all parts are ice free. Clean the unit while at it.
Jul 15, 2009 | Refrigerators
Frigidaire frs26zrf
IS THE EVAPORATOR FAN INSIDE FREZZER WORKING AT ALL IF IS NOT WORKING THEN THERE IS NO AIR FLOW TO THE BOTTOM PART
Nov 09, 2008 | Refrigerators
DEFROST SEEMS STUCK
Check freezer... for Frost build up and if Fan is blowing, Check condenser... To make sure clean, and the fan is blowing by compressor, Check Recirclating Vents in refrigerator... to make sure theres no blockage, CONTROLS ...should be in the middle setting,
Sep 13, 2007 | Frigidaire FRS266ZDSB Side by Side...
Refrigerators Logo
266 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
