Question about Sport & Outdoor - Others
1998 4 stroke 9.9 johnson outboard shuts off while trolling, starts back up a few hours later
    Champion:
  • 225 Answers
Check the coils,sounds like the are getting hot and has to cool befor restart.
Posted on Aug 02, 2009
Is a 1978 Johnson 115hp outboard a two or four stroke
for that year of manufacture 4 strokes were not the normal thing in outboards
if it doesn't have rocker covers and rocker gear it is a 2 stroke
Jun 24, 2017 | Johnson Boating
What is the gap setting for a champion 910 spark plug for a johnson 6hp four stroke outboard motor
if the plug is a standard plug as used in a car , it is the wrong plug
the plug to use is a multi point plug or anti foil plug and the gap is preset
single point plugs such as used in cars motor mowers etc , foul up from the oil / fuel mixture that deposits carbon across the gap so the use of a multi point anti foul plug is recommended in outboard engines
if you persist , for an conventional magneto /coil operation .025" and a later electronic ignition .050"
Sep 30, 2016 | Boating
I have a 1998 model E25RMECA I NEED TO KNOW WHAT TYPE GAS TO USE IN IT. AND IF IT IS 2 CYCLE OR 4CYCLE.
I found a mixture of sites for the information
one owner of a 1998 25 hp evinrude says that it is a 2 stroke with a fuel mix ratio of 50:1 as 25:1 is a bit smokey
another site says that the recommended octane fuel rating is 87 although it might run better on 91
best advice is to find an evinrude service dealer and get the right information as the later 25 hp units are etec engine which will be 4 strokes
Oct 23, 2015 | Clymer Evinrude/Johnson 5-70 Hp...
What year is a johnson 4 hp outboard serial number b 7643180 model number bj4brccs
To get the year of Johnson and Evinrude outboards use the word "INTRODUCES". Each letter corresponds to "1234567890" respectfully. It's best to check with a model year reference book, but this motor's model number contains "CC" which would indicate it's a '88.
Sep 21, 2014 | Clymer Evinrude/Johnson 2-70 HP Two-Stroke...
Change question
sounds like a fuel venting problem. Loosen the cap to the gas can and see if that works.
Then (if that fixed it) you will find the vent built into the cap is sticking shut or you forgot to open it.
Sep 25, 2012 | Seloc Johnson Outboards 2002-2007 Repair...
I have no spark on 1989 7.5 evinrude outboard motor
Hi have you tried it with the stop switchl/button disconnected, if so you have only got the stator under the flywheel left to replace, regards Phil.
Jun 04, 2012 | Boating
9.9 johnson 4 stroke wo'nt idle
Your cabs need rebuild, something is stuck in the carb or air line cracked
If you have rebuilt the carb check for carb gaskett leak that caused and let the air flow in
When to choke is on the air is block and prevent air flow but allowed small amount of air to keep the engine running
After your engine warmed up the heat in the compression burn much faster so you have to let air in by turn off the choke
Good luck
Aug 19, 2009 | Boating
Sport & Outdoor - Others Logo
161 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
