I cant even turn it off, it doesnt connect to the monitor it says its on power safe mode. When I plug it in, the fan runs, the machine runs and turns on but nothing out of it, the mouse and keyboard dont work with it
    President:
  • 2,777 Answers
Hello there, sorry to hear about your problems with this machine.
The first thing you will want to do it shut it all the way down (hold the power button in for 10 seconds or so).
Once it has been shut down go ahead and unplug EVERYTHING from the computer, both front and back. Now go ahead and plug in only the power cord and the monitor cable. Turn on the computer, if your monitor still doesn't come on then you either have a bad processor, bad ram, bad motherboard, bad video card, or under voltage power supply. If this computer used to work fine and suddenly stopped then you have a piece of hardware fail on you. You will want to get the machine checked out by a local computer repair place. Or, if it's still under warranty, check with the manufacturer.
If you were able to get it on with only the two plugs into it then shut it back down again and this time plug in just those two and the keyboard and mouse. See if you can boot into Windows just fine. From there keep adding hardware one at a time until you find the problem.
Hope this helps, thanks for your time,
Tim
Posted on Jul 14, 2009
Flatron lcd l1930b in power saving mode how do i get it out of power saving mode
if the PC can be booted up and after that the monitor goes into powersave mode... if that is the case, you can turn this function off by clicking start and then run button, In the dropdown box, enter "powercfg.cpl" (without quotes) and click ok.. Note: one can also use Control panel and then select Power option icon.
Once you are inside the power options property.. turn the monitor's timing off by selecting "Never"...
One could also turn off the power management from the BIOS setup
If you cannot even get the monitor started and got a "no signal" before getting into the safe mode, most likely you have a problem with the video card or the cable. Have them fixed by either changing the cable or the video card.
You will need to check if the refreshing frequency rate if you have the video card or the drivers changed.when the refreshing rates are not the same between the monitor and the PC's video driver, it will give the same problem
Jun 06, 2014 | Computers & Internet
E machine model T3626 turns on display doesnt work and doesnt power off???
Sounds like either the Monitor is bad or the Video Card is bad. Try plugging another monitor on the computer and if it can't show a display then more than likely the Video Card is bad. If it shows on the monitor you just plugged in, then the original monitor is bad.
May 01, 2012 | Computers & Internet
It doesnt run, I men when i hit the start button it sound like is going to run but suddenly the fan just gone crazy... and nothing else happends, no image in the monitor and nothing else but the fan runs...
give it a good kicking...................NOOOOOOOOOOOOOOO
just kidding, check all the power leads and data cables, re fit the ram. if it still wont book normally, try safe mode (f8 on boot)
if not get back
Jul 16, 2010 | Dell Dimension 2400 PC Desktop
My computer will turn on but my monitor does not get a signal and I've tried this on two working monitors and two different power chords. The lights on the keyboards don't even work. Any solution?
I was just dealing with this last night. My pc would come on, but I kept getting a "No Signal" message on my monitor. I first plugged the machine into a known working monitor. It worked fine so that eliminated the video card issue. Then I plugged the monitor into a different computer...it too worked. So I knew that the monitor was good. I then switched the cord from the faulty monitor and still didn't get a signal. I proceeded investigating the issue. I found that if you boot the machine in safe mode, it actually caught a signal. So...I figured it must be something to do with the resolution. My solution: Boot the machine in safe mode, change the resolution in the control panel and reboot the machine. If it doesnt catch the signal booting in safe mode, I suspect it is a faulty video card. You are likely to find what you are looking for online at zipzoomfly.com or newegg.com
May 20, 2010 | E-Machines eMachines Desktop PC
Resolution set too high ..no picture cant get safe mode to work up down arrow buttons wont move ..computer wants to start normal...cant get into computer with no monitor display ...help...brand new...
Sounds like you need to boot up in VGA mode instead of Safe Mode
Step 1. Power Down your computer.
Step 2. Powwer on your computer and press F8 to enter Safe Mode
Step 3. Instead of selecting Safe Mode, Select VGA mode.
Step 4. Once in Windows, uninstall your graphics card for your Monitor.
Step 5. Restart your machine, when you log back in Windows will reinstall the drivers for your monitor.
Apr 21, 2010 | ViewSonic VX2025wm 20.1" LCD Monitor
Black Screen Compaq Presario
Do you see the BIOS splash screen or anything?
Try booting into safe mode by pressing F* as soon as you power on the computer. If the monitor works, then it is a bad driver. Roll back to a previous restore point, boot to last known good coonfiguration. Last Known good configuration is available from the same as the safe mode screen.
If this is helpful, please comment and rate. Have any other questions, please let me know.
Oz
Feb 12, 2010 | HP Compaq Presario SR2010NX PC Desktop
My emachine T1742 desktop will not turn on. When plugged in the power supply's fan turns on, cpu fan doesnt start, both hdd/power led's flicker and pressing power button doesnt power on/off system.
Disconnect all the devices from the computer(tower) including keyboard, mouse, monitor(everything)..even the power cable
Now keep on holding down the power button on the computer tower for 15-30 seconds..
Now release the power button, plug in the power cable, monitor, keyboard, mouse and turn on the computer...
If it works, great!!!
Otherwise, take it for repair..
Dec 03, 2009 | E-Machines eMachines Desktop PC
THE ONBOARD VIDEO DOESNT WORK HOW DO I DISABLE IT, WITHOUT GOING INTO THE BIOS CUZ CANT GET MONITOR TO WORK WITH COMPUTER
You might be able to boot Windows in Safe mode (F5 at startup). In this mode WIndows uses a basic VGA driver. From there you can change the video driver to the appropriate one for your monitor. If you are unable to see video even before Windows startup, you may need to check the monitor on another computer to be sure it's working properly.
Bret
1-2-1ComputerServices
Oct 04, 2009 | E-Machines eMachines Desktop PC
My monitor wont stay on.
May sound wierd, but Its windows, try going into safe mode, and changing the screen size, (1024 x 768) sometimes, it gets put on a size that doesnt fit your pc/screen, so it turns off.. Like I said, go into safe mode, and change it around and reboot untill it works.. I had that issue once.
May 23, 2009 | Sony SDM-HS73 17" Flat Panel LCD Monitor
Computer won't boot
turn off the system remove all the cables from the back of the computer press and hold down the power button for 10 seconds now connect just the poer cable and try to tun on the system and as soon as it turns on tab the F8 key on the keyboard and then boot into last known good configuration
May 28, 2008 | Computers & Internet
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
