Question about Ridgid 3 X 18 Belt Sander
Dead. Power is connected, wires are in tact. Just died when I was using it. Is ther an internal reset?
    President:
  • 1,273 Answers
Try to plug something else into the outlet, just to make sure that the breaker didn't trip.
Try to run the sander without a belt. It may be in a bind.
With the sander unplugged, check the motor brushes. Replace if necessary.
If everything above checks out OK, you may have a loose wire.
Regards, --W/D--
Posted on Jul 13, 2009
My altect lansing bxr1121 speakers stopped working suddenly. I have checked all the connection but the power led is off.
Hi. i think it is the internal connections or jacks need to be resoldered, but first try to check the continuity of each wires. tact switch cleaning and replacement is another approach.
Mar 07, 2011 | Altec Lansing BXR1121 2 Speakers
Died. nothing comes on, so not dead drive. switched out power supply, so not dead power supply. the switch on the front - blue led only comes on when plugged in lower right two prongs of 8 (4x4). So, tried...
short power switch pins on mother board, reset bios, short green wire to black wire on ATX connector with all drives etc.. power cables disconnected to test power supply. i suspect you have a dead motherboard.
Jun 20, 2010 | eMachines ET1161-01 PC Desktop
Battery keeps draining
if your battery died while driving and the car cut off while your driving,, your problem is from your alternator!!!,, on a normal working car, you can start, remove ther battery terminals and the car would still run cause the alternator will be powering the car. In your case the alternator isnt working and the car was working on battery power therefore when the battery went dead the car cut off.. Your alternator need \s to be charging between 13.5 and 14.2 volts.. as little as 10 volts will keep the vehicle running.. I'd suggest you have the alternator replaced.
May 06, 2010 | 2003 Chevrolet Impala
Battery is dead or dying what kind do I get for replacement
is ther any light on the car. if not the battery can be emty.(control whiit on lamp or mont an charger and tri again. if ther are ligt you thak of the minus on batteri and plug in the multimeter betvin car and virring minus.(multimeter on amp.)then se if ther are leaking power . shoud not be many amp whit the shwits of/now power jusers one. tack one and one fuse out to se when te amp is going down. then you now wher the fault can be.the seck for the component on that to find the one using your amp.
Dec 04, 2009 | 1992 Oldsmobile Ninety Eight
1983honda vf750s v45 sabra: one cylinder & tact die out. can happen at anytime, can last for a few seconds or long time.
Hi and welcome to FixYa,
With the indulgence of Knight 007...
The tact dying is significant. It indicates that the pulse drive from the spark unit (CDI) towards the ignition coil has gone missing. The intermittent problem almost always points to a loose connection from the CDI connector to the terminal of the coil for the cylinder that misses. This would be the yellow wire of CDI to yellow wire of harness. This should not be mistaken for the yellow wire from the other CDI that connects to a blue wire that goes to the other ignition coil and fuel cutoff relay.
In some instances, the intermittent loose connection could be heat related and internal to the spark unit. A way to verify is to interchange the spark units where in the expected problem would be that the tach would no longer fail but the bike would suffer with fuel starvation.
Perhaps a wiring diagram would be of additional help.
Good luck and thank you for using FixYa.
May 08, 2009 | 1982 Honda VF 750 S
GE Profile Dishwasher PDW7300 Died on me!
Turns out the folks who installed it did a shoddy job of connecting the power. The power connections were not twisted on tightly enough, and after time, the continuous arcs of current between the loose connections burned through the wire nuts and finally separated the poorly twisted electrical wires. SOLUTION: Turned off power to the dishwasher, chopped off old, burned up wire ends, stripped some insulation off, twisted/spliced the electrical wires back toghether TIGHTLY and then tightly closed it all with quality wire-nuts. Power came right back on! :-) Yay! The only problem is, since the washer had been sitting/dead for a week or two, the lubricating water on the motor's ceramic bearing dried up, causing the motor to seize up. Had to replace the motor. :-( But everything is working fine now!
Apr 17, 2009 | GE Dishwashers
No Power ... Display Blank
There may be, but your problem is not any of those. You apparently have a short to ground somewhere that need's to be located and repaired.
Jan 24, 2009 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Vechicle died when sitting a stop light
If the battery is dead it is probally a bad alternator, which is what recharges your battery.
Obviously, if your car is using power, but not recharging the battery eventually the car won't have any more power.
Otherwise, it could be a bad connection of one of the wires or a bad fuse or relay.
Jul 24, 2008 | 1994 Mazda 929
I have a syncMaster 997 DF it is acting like it has no powere and will not come on - it has done this before when i moved it to change locations to a different desk - then the next morning i plugged it in...
probly you have loose conection...the wires that connects the monitor might be broken...try moving(shaking) the wires will it is power (AC current is given to it)...press the power jack harder into the monitor....or else it can be some internal faliure
May 10, 2008 | Computers & Internet
Ridgid 3 X 18 Belt Sander Logo
141 people viewed this question
Top Ridgid Tools & Hardware - Others Experts
rickb63
Jerry Kramer
Jerry Kramer
Are you a Ridgid Tool and Hardware - Other Expert? Answer questions, earn points and help others
