Question about Salsbury Industries Garden
Mower wont stay running
Hi I have a commercial desiel and its been losing power and wanting to stall so I changed the fuel filter and now it starts but doesn't stay started. It sounds like Its not getting the fuel. Any suggestions ????
    President:
  • 1,273 Answers
Pump the primer handle, bleed the air and pump the primer handle until it becomes very hard to pump. Try it again. Repeat as necessary to remove the air from the system.
Regards!
--W/D--
Posted on Jul 13, 2009
My mower was running fine it started to lose power and run about half throttle now it want run put chock on it run a second then quits
Hi Bobby:
I'd probably tend to give it a maintenance "once over"
- Change plug(s)
- change oil (and filter)
- flush carb (check fuel filter)
- fresh gas
- clean air filter
- clean underside of mower deck
See how it runs and we'll help with any remaining problems.
May 13, 2015 | Garden
Not getting gas to carb. changed fuel pump, bypassed filter. hold gas line below tank and fuel comes out. but not being sucked through pump it appears. help
It has a pressure differential fuel pump, just put a little fuel in the carb. and it should start it may stall but do it 1 more time and then it will stay running as it uses the crank pressure to actuate the fuel pump
May 08, 2015 | Toro Garden
Kohler sv735s
Sounds like it could be caused by low oil level
Oct 27, 2013 | Garden
84 john deere 410b stalls out
could be something floating around but did you fuel it one day and not the other try and run it with the gas cap off there is a vent on the cap that gets plugged
May 13, 2012 | John Deere Garden
Diesel fuel problems
sounds like you need to change your fuel filter. after you do.you may want to add some howes fuel treatment it will disperse the water. if the outside temp is below 0. you could also be jelled up. i think the cloud point on desiel these days is about 20 deg. thanks to the new ultra low sulpher.
Jan 14, 2012 | Cars & Trucks
Runs fine for 10 miles then starts missing and loses power acts like it wont take gas
Check if the breather holes in the fuel cap are open - when the tank is sucked vacuum, fuel supply stalls. If it's not that, check the fuel filter if it's clogged up - change the filter anyway when checking.
Jun 30, 2011 | 2001 Nissan Quest
I have a 2000 f150, while driving at 60mph it stalled. Fuel filter has been changed, pump is working. My truck wont stay running. Please help
Try wiggling the relays in the power distribution box under the hood, you may have a poor connection to the fuel pump relay. Also you should check fuel pressure. Also check the ignition, when your truck dies do you lose spark?
Aug 03, 2010 | Ford F-150 Cars & Trucks
Why does my 91 VW Jetta stall out and lose power while driving?
I had a similar problem and the mechanic diagnosed it as a problem with the ignition coil. So you might want to get that checked.
Jul 02, 2009 | 1991 Volkswagen Jetta
Cant get truck to stay running
did you try the fuel filter
May 20, 2009 | 2000 GMC Sierra
Mower will not stay running
Sounds like a lack of fuel. If it has a briggs motor replace fuel pump diaphram in carb.
Jul 19, 2008 | Electrical Supplies
Garden Logo
75 people viewed this question
Top Salsbury Industries Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Salsbury Industries Garden Expert? Answer questions, earn points and help others
