Question about RCA DCM315R Modem
Driver download for a RCA DCM 315 cable modem.
I have misplaced my driver cd for a RCA DCM 315. Where can i download the drivers from? i have tried one website but all i got when i downloaded the file was a .sys file and am looking for a .dvr file i believe.
lolita
  • 385 Answers
SOURCE: I can't get my computer on the internet . I am using windows xp and the modem will not get the internet on the dell computer
Hi, This modem can be used via one of two ports: ethernet port (network port) or USB port If your computer has an ethernet port, it is perferable that you connect through this as you will have better performance. If you don't then you can get an ethernet card installed inside the CPU. If it's not possible to connect via this connection and you have to use the USB, then you will need drivers. This website gives you full instructions on how to use this particular modem and also gives you the USB drivers if needed. http://www.triadtwcable.com/template_media/cablemodems/rca245.htm Good luck! Lolita
Posted on May 08, 2007
  • 317 Answers
SOURCE: rca cable modem...
This one is for a DCM 315, it should be pretty close and might work. http://a1212.g.akamai.net/7/1212/6718/20030131/comcast.download.akamai.com/6718/help/cmdrivers/RCA_315.zip
Posted on Aug 01, 2007
  • 1550 Answers
SOURCE: cable modem 315
Have a look at the link below for basic troubleshooting techniques for RCA modem
Troubleshooting DCM 315
Posted on Oct 13, 2008
frcs68
  • 1605 Answers
SOURCE: Reseting "Bridge mode" in RCA DCM 305R cabel modem
you can't set teh modem to bridge mode, however, you can set the router to bridge.
The linksys should have bridge mode configuration in the uer guide.
connected the 2 router together
configure the IP address of the liksys to be inthe same subnet as the moem, but out of the range of the DHCP of the modem. ie. DHCP address 192.168.0.2 through 192.169.0.100, the linksys should have the IP address as 192.168.0.200
disable the DHCP on the linksys
setup the wirless just the way you would if ti was the modem.
connect from the modem LAN port to the LAN port on thelinksys. leave the WAN port open.
Posted on Dec 30, 2008
  • 9 Answers
SOURCE: DOWNLOAD A DRIVER
http://www.insightcom.com/files/RCA_DCM425.zip
Posted on Mar 07, 2009
I need a driver for modem D-Link DCM-202 for Windows 7
Hi almoro !
Here is a link to the Vista drivers. Drivers for Windows Vista should work with Windows 7 as well.
ftp://ftp.dlink.com/Broadband/dcm202/Drivers/dcm202_Driver_110.zip
Best of luck
omerk.
Jan 29, 2011 | Computers & Internet
Cable modem 315
Oct 13, 2008 | Computers & Internet
Need D-Link DCM 200 Modem driver
You should be able to find your drivers at this address:
http://www.dlink.com/products/?pid=DCM-200&tab=3
You will need to click on your country, as this is a discontinued product.
Hope that helped :)
Oct 17, 2010 | D-Link DCM 200 (DCM-200) Modem
I just reinstalled windows xp on my other computer and I can't get on the internet now. I downloaded my modem's driver onto a flashdrive, but I'm not sure how to install and set it up
You should install your LAN driver. Once you reinstall xp it does not automatically install LAN driver since this is a motherboard issue. The LAN driver is located on your motherboards set-up cd or on your recovery discs. If not available, the LAN driver can be downloaded from your manufacturers website...DELL, HP...etc, or if it's a homemade system then your motherboard's mfg website.
(LAN driver sometimes called ethernet driver)
Hank
Aug 16, 2009 | D-Link (DCM-202) Modem
Is my modem a WiFi router?
This RCA DCM 425 is a cable modem only its not even a router, its just a plain cable modem that is being provided by some cable company like Cox and Comcast, try searching again for a different box there they have a brnad name of Linksys, Netgear or Dlink because those are the common manufacturer of wireless router ...
Hope that helps............
Sep 18, 2008 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
No connectivity from 1 laptop but connectivity with another`
Try resetting the modem whenever you change between those PC's some NIC's will hang a cable modem stuck on an address.
May 02, 2008 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
RCA DCM 425C Modem USB driver
I got a different modem from Comcast....a Motorola. Then I got a Belkin USB network adapter. You can plug in an ethernet cable into the Belkin and plug the other end into the computer USB input. This works well for older laptops that have no ethernet input. Then you call Comcast and they configure it over the phone and Viola! It works. So if you have an older laptop like I have, get a Belkin F5D5055 Gigabit USB 2.0 Network Adapter. Plug it in to your USB input and then plug in the enthernet cable from Comcast. Hope this helps someone.
Feb 18, 2008 | Computers & Internet
Cable Modem Speed
yea certainly it will support as it has a WAN throughput: 38 Mbps however the download speed will fluxtuate from 9 mb to 11 mb......u wont have exactly 12 mb download speed/....oki
Aug 15, 2007 | Microsoft RCA CABLE INTERNET MODEM MODLE...
Rca cable modem...
Jun 20, 2007 | RCA Cable Modem DCM315R (11603540)
RCA DCM315R Modem Logo
649 people viewed this question
Top RCA Computers & Internet Experts
Julie Endres
shaun taylor
Are you a RCA Computer and Internet Expert? Answer questions, earn points and help others
