Question about Dryers
Kenmore HE4 dryer kick plate won't come off
Our dryer stopped heating and we want to check the fuses. How do we remove the kick plate from the Kenmore HE4 dryer. We took out the bottom 2 screws, but it sticks at the top. We don't want to force it off and break it...is there a trick?
  • 5,911 Answers
With the screws removed, tap each side of the panel and it should drop down. Sometimes the panel can stick (epecially if dryer softener sheets are used).
The Thermal Fuse is located on the blower fan housing. It is a white (or gray) colored plastic component with two wires. If it is blown the dryer will not run at all. If the dryer IS running, however, but not heating, the following link will give you the steps necessary to troubleshoot:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
Most dryer heat related problems are attributed to poorly installed, kinked or clogged exhaust ventilation. If this is your problem, please refer to the section that discusses the ventilation. Replacing any failed components with a dryer left in a clogged condition, will result in repeated failures of any components you do replace.
The heating element on your dryer is located on the lower right hand side under the drum. The Thermal Cut-Out (TCO) and Hi-Limit Thermostat are mounted on the outside of the heater box to the left of the heating element. The component that commonly blows in an overheated condition is the TCO. It is located at the end opposite the heating element terminals. If the TCO is bad, replace the Hi-Limit Thermostat at the same time. Failure to do so may result in premature failure of any parts you replace. These two components are often sold as set.
If you have any questions, or require addtional assistance, please let me know. I hope you find this information helpful.
Posted on Jul 13, 2009
Kenmore elite he4 moder 110 won't heat
In terms of likelihood, here is what's wrong:
1) The heating element has failed.
2) One of the several "overheat thermostats" has overheated and failed.
These are found in the back or the bottom of the dryer in the rear.
3) One of the wires to something, like the heating element, has burned in two.
4) The panel where the electric cord attached to the back of the dryer has failed. This will be inside the back of the dryer, usually behind a small plate.
5) The circuit breaker for the "heating" circuit wire of your dryer is popped and needs to be reset. (That is the circuit breaker found in your hall, or basement, or garage, or wherever.)
If you decide to fix it yourself, a question to "fixya" might get you step-by-step instructions.
Be blessed
4)
Feb 11, 2013 | Dryers
I have a Kenmore Elite HE dryer full of lint in side behind kick plate
A break in the the element should not have passed a continuity check but there are rare cases. For example, I went to a call in my beginngin years for a dryer that was taking too long to dry. This is the usual complaint when the vent is clogged or the liine is restricted cause poor air flow. There was a kink in the vent so I fixed the vent and off I went. A week later the customer called back with the same complaint. At this point I did what you did and had the same results. After multiple call backs I decided to remove the parts becuase I was looking for a shorted wire. As I removed the element I by chance looked down into the canister and low and behold the element was burnt in two but a place where the element wire was touching the canister and giving a false reading. I guess what I'm trying to say is take the element out and look at it. Also when checking the fuses atleast disconnect one wire because if both are on you can get feedback through other roiutes and give you a false reading .
Apr 29, 2012 | Kenmore Elite HE4 Electric Dryer
We a Kenmore Elite clothes dryer (Model # 110 70972990). Monday there was a power outage that happened while the dryer was running. Hours later when the power was back on, we tried to finish drying, but...
There is a thermal fuse. If your lint filter is on top of the machine it is in the rear of the machine behind the removable panal near the exhaust port. If the filter is in the door the fuse is behind the kick plate on the top of the blower housing they are usually white plastic. But a power outage won't blow the fuse
Oct 19, 2011 | Kenmore Dryers
I have a kenmore he4 no. 110.85871400. i have no heat replaced thermal fuse high limit thermostat anf thermal cutoff switch. still ni heat. elements are good. cleaned all lint. do i need to get a...
Check thermistor with ohm meter, make sure you unplug unit first, make sure wires are removed from thermistor or you will read ohms thru the wiring. If thermistor checks ok, the you have a relay board problem. replace power board.
Sep 29, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4 gas dryer, no heat at all
The ignitor may be bad or the thermal fuse may be failed.
Aug 27, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore HE4 - no heat
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Jun 18, 2009 | Kenmore Elite HE4 Electric Dryer
Dryer won't Heat up - Kenmore Elite HE4 Gas Dryer
hi..A poor connection between the wire terminals and the
heater relay causes high current draw and damages the
terminals on the heater relay on the main control board.
check it out..
thank u..
kindly rate my response..
Jun 09, 2009 | Kenmore Elite HE4 Electric Dryer
Dryer not heating
what is the model #the heater is not in the back of the he4.
Oct 21, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
Top Dryers Experts
