Question about GE Spacemaker JVM1640SJ Microwave Oven
GE Microwave cooks for a few secs then pops off and asks me to reset the clock.
  • GE Master
  • 9,098 Answers
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again. If that doesn't work, leave it unplugged for about 5 minutes.
Otherwise, this is almost always due to a defective or loose magnetron causing electrical interference and disruption in the control circuit board.
Details covering some previous models are in their bulletin here. Even if your model is not on the list, the same problem can occur.
If your magnetron was recently replaced, it may have loose mounting nuts or bolts or maybe the wire mesh RF gasket was not installed or got pinched.
NOISY MAGNETRON TEST (c) 2009 William E. Miller prototech@usa.net
One way to test it is to do the following:
1. Unplug the microwave or turn off its breaker.
2. Open the door, then detach the control panel as shown in the video at http://www.microwavedisplay.com and swing it down, but without disconnecting the wires. If you have any trouble getting the grille off once the screws are removed, slide the hood vent grille to the left about 1/4", then then pull it forward. On some models there are L-shaped clips that fit into a slot to hold bottom of the vent.
3. Plug the microwave back in.
4. Make sure neither you nor anyone else reaches in behind the control panel. There will exposed high-voltage connections.
5. Put a few cups worth of water in a microwave-safe container and place it inside the microwave.
6. Shut the door.
7. Run the microwave for about 1 minute or so on full power. (Time Cook > 1 > 0 > 0 > Start, e.g.)
8. If it does not fail, try it several more times.
9. When the water boils, change the water and try again.
NOTE:
If your model does not have a door handle, you will need to unplug the oven and reattach the control panel to be able to open the door.
If it still does not fail, I would recommend that you put it all back together and keep using it until it fails more consistently, then repeat this test.
While a microwave should never be left running unattended under any circumstances (as your owner's manual will tell you) it's even more important when one is exhibiting a failure or any odd behavior. So play it safe and stay with it while it's running!
If you or someone you know want to replace the magnetron yourself, you will need to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
Sometimes they will send you the magnetron to do it yourself. Call them at 888-239-6832.
Be persistent. You may have to speak with a supervisor.
If it is not within the magnetron warranty, you can find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Jul 14, 2009
Troubleshooting Ge Microwave that is acting bizarrely
Sounds like the main control board, but further testing should be done to rule out other possible causes. One thing I would do is to check to make sure it is plugged into a grounded outlet that is actually grounded. Bizarre behavior can be caused on some ovens because of a lack of a ground connection.
Oct 13, 2016 | GE Microwave Ovens
GE Spacemaker XL 1800 turns on for 1 second and then resets. The display shows PRESS CLOCK.
Sounds like your losing power, have you tried it on a completely Different circuit??? Either that or bad fuse or connections inside of microwave.
Sep 08, 2017 | GE Microwave Ovens
Ge spacemaker jvm1650sh01 starts to microwave then loses power
See this FixYa solution.
May 27, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker shuts off after a few seconds and asks for the clock to be reset
Ge Spacemaker comes on ok but after a few seconds the noise level goes up significantly and it does not heat. It keeps running until the time runs out but it doesn't heat.
Feb 11, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Went pop 20 seconds into cooking clock still works turntable stills moves won't heat
Remove the cover and look for a blown fuse. If found, replace the high voltage diode and the 'stirrer' (a fan like device that is inside the sheet metal wave guide near the area where the microwave energy enters the cooking cavity).
Oct 12, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Same thing. Mine was also manufactured feb 05
See this FixYa solution. even if your model number is different.
Sep 09, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Is not cooking
sounds like the magtron is gone out.
Call GE answer center 1-800-626-2000 ask for tech help. Have you model # off the data plate ready.
May 09, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Power cuts out after about 5 seconds
Hi try unplugging form mains for an hour this will reset any settings back to factory settings let me know what happens after doing this then i can assist you further ok
Mar 19, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Shuts off, must reset clock
Sounds like you could have a fauly control circuit. Something like when you press the pad the processor does not interpret the information correctly and resets itself. Or the power going to this circuit is being interupted. It is VERY dangerous to work inside of a microwave. So you could get an estimate from a repair shop. But those control boards are expensive. Do not attempt to repair this yourself. For your own safety.
Aug 06, 2006 | Frigidaire PLMV168 Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
131 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
