Question about Garden
At the time I was using the trimmer and it just
At the time I was using my Homelite trimmer and it just quit running. Won't start at all.
5 Suggested Answers
darth yoda
  • 4 Answers
SOURCE: Homelite trimmer dies every time I squeeze the handle
try to adjust the air intake??
Posted on May 29, 2009
#1 Taper
  • 1041 Answers
SOURCE: Homelite gas trimmer will not run without half choke and throttle
You need to disassemble the carb. and spray with carb. cleaner. If you need tips on how to do this, just let me know. You may need a new carb. kit as well, but we won't know that until you first perform the first step, or if the carb. parts are more than 3 years old. If they are, then go ahead and buy the carb. kit and replace the parts.
Jim
Posted on Jun 02, 2009
  • 50 Answers
SOURCE: Homelite Trimmer Model NT20769 After pressing the
once you start you need to adjust the A and B carb. screws
Posted on Oct 16, 2009
hunter19_46m
  • 7482 Answers
SOURCE: Trimmer won't start
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please rate me, Thanks
Good Luck, I hope this helped
Posted on May 15, 2010
Homelite weed trimmer bogs down and smothers out quits running
This could be a number of things. Clogged air filter/fuel filter/carburetor/fuel tank lid breather hole, cracked fuel line or primer bulb, or clogged spark arrestor in muffler. Here's some links that will help to change the bulb, fuel cap, fuel lines, rebuild carb, replace spark arrestor, and troubleshoot.
Homelite Tune Up
Homelite weed eater gas trimmer will not run how to rebuild weedeater...
http://www.repairclinic.com/RepairHelp/String-Trimmer-Repair-Help
Apr 27, 2014 | Homelite Garden
Homelite weedeater mod. 26cs
Try going to ebay and finding a carb for the model, some are as cheap as $12.
Mar 12, 2017 | Homelite Mighty Lite Lawn Trimmer
Trimmer won't start
they were in/out.
May 13, 2010 | Homelite Mighty Lite Lawn Trimmer
New trimmer same problem
the carb screws need to be reset
Sep 01, 2009 | Homelite Mighty Lite Lawn Trimmer
Trimmer won't stay running
Most likely needs the carb rebuilt.
First check the prime bulb and fuel lines for cracks. Check the spark arrestor for carbon buildup.
Another problem could be a stuck piston ring, but try rebuilding the carb first as it is usually the source of the problem.
Aug 02, 2009 | Homelite Mighty Lite Lawn Trimmer
Homelite xs 135 runs 10-15 min then stops. have to reprime and it runs 10-15 min.
Either the gas mixture is not quite right or the gas cap is slightly clogged.
If you don't have enough oil in the gas, this may cause it to overheat.
The next time you run the trimmer and it starts to die, loosen the gas cap. If it starts running again, then you know that it's a clogged gas cap.
You may also check the air breather, it may be dirty as well.
If you need further assistance, just let me know.
Jim
Jun 27, 2009 | Homelite Garden
Correct gas to oil ratio for Homelite Mighty String Trimmer Model
most trimmers are 50:1. or 40:1. i would use synthetic 2 cycle oil and use the 50:1 ratio. i know guys with trimmers that require 50:1, and they use synthetic at 80:1 with no problems for years. they say the engine runs cleaner. i am a part-time lawn care operator.
Jun 18, 2009 | Homelite Mighty Lite Lawn Trimmer
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
