Question about Whirlpool LGR5636L Gas Dryer
Glow of fire gas dryer
Is it normal to see the glow of the fire at the back of the dryer
  • Mike Smith
    Mike Smith May 11, 2010
    The glow is probably the electronic ignitor glowing for a few seconds at a time .
  • 72 Answers
No. some of your duct must have come loose
Posted on Aug 04, 2009
Fisher & Paykel dryer orange glow under dryer while operational.
gas driers use a flame to heat the drum for the drying so there will be a flame some where in the unit
when in doubt get in a technician to check and /or repair
Jul 13, 2017 | Fisher Dryers
I replaced the thermal fuze in my kenmore gas dryer. Now not only does the dryer not FIRE up, but when I push the button to start the dryer, it will not fire and will shut off shortly after. When I let go...
when you start the dryer does the igniter glow red hot? they crack very easy.If you are sure you put the wires on the fuse the right way,and the igniter is glowing, and you remembered to turn the gas back on,( I've done that ), no kinks in the gas line.The next thing I would look at is the gas vavle, or coils. good luck.
Jan 19, 2011 | Kenmore 400 6942 Dryer
First cycle dryer will fire as normal. each time after it will not light. glow plug is working but no gas allowed to turn on. i'm feeling it may need coils for gas valve?
I would change the ignitor first...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 16, 2011 | Maytag Neptune MDG5500AW Gas Dryer
Maytag gas dryer model#NDG2330AWW heating problem
your gas coils are bad. they open up for the first cycle but fail to after. Replace your coils and this will solve your problem
Dec 13, 2008 | Maytag Dryers
Dryer starts normally but no heat - burner never lites
had same thing happen.. i replaced the thermal fuse located on back papnel.. fires right up now..partis about 15 bucks at any appliance part store or online.
Aug 01, 2008 | Whirlpool GGX9868J Gas Dryer
Kenmore elite gas dryer
Does the ignition glow when you start the dryer? if so you have power to gas valve and ignition system. if not you may have an open thermostat or thermalfuse.
If the ignitor just sits there and glows all day, you have other problems, It could be a gas valve, or ignitor sensor.
Jun 04, 2008 | Kenmore Elite HE4 Electric Dryer
Gas dryer fires up once and that's it
suspect coils on burner once burner fires and heats up area coil may fail on next firing 2 coils are present.. whirpool sends both in kit
Apr 26, 2008 | Whirlpool GGX9868J Gas Dryer
Kenmore gas dryer 80series model 110.c72852101
if you hear the valve clicking but no gas the valve is bad.when the burner lights theres a probe that senses that it is lit and sends a microvoltage back to the controller to tell its lit.check to make sure all ground wires are grounded to a clean metal surface.
Oct 03, 2007 | Kenmore 74602 Gas Dryer
Gas dryer
There should be a gas igniter, inside of the burner chamber, that will glow bright red before the gas will be allowed to flow. If the dryer model that you have has a flap on the front you will be able to observe this otherwise you will have to remove the front of your machine to check it. If you post back with your machine model number I will be able to assist you further.
Mar 12, 2007 | Maytag MDG2706A Gas Dryer
Whirlpool LGR5636L Gas Dryer Logo
77 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
