Question about Hotpoint Refrigerators
I would like to know the model number for my hotpoint fridge
I found this number athe bootom of the fridge GT290734
    President:
  • 704 Answers
Without knowing the approximate age of your fridge, or the style, (top/bottom freezer, side-by-side, etc.) it makes it hard to give an exact answer. However, I'll provide you with some places to look for the model number.
You should look inside the fridge section of the unit and there should be a label either on the ceiling of the fridge section, on the upper side of the fridge (look at both sides), on the edge of the door opening located at the bottom of the fridge (when door is open) or behind the toe kick plate at the bottom of the fridge. Another place to look is at the back along the top edge.
Again, without more info, it is difficult to zero in on where the data plate is. Hope that helps, if you have more info, get back to me and I'll try to help you further.
Posted on Jul 13, 2009
Fridge light not working
door light switch Need full model # for better idea .
but normal switch should be at bottom of door or at hing side of ref
some model have at top it may be broke off and thats why you don't see it send us a full model number we will find for you
Feb 28, 2015 | Hotpoint Refrigerators
Need to know the year of a Hotpoint fridge. Ref numbers are: CTHY16EPERWH MF 780907
According to that model and serial number is was made in July 1991
Aug 24, 2011 | Hotpoint Refrigerators
Small puddle of water under fridge
if you have a thin sheet of ice in the bootom of the freezer your drain is clogged,use a hair dryer to lossen the ice sheet and get it out of the way,heat up the drain hole and pull the frig. out from the wall,use a hanger or something you can usr to clear the drain tube,last get a hot half cup water with alittle beach and pour it down the drain,your done,let me know how you do-ike
Nov 28, 2008 | Maytag MSD2756GES Side by Side...
Fridge is not cooling
if you found the coil iced up then there is a defrost problem check thethermodisc and defrost control board if you know the heater is ok
Jul 09, 2008 | Hotpoint FFM90 Bottom Freezer Refrigerator
I don't know how to set the temperature setting on my Hotpoint RLAV21 fridge. The dial goes from 0 to 4. For fridges I have had in the past the higher the number the colder the fridge but I've got my...
You should have 2 dials one is the thermostat when you set it all the way one direction it will shut you refrigerator off. Turn it back to about the middle if there are no numbers. The other dial is the air damper between the freezer and the refrigerator. The fan circulates the air through refrigerator by this damper. If you open this open to much your food in the refrigeration section will freeze. Close it back to about 2 that will give you a colder freezer and should be about right for the refrigeration section.
May 17, 2008 | Hotpoint Refrigerators
Hotpoint fridge
what is the model number of this unit
May 17, 2008 | Refrigerators
Condensation problem hotpoint mistral 8596
if the door seals are both ok, check and see if she has any open containers in the fridge juice ect that may be allowing moisture to escape. a model number and serial nuber off the sticker in the fridge would help me with more ideas.
Sep 25, 2007 | Hotpoint FFA60 Bottom Freezer Refrigerator
Refrigerators Logo
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
