Question about Estate TGDS840JQ Gas Dryer
Eleven year old Whirlpool electric dryer cannot turn the drum with a full load of towels. The motor turns on but then shuts off. It will turn a very light load.
  • 375 Answers
Turn the drum by hand. It should rotate fairly easy in one direction. If so, then the motor is going out and need replacement. Fairly common problem.
Posted on Oct 14, 2009
Whirlpool electric dryer wed5300sq0 runs for like 5 minutes then shuts off....other than that everything works....
Reach inside the dryer and turn the drum. Does it turn easily? If not then it might be rollers or idler or drum glide worn out. Even if the motor needed replacing I would do it on this mdel. Nothing newer is worth a dayum in today's market. You can also try and lube the motor if it is getting hot and quitting. I have some links here:
Help! My dryer is growling at me, won't go!
Kenmore/Whirlpool Old school Dryer repair tip
Jan 24, 2011 | Whirlpool Dryers
Dryer model # ALE866SAW approx 9 years old ran great until tonight. Went to touch up load of whites (socks underwear etc) and get a sound from the back that sounds like an electric motor that just went on...
Yes it sounds like the motor is bad and that is very fixable, but what about the belts the guides and the wiring??? If this has been used hard ( more then 6-8 loads a week for 9 yrs then I would go new...
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
May 09, 2010 | Dryers
Drum won't turn
Your dryer uses a belt wound around a spring loaded pulley and, around the middle of the drum and, around the motor pulley to turn the drum. If you feel capable of fixing ths yourself: Unplug the dryer, if it is gas or, electric. if it is gas: shut off the gas line to the dryer then remove the gasline; next pull the dryer out from the wall and, remove the back panel. Once you do this you will see that the belt has fallen off both the motor pulley and, the spring tension pulley. put the belt back on so that the belt is tight around the drum and, the drum will turn again.
Apr 05, 2010 | Whirlpool LER4634J Electric Dryer
Whirlpool electric dryer not drying
If the drier drum is still turning I would suspect a separate fuse is open for the heating element. Checking this may require openning the back cover. It may also be a defective or open heating element.
Jan 28, 2009 | Whirlpool LER8648L Electric Dryer
Dryer Not Tumbling
Sounds like belt problems.
Jan 20, 2009 | Whirlpool LER5636P Electric Dryer
Dryer motor
if the motor buzzes when you push start then it is a bad motor.as long as the drum turns freely by hand.
Oct 29, 2008 | Whirlpool LER4634J Electric Dryer
Estate TGDS840JQ Gas Dryer Logo
Top Estate Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Terry Schneider
Are you an Estate Dryer Expert? Answer questions, earn points and help others
