Question about Kenmore HE2 Plus Front Load Washer
What does F-20 MEAN ? - Kenmore HE2 Plus Front Load Washer
X/2-20=150
You could mean
(x / 2) - 20 = 150 then x = 340
or
x / (2 - 20) = 150 then x = - 2700
Wherever this type of ambiguity arises in an equation you should use brackets to resolve it. Note that in the absence of brackets a calculator will always choose to perform multiplications and divisions first.
Oct 31, 2017 | Miscellaneous
Please I'm still waiting for any solution What My 1995 c280 Mercedes Benz can not raise or fire beyond 20 odometer at idle, please what could be the problem
every one is having trouble trying to understand what you are saying
cannot fire or raise ----does that mean cannot accelerate the engine
beyond 20 odometer does that mean faster than 20 mph(klm ph)
or does it simply mean that it will not rev higher than 2000 rpm on the tachometer
a odometer reads speed and a tacho reads engine rpms
so you can see why no one is answering your question
it is confusing as to what you are saying
Sep 18, 2016 | 1995 Mercedes-Benz C-Class
The humidity sensor reads "LL" ... What does that mean for a gro1 digital weather station ?
Humidity value is lower then the forecaster registers , they normally go no lower then 20% . If you are getting an LL that could mean where you are located the humidity was lower then 20%
Feb 18, 2015 | Measuring Tools & Sensors
Math mean median mode
The question is incomplete.
The mean, also called the average is defined as
mean= (sum of the data values)/(number of data elements)
Mode = the most frequent data value (the one that is most repeated)
To find the median:
  1. Order the data values in ascending order (sort them from the smallestr to the largest), and
  2. Locate the data value that is in the middle.
  3. If the number of data values id ODD (not a multiple of 2) there is only one middle element. That is the median.
  4. If the number of data elements is EVEN (multiple of 2), there is not one middle element but two.
  5. The median is the average of the two middle element values
    1. Median =( left of middle value +right of middle value)/2
    2. Imagine this median value to be inserted between the two middle elements
Example 1
Data values 12.5, 13, 13., 13, 13.5, 14, 19.5, 19.5, 20
Mean =(12.5+13+13+13+13.5 +14+19.5+19.5+20)/9=?
Mode= most frequent value. Here it is 13 (repeated 3 times)
There are 9 values, an odd number. Middle element is the 5th ( 13.5)
Median=13.5
Example 2
Data values 12.5, 13, 13., 13, 13.5, 14, 19.5, 19.5, 20, 25
Mean =(12.5+13+13+13+13.5 +14+19.5+19.5+20 + 25)/10=?
There are 10 values, an even number. Middle element is not among the values. There are two middle elements (the 5th and the 6th) or
The value of the median is the average of the 5th and 6th elements or
Value of Median =(13.5+14)/2=?
Nov 21, 2013 | Computers & Internet
My pump psi reading is 20...what does that mean?
Pumps do not have a Pressure Guage.
A filter will have one, if your pressure is higher than normal... (A 20 reading tells us nothing, if we don't know what normal starting pressure is - 20 could be normal for some systems)
If you had a reading prior to the 20 you are now seeing by approx 8 lbs, then clean your filter - backwash/backflush.
Aug 17, 2012 | Hayward Pool & Spa
How to assemble a DP Fit for life dual trac 20
dp trac 20 weight lifting mechine how can i assemble
Dec 18, 2011 | Cars & Trucks
What does E 20 mean
e20 is problems with draining. check pump chamber at plinth area of washer. first drain water out of drain tube (at side of pump access area). can be blocked at connection with waste if under sink connection.if not these pump may be faulty.
Jul 23, 2010 | Zanussi FLE1416W Front Load Washer
Omega Europa 20-1 oven. What do the symbols mean?
Fan symbol - defrost (fan only - does not use thermostat)
Fan symbol within a circle - fan forced oven
3 little triangles - static grill (keep oven door open)
3 triangles above the fan symbol - fan grill (keep door closed)
Oct 03, 2009 | Ovens
Kenmore HE2 Plus Front Load Washer Logo
83 people viewed this question
fordexpert
Kristen Denison
Kristen Denison
Level 1 Expert
Jim Chinnery
Jim Chinnery
Level 1 Expert
