SOURCE: Sony Dav-C770 blinking standby light product will not function
I had the same problem, red blinking light after owning for several years. I decided to replace the capacitor at C914 to see if it would work, and it did. Apparently that capacitor is prone to failure. Since this seems to be a common problem, I created a web page detailing the repair. Hope it is helpful. Repair cost $1.39 + tax.
http://hancockfamily1.googlepages.com/dav-c770repair
SOURCE: While in TV mode after a few minutes the DISC lights flash.
turn off the demo mode. see page 32 in your manual...
SOURCE: My Bose 321 series II is not responding to the
Replace the batteries from the remote control. Press and hold the TV button on remote for 5 seconds. If the red light shines bright, your remote is OK since it is showing it's programmable side. If unit still won't go on using the remote, reboot the whole system by unplugging the power cord and other wire from the Subwoofer. Wait one minute, then replug all and see if the system displays BOSE 321 in front when re-connected. If so, try the remote and if that doesn't work, your dead, the Infra red communication device from the unit to the remote is busted inside the unit and needs to be returned to the company like mine!!!!!
SOURCE: Comcast remote codes for Sony Bravia DVD Home Theater System
This Also Works for DAV-HDX598w
SOURCE: Apex DT250 wont turn from standby (red light) to On (green light)
The
DT250 has one or more bad 470uf 25v capacitors. You should replace all
four. Look at some of these youtube videos for how do do the
replacement.
http://www.youtube.com/watch?v=on_2CP52cW4
http://www.youtube.com/watch?v=YCSNWi3UHf4&NR=1
Order 4 new 470uf 25v capacitors from digikey.com P/N P10274-ND
Use first class mail as your shipping method. Will be under 10 dollars total.
I also have exactly the same problem with you. I tried reset many times as well as switching off and on the Power on the console but the problem is still the same. My Subwoofer power lights also blipping Orange to Green all the time.
Have you found the remedy by now?
Mine has been doing this for 3 days. Anyone figure it out yet?
Did anyone figure this out yet. Thanks
