Question about Bosch HBN 9163 GB / 9163 GB hot-air Double Oven
Hi, I have a Bosch HBN9121GB/06 double oven and the main oven was not getting hot. The Fan was running & Light was on. I switch them off tried it again and heard a click. The fan and light are now not working. I have removed the element which has completely fractured and open circuit. Would this be the reason why the fan and light are stopped working and presumably all part of one circuit. I cant find any control fuse and the small over is working. ?
  • brian_mountf Jul 27, 2009
    Hi, I have now resolved this myself and it appears the element although part of the circuit, would not stop the fan running. When you isolate the oven electrically and switch back on, it may "default" to auto mode on the clock, as if you have timed it to come on later. Consequently this will "hold off" the oven until the auto mode has been cancelled. It drove me mad for a while but with some help on the phone, got it sorted !!!
  • 1462 Answers
SOURCE: fan oven not heating, bosch hbn 202t
the fan oven element is separate from the grill element. the problem is that the circular element round the fan is blown. remove the back panel of the oven and you will see the element. replacement is easy. on most bosch, the element is removable from inside the oven but for some you have to remove the oven and take off the back casing
Posted on May 04, 2007
barkencoa
  • 3463 Answers
SOURCE: bosch convection double oven,ovens won't heat,only broilers work
If it is fan assisted then check the fan element, it is located behind a panel at the rear of the oven compartment.
Plz rate my\solution.
Thanks.
Posted on Dec 17, 2008
  • 134 Answers
SOURCE: MAIN OVEN DOESNT WORK
Hi
Pretty certain nofuse. Suspect switch. Guess would be as element blew it took out contacts on oven switch
Posted on Feb 20, 2009
barkencoa
  • 3463 Answers
SOURCE: I have a bosch double
It should not be neccessary to remove from cabinet.
Remove cover at rear of oven and you should be able to change the elemnt from inside.
Posted on Feb 10, 2011
HansPP
  • 2510 Answers
SOURCE: Bosch built in double oven:
This type of problem normally can be ascribed to a defective thermostat. Unfortunately there is no test for a thermostat, it has to be replaced to see if the problem has been sorted out.
One thing you can do is remove the thermostat bulb from the oven and place place it in a position where it will not heat up. Place an oven thermometer in the oven. Switch on and see of the temperature climbs above what you wee seeing before. This is a very much hands on test as you have no control over the temperature that the elements can get to. As soon as you see the temperature reach a point above that seen before, shut down immediately.
Posted on Mar 27, 2011
Bosch oven cooling fan behind top oven not switching off after using main fan oven
stat problem stat that controls fan function is not openning telling control oven is still hot How Does An Electric Range Oven Work Appliance Repair
Jan 29, 2017 | Bosch Ovens
Bosch HBN 91 Sticky Fan
Yes you can oil the shaft...but the problem is within the bearing itself. You might be lucky and only have to oil it once...but chances are your bearing will sieze again...I suggest you remove and replace the fan.
Dec 02, 2013 | Bosch HBN 9163 GB / 9163 GB hot-air Double...
Main Oven Overheating
Try putting thermoter in oven take off main dial you well see a small screw ajust slowly and check every 30min.tell temp is correct.and put dial back on
Jul 26, 2010 | Bosch HBN 9163 GB / 9163 GB hot-air Double...
Main oven doesn't heat up. is there a fuse i can change some where?
If it is a electric fan assisted oven, and the fan is working o/k, then you will probably find that the oven element is faulty.
This is located at the rear of the the oven compartment, behind a removeable cover.
Hope this helps.
Dec 31, 2009 | Bosch HBN 9163 GB / 9163 GB hot-air Double...
Neff U1410 main oven trips the main RCD. Occurs
I have a u1421 with the same problem! I notice the fan doesnt run too well, sometimes it doesnt run at all, needs a prod to get it running. I suspect with no fan, that the element gets far too hot, and then starts to leak to earth, tripping the RCD. I'm gonna try buying a new fan motor - you should ckeck if your fan is running full speed OK.
Oct 25, 2009 | Neff U1421 Double circotherm Electric Oven
Electrolux double oven does not get hot
If it is a fan assisisted oven and the fan is still working, then you need a new oven element fitting.
Plz rate my solution.
Thanks.
Jan 11, 2009 | Electrolux EOU6330 Electric Double Oven
Top oven (and Grill) have stopped workingMy 3 Year old AEG Competence D2100-4 Double oven has malfunctioned.  Bottom (main oven) works fine but top oven and grill have ceased to function.  The fan will run...
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Nov 12, 2008 | AEG D2100-4 Electric Double Oven
Bosch hbn s gb
oven element would need model and ENR No. to supply
Sep 16, 2008 | Bosch HBN 9163 GB / 9163 GB hot-air Double...
Main oven not working
the thermostat or selector switch has gone.
Mar 14, 2008 | Neff U1721 Double circotherm Electric Oven
Bosch HBN 9163 GB / 9163 GB hot-air Double Oven Logo
80 people viewed this question
Top Bosch Ovens Experts
ashburton
reliableservice
Are you a Bosch Oven Expert? Answer questions, earn points and help others
