Dell w1700 As with most Dell w1700's no picture only audio. I replaced the backlight inverter board and fired it up and the tv worked perfectly. Only problem is no picture on the pc monitor side only a test pattern. Obviously I have done something while it was apart. Cable and hook-ups all fine. Any ideas?
My Dell W1700 worked fine for 3.5 years. But one day I turned it on and got black screen with only sound.
I took everything apart. I don't know which board to replace and where to get it.
Any suggestions?
Igor My Dell W1700 worked fine for 3.5 years. But one day I turned it on and got black screen with only sound. I took everything apart. I don't know which board to replace and where to get it. Any suggestions? Igor
You can't post conmments that contain an email address.
Hi bsut96,
Check the cable between the monitor and the box for damage.
Try a new cable.
It may be a problem with the input board but it sounds like a cable problem.
Let me know what you find and please rate this solution. Lone99star
I have just did this here is the solution for you:
MoniServ, Inc.
http://www.moniserv.com
Tools:
Philips screw driver
Small Flat screwdriver
that’s all!
Preparation:
Make sure your desk is clean and you also need a piece of soft clothes because you need
to place your LCD Monitor face down.
How to open the back cover:
First, remove all screws on the back cover, then, use a small flat head screw driver to
push down
the plastic Clip inside the LCD Monitor star at the bottom of monitor. Then you can easily
separate the front bezel and back cover like the photos shown below.
Backlight Inverter Installation Procedures for Dell W1700
Place the Monitor
Face Down
Push This Plastic Button
Down and Remove
Swivel Base as shown
on Next Photo
Remove these
screws
Star at the bottom of monitor as
shown on photo.
Use a small flat head screw drive
to push down the plastic clip.
Do it one side at the time as
shown on next 2 photos
When you have unlocked all 4 sides of plastic clips, Place the monitor face down again
as shown on photo
Slowly tilt
upward from
left side of
back cover
Disconnect this cable and
remove back cover
Remove two
screws and Pull
out this small
circuit board
Disconnect Speaker
cable and remove
the tapes
Disconnect
Backlight cables.
Remove these screws
on the both side of
Panel
Caution!!!
Slowly tilt upward the chassis and disconnect the flat cable
between Chassis and Panel As shown on next 2 photos.
Holding the chassis upward and
Use small flat head screw drive
to unlock this plastic clip
Slowly pull it out
Remove defective inverter board and replace with our New Substitute Board
(T501045.00MSS) and re-install all disassembly components back. Now your LCD
Monitor working again.
MoniServ Substitute Board is available at
http://www.lcdpart.com/Products/t50104500mss.html
Backlight Inverter board.
Photo Shown with our Substitute Board
Remove 4
screws and
disconnect
this cable
you may have gotten a bad board. this board is the most common failure to the back lights lighting. the cffl's can not be replaced they are a part of the panel, you would have to completely dismantal the panel to get to them. if you feel that the board is good the next step is the main board. the feed back to the main board is not being excepted the processor, replace the main board.
Any suggestions?
Igor
