Question about Lanzar Vibe 210 Car Audio Amplifier
I am getting a loud bumping sound when 2 rca jacks are plugged in..
    Scholar:
  • 113 Answers
Hiya limited info but thats normal -as the rca goes in in makes a once off pop noise and also suggest the amp is fine. If the noise continues (which was not clear sorry) then the problem could be preamp, x over etc if there is a problem??
Its better to plug in RCA etc when the amp is off as well. Have known amps to go bang from this.
Best of luck
Posted on Jul 14, 2009
How to make sound loud enough to hear normal hearing
Carole... Is there a "Audio Out" on your TV or perhaps a 'earphone' jack?
MANY MANY amplified speakers and boom boxes may serve you very well! Of course you will need only ONE. You will also need the extension cable that interconnects the two devices.
A "adapter" may also be needed IF your Audio Output Jack is a RCA type?
RCA Plug to 3 5mm Jack Adapter
https://www.showmecables.com/3-5mm-mono-plug-to-rca-plug-cable-6-ft?gclid=Cj0KCQjwzIzWBRDnARIsAAkc8hGtGWhZt7MqTHAoDRzY5LJKsJYpWgLFlxLjGV1bWEuo908cplIcAr0aApLvEALw_wcB
Anthony
Apr 03, 2018 | Televison & Video
I have a paradigm ps 1000.it powers on fine when i plug in the rca cable into thoe back of the sub into the low level input it humms supper loud. i tested my cable and used another one same thing. could...
It sounds like it has bad ground on the RCA input assembly, you should Ohm out the ground of the RCA jacks to see if they are all connected.
How about the sender side (the amplifier) ground?
Mar 09, 2011 | Paradigm PS1000 Speaker
We have our cable box hooked up to the tv and get a great picture but no sound. The previous owners had a stereo system hooked up to the tv and we are simply trying to get any sound at all. We went into...
Ok, I need more verifications:
1) Your TV is Fujitsu Siemens PlasmaVision P42VHA40 Monitor which does not have tuner? If not, please provide the make and model of the TV.
2) What kind of cables you are using to hook between the cable box and the TV? HDMI? Component video (Red, Blue, and Green cables withe RCA plugs)? Composite video cable with Yellow RCA plugs?
3) Are you trying to get the sound to come out off the TV speakers or through the stereo system?
Feb 03, 2011 | Fujitsu Siemens PlasmaVision P42VHA40...
Model ELCHW402 40" LCD
The TV has two audio out options: a digital audio out (coaxial) and a 3.5 mm headphone jack. Both of these are just above the antenna in connector. The headphone jack is the top one.
For a sound system that uses RCA stereo plugs, get a 3.5 mm (M) to 2 red/white RCA F adapter at the headphone jack and use an RCA audio cable from the adapter to the sound system. Alternatively, you can use a 3.5 mm audio patch cable from the headphone jack and the 3.5 mm (F) to 2 RCA (M) adapter at the sound system. The TV speakers will probably be turned off automatically with this connection.
If your sound system has digital audio, get the digital audio cable. You will need to enter the menus to make this audio output active. See the Audio menu > SPDIF Type (PCM, Dolby or Auto).
I hope this helps.
Dec 24, 2010 | Element Televison & Video
Audio-Technica freeway 200 Series VHF Wireless System - I had problems connecting the wireless system with a quarter inch to a xlr. The sound system made a very loud disturbance sound. What cable do I use...
XLR connectors are a two-wire plus ground system. Using a 1/4 inch to XLR adapter may not connect the wires correctly to your sound system input.
The A-T Freeway 200 Series has a 1/4" output jack. This would indicate a line level. A cable to connect the tip of the 1/4" jack to pin 2 of the XLR and the sleeve of the 1/4" jack to pins 1 and 3 of the XLR should work. The XLR should be plugged into a device that accepts line level.
Ideally, you should plug the 1/4" into a 1/4" or RCA jack that is designed for line levels.
Dec 14, 2010 | Audio Technica ATM33A Fixed Charge...
How do you connect external speakers to a desktop pc?
if what you are trying to do is connecting a regular speakers not made for pc, it would be best to connect through a stereo receiver for most time your pc does not have enough power to drive those speakers. You will need a RCA to standard stereo head phone jack connectors (at your local radio shack). Plug in headphone jack to your sound out put jack in your pc. Connect RCA jack to your receiver's Aux, or any other available input slot(CD, Vidro, ect...) make sure to start up at low volume for it might be really loud.
Oct 12, 2010 | HP Presario SR1120NX (PC132A) PC Desktop
Can i hook my onkyo reciever upto my laptop to bump my musac? and what do i need?
u need this (search ebay.com)also u can make this cable easily. 3.5mm Mini Plug to 2-RCA Stereo Audio Cable. plug 2 RCA jacks to (Aux in)socket on your Receiver,3.5mm Minijack to your Laptop's speaker out.select AUX input on your Receivers Remote .
Apr 22, 2010 | Onkyo TX-DS595 Receiver
I have a djm 400and a pair of active behringer speakers model b2031a an im gettin no output from then what am i doin wrong the leads are male to female in the back of the speakers an obviosly like a phone...
First, we need to get the terminology correct.
The DJM has "PHONO" (RCA) jacks, not "phone jacks" of which the current usage is normally the 1/4 inch diameter.
You would be going INTO the Berhinger 1/4 inch jacks on the back of the speakers since you are not using the three pin XLR connections that are used for balanced lines which the DJM does NOT have.
So you should have RCA plugs to 1/4 inch plug cables. The inputs on the 1/4 inch will take TRS connections. IT IS possible you may need to use an RCA to TRS cable with the signal on the "ring" rather than the "tip" of the connector.
A test of the speakers is to touch the tip of the RCA plug with the speaker on and you should hear a hum.
PLEASE be aware that these speakers are INTENDED for use as studio monitors by the sound man in the booth and NOT for playing loud at a venue for dancers, etc.
Dec 16, 2009 | Pioneer Music
I just bought a RCA rtd3131 home theater system. My husband trashed the manual and i can't get all the speakers to work when the cable is on. When the DVD is on all the speakers work but the sound is not...
If the cable tv has audio out jacks, or if you have a cable box with an optical audio cable, plug either the audio jacks into the RCA system or the optical audio cable, and the system should automatically simulate 5.1, through Dolby Pro Logic II. All speakers will not be at the same volume as they are simulating surround sound, not just playing the audio.
The TV will never have sound for the DVD as this system has no audio out puts. Realistically, most televisions have 10w speakers, and this system is 130w, so the TV speakers are useless in comparison.
Jun 28, 2009 | RCA RTD300 DVD/VCR Home Theatre System...
Lanzar Vibe 210 Car Audio Amplifier Logo
Top Lanzar Car Audio & Video Experts
Chris Ward
xxxxxx xxx
Are you a Lanzar Car Audio and Video Expert? Answer questions, earn points and help others
